Hot Rods 16 inch steel wheels.
Discussion in 'The Hokey Ass Message Board' started by GordonC, Mar 10, 2020.
  1. GordonC
    GordonC
    I recently bought some Ford 16 inch steel wheels sight unseen through a buddy. Price was pretty cheap. Lesson number 1 don't do that ****! Go and look at them first! Anyway, I had the wheels blasted in order to get a good look at them in bare metal. Turns out they are too far gone to be used. Which brought up the question are the centers of these wheels worth doing anything with? Three of the four centers are in decent shape but the hoops on them are in rough shape. Is it worth pulling the centers out or should I just bite the bullet and s**** them? I searched around but didn't find anyone making 16 inch hoops thinking that might be the way to go? I already have bought new 16 inch steel wheels so these aren't needed but I didn't want to **** can them if there was any value to them.
  2. alchemy
    alchemy
    Sure there’s some value, but it might not be much. Maybe $25 per center?
    GordonC likes this.
  3. RMR&C
    RMR&C
    from NW Montana
    I'd save em, but I'm kind of a hoarder....
    I have re-hooped the 15" Ford (F100) wheels with modern hoops, so finding 16" hoops for them is a possibility. Probably a thread on here about it.
    GordonC likes this.
  4. Desmodromic
    Desmodromic
    I ***ume your referring to '40 to '48 wheels (5.5" pcd), not the '49+ (4.5" pcd). I think some Jeep wheels are 16" x 5.5". There are dozens of wheels with 16" outer rims (GM, Mopar, Nash, Stude [?], etc.). Question is, do all drop center outer rims have the same ID, as an industry standard, or do they vary from make to make (does anyone know?). I personally wouldn't dream of t******* the center or outer rim in a lathe to get a good fit. If you find any Ford wheels, they will not likely have good outer rims and trash centers. Obviously, if both pieces are good, you'ld use them and s**** the ones you have now (or give your buddies some tacky hose reels next Christmas).
    kidcampbell71 and GordonC like this.
  5. Budget36
    Budget36
    Thought Speedway sold hoops?, maybe Summit too?
    GordonC likes this.
  6. Smiffy
    Smiffy
    Hi Gordon
    You could always go down to 15 inch if the centres are Ok. Get 15 inch industrial rims or similar and give the centres a quick skim on the lathe , center them up and weld them in. Read about in an old R&C magazine years ago then did it myself worked out really well also meant I could use the old 46-48 hubcaps as well.
    BradinNC, keith27T and GordonC like this.
  7. RICH B
    RICH B
    I had a couple wheels with bad hoops; cut the good centers out, instead of s****ping the whole wheel. Ended up selling them to a guy with wallowed out lug holes in his wheels. So, yes centers are worth saving to repair other wheels; doesn't take much to drill the rivets and torch the hoop.
    big duece and GordonC like this.
  8. clem
    clem
    Keep them, one day you will find some decent similar wheels with flogged out stud holes.
    GordonC likes this.
  9. GordonC
    GordonC
    I did find 16 inch tractor hoops that were 4 1/4" with an inside dia. of 13.430". One other place I never heard of had 16" x 4 1/2" and 6" with 13.430" centers. I think the ones I have are around 13.625". Speedway only had 15s if I recall correctly. I didn't see any 16s on Summit. Thanks guys. I think I'll invest the effort to pull the centers out of these and hold on to them for now. Appreciate the help.
  10. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    There aren't any new rims available that are the right size, they either have to be cut down to fit or you have to use another original rim. Ford used that ID into the 80s on most of their 16" wheels.
    town sedan and GordonC like this.
  11. alchemy
    alchemy
    So a guy might find some good used donor rims in the junkyard on a later model Ford ? Maybe even in a 6" or 7" size for use on the rearend?
    If anybody goes scrounging and discovers the proper source vehicle, please post it here.
  12. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    Yes, for something that wide I'd look around the 80s 8 lug trucks.
  13. 31Apickup
    31Apickup
    I thought there was a thread some time back that mentioned 90’s era Chevy pickup 16” rims had a hoop size that would work, although I haven’t verified it.
  14. chriseakin
    chriseakin
    There are imports with 16" steel wheels - check out any small SUV, there are enough they should be cheap and might even be an American brand.
