Hot Rods 16 common VACUUM gauge readings
Discussion in 'The Hokey Ass Message Board' started by Flatheadjohn47, Mar 20, 2020.
  1. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    5351F23D-C25C-4C09-B44C-1AB2EAD73599.jpeg 60523E58-00EE-4804-8AA8-088600530ED8.jpeg being 72 years of age,all of my hot rods(close to 12-15 early Ford v8) always have a vacuum gauge for me to observe while driving my cars. They are forever moving each time the go pedal is changed. I have had this deteriorated guide many years and have consulted it many times. Pictured are 16 different readings showing various problems or statements regarding virtually any gasoline engines. A vacuum gauge will tell you many things about your engine. Enjoy—-Flatheads Forever!
  2. onetrickpony
    onetrickpony
    from Texas
    I set carbs and timing by vacuum gauge any time I'm working on a non-stock setup. Factory settings will get you close but a vacuum gauge will put you on the money.
  3. It’s one tool I use quite a bit, but most modern “ technicians” have no clue how easy and versatile this simple tool is to help diagnose issues.
    rhanks for sharing
    Deuces likes this.
  4. southcross2631
    southcross2631
    My dad showed me how to set the timing using a vacuum gauge when I about 12. He said that way the motor would tell you what it likes.
    We would do a hands on test for prospective new mechanic hires one of the challenges was a plugged cat convertor where we would put a washer in the exhaust system . Hooking up a vacuum gauge would show really low readings , but some applicants did not even know how to use one .
    They wanted to hook up a scan tool.
    VANDENPLAS likes this.
  5. 57 Fargo
    57 Fargo
    We still teach it here for diagnostics however it’s getting harder to find a spot to hook one up as well
  6. Sporty45
    Sporty45
    Thanks for that guide, I saved it to my computer :cool:
    Deuces likes this.
  7. Casey Riley
    Casey Riley
    from Minnesota
    I bought a vacuum gauge at the farm and fleet store that came with a sheet like that.
    Deuces likes this.
  8. WZ JUNK
    WZ JUNK
    from Neosho, MO
    I have been messing with this some lately on a new engine with an aftermarket high lift cam. Hot Rod Magazine recently had an article on using a vacuum gauge and I was using that article as a guide. I tried working with the idle screws but the vacuum readings on this engine are erratic and it is difficult to see the change when you are adjusting the idle screws. I have been battling other issue lately but I plan to get back to the vacuum gauge and tuning soon.
    I would like to know more about how a non stock camshaft effects the vacuum readings.
    Deuces likes this.
  9. special-k
    special-k
    The short answer is to restrict the line until the needle smooths out. That doesn't help you on the effects of erratic vacuum on vacuum advance units etc. I'm sure the more advanced guys here will have a ton more info on this subject
    Deuces likes this.
  10. stillrunners
    stillrunners
    from dallas
    Neat...thanks for posting.....think that's the other gauge next to the Sun tach that was in the "paper route" 1955 Stude - you can't see the door but its right behind the rear bumper....also use these as well......... me 1955 goode's under garport.JPG
  11. J. A. Miller
    J. A. Miller
    from Central NY
    Used to be a vacuum gauge guide like that in the front of every Motors Manual. One of my favorite diagnostic tools.
    Deuces likes this.
  12. Kan Kustom
    Kan Kustom
    Thanks for posting this.
    Deuces likes this.
  13. Gasser 57
    Gasser 57
    from New Jersey
    Thanks, I have added it to my computer "car files".
    Deuces likes this.
  14. bobss396
    bobss396
    This is pure gold. I have a sheet somewhere I got with a gauge many moons ago.
    Deuces likes this.
  15. I have had the short version saved on my 'puter.
    Gasser 57, Kan Kustom and Deuces like this.
  16. I am 76, and have been using a vacuum gauge in all my cars and boats, since my first car at 15 yoa. I also have one in my main tool box for tune ups.
    I wouldn't be without one.
    Bob
    Deuces likes this.
  17. Greg Rogers
    Greg Rogers
    I remember those charts well and used them a lot. I had my first car (65 Cutl*** 330) my parents bought me a tune up tool kit from Sears or somewhere. The problem was that the vacuum reading was always low compared to what the chart said it should be. "A" is where it should be 17-21 in. My 330 was always about 15" or as is "C". And what does "C" say about that reading? Worn rings!! Now I was all worried that my engine was junk and worn out. Later me and a buddy checked other cars and they all were about 15". I remember telling my Dad that my engine was worn out and needed a overhaul... That went over well and of course I was wrong. Maybe that cheap kit had a bad vacuum gauge...
  18. TagMan
    TagMan
    I never drive any of my old cars without a vacuum gage in my tool kit. It's been a help on more than one occasion.
