16" Tire Size Recommendations For My RPU
Discussion in 'The Hokey Ass Message Board' started by rhpope, Feb 28, 2008.
  1. rhpope
    rhpope
    I have a set of 1935 Ford 16" x 4" wire spoke wheels to use on my rpu.
    What are the typical size tires to use on the front and on the back?
    Something like 6.00-16 on the front?
    Don't know about the rear, but I have noticed from pictures of others that the rear tires are usually bigger in diameter and fatter (or wider), so, maybe a 7.00-16 or 7.50-16?
    Thanks,
    Roger
  2. i ran 5.50 fronts
    and 8.50 rears on the tub i built
    8.50's are about 33' tall
    i ran 16x4 fronts (42-48 ford wheel)
    and wide 5's on the rear
    tk
  3. sxdxmike
    sxdxmike
    it depends on the look you're going for..but i always like the look of about a 5 inch height difference between the front and rear tires.
  4. rhpope
    rhpope
    tk,
    How wide are the Wide 5 wheels?
  5. not sure
    my guess is 4 inches
    i think they are different depending on weather it was a v8-60 car or a v8-85 car
    tk
  6. G V Gordon
    G V Gordon
    from Enid OK
    You can run up to a 7.50 tire on your 4" wheels although a lot of folks don't recomend it.
    My personal opinion is a 7.50 is too "cheeky" on that narrow a rim. It gives it a baloon, kind of cartoony look.
    When I swaped out the rolling stock on the T I went with 7.00 Firestones and 5.50 Excellsiors both from Coker. These are on stock '35 wires.
    Pics worth a thousand words so here is a side shot.
  7. von Dyck
    von Dyck
    Check the Speedway Motors catalog, especially their Late Model racing catalog in the wheel section. They sell wide 5 centers to fit 15" shells to almost any width you want, depends on the "look" you're after. They need to be ***embled on a truing stand, then welded by a competent welder. Otherwise you'll have to split your 4" rim, add 2 - 3" band, truing stand, competent weld, if going the 16" route.
    G.V.Gordon is right (IMHO). A 7.50 looks "right" on a 7" wide rim.
  8. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    7.50x16's in the rea5 and 4.50/4.75 16's up front...
    There nothing better looking on a hot rod than this combination...
  9. I looked at ALOT of photos and prefer a more conservatrive approach so I choose 600/700 combo for my A rpu. BUT those 16 in wires look really good with larger rubber...
  10. NealinCA
    NealinCA
    5.00/5.25-16 Firestones on 16x3.5" wheels in the front
    7.50-16 Firestones on 16 x 5" wheels in the back.
    Neal