  15. rusty valley
    rusty valley
    i just painted a pair of 16" 3/4 ton wheels for my pickup. man...they are heavy compared to an old ford
  16. Desmodromic
    Desmodromic
    I have some experiences in stress ****ysis of high pressure high temperature piping systems, and weld design of related components, which I'll concede is not directly applicable to this proposed wheel fabrication. But, I think I've developed a good intuitive feeling that tells me this is not a good idea. After the flange is cut off the inner wheel, your left with essentially a disc being welded to the outer rim, using I ***ume a single fillet weld on the back side. Even with a double fillet (i.e., on both sides), the combination of a now somewhat flexible inner wheel and being subjected to exceedingly high stress cycles, suggests a likelihood of cracking. If I had to do this, the weld would be a full penetration double fillet, with a very gentle concave contour of the weld surface. I'd inspect it frequently, and have the welds checked by dye penetrant at some point.
    Anyone out there with Finite Element ****ysis experience that can chime in?
    There is a reason wheel centers are made with flanges around their cir***ference, and it's not because it's cheaper!
    INVISIBLEKID likes this.
  17. nochop
    nochop
    from norcal
    Hose hangers
  18. krylon32
    krylon32
    from Nebraska
    Years ago I had Rally America make me some 16 X 8 inch wheels with new hoops and gennie centers.
  19. GordonC
    GordonC
    Well I solved my problem by just ordering up some reproduction 16 inch wheels. In the mean time I pulled the centers out of 3 of the 4 wheels I had. Fourth was rusted through. If anyone has some wheels with wallowed out lug holes and wanted to swap out their centers these have good lug holes and are up for grabs.
    Just Gary, silent rick and town sedan like this.
  20. They've been replacing or reversing outer hoops for decades. Super easy, get a used inside caliper or chunk of something, measure id of hoop, go to the junkyard and find another 16" that fits. Fords are easy to take out because the rivets, others you just carefully cut/grind through the welds to leave the center intact. The center should fit snugly maybe even needs a few whacks with a hammer to get it in and then weld it in. I over simplified it, but you get the point. I took mine in to get it trued and welded, the place has been using new and used parts for decades.
    Don't waste the centers, you can make some 16x5 or 16x6 with some cheap Toyota, Chevy, Mopar or whatever will fit. I waited for the 40% off sale at Pick Your Part.
    GordonC likes this.
  21. I can say that most of them are different. I had my Chevy wheels re hooped on my '56 panel and had to find donor wheels. I checked out about 30 wheels from at least 5 different vehicle manufactures, various years and weight (1/2 ton, 3/4 ton and 1 ton). After I found the wheels that would work, I was told that the other set of same era wheels from a truck were easier to find hoops for (40's-50's Chevy car 6 clip vs. 40's-50's Chevy truck 3 clip). I was also told that my car wheels didn't match any newly made hoops, but the truck wheels did........I only had 1 truck wheel and they're harder to find.
    Moral of the story is don't give up, there's a match somewhere and I came home with $55 worth of wheels (and more knowledge).
    Oh yea, I did buy some 15x6 disc brake wheels from them for the Studebaker for $25 each. They're a Ford shoebox center and a disc brake hoop (disc brake has a different profile then a drum brake hoop to clear the calipers)......someone ordered them and never picked them up.
    GordonC likes this.
  22. Scnick
    Scnick
    Do you know if there are any 6.5” or 7” wide donor 16” hoops with 13.625” ID that are NOT the thick heavy steel ford truck rims?
  23. nobby
    nobby
  24. AccurateMike
    AccurateMike
    Donor 16x7 hoops with 13.625 ID
    https://www.jalopyjournal.com/forum/threads/donor-16x7-hoops-with-13-625-id.1346559/
    Some of this is covered in this thread.
    I pushed the riveted centers out of some wheels. There was considerable press fit. My 20T air/hydraulic press actually groaned a bit. It's the way they were designed. I have hoops with the same ID and it will be a push going back in. Just throwing this out there. Don't measure the center's OD to look for hoops, measure the old hoop's ID.
    RMR&C likes this.
  25. dart4forte
    dart4forte
    from Mesa, AZ
    you should have a chat with your buddy
    GordonC likes this.
