16ga bead roller
Discussion in 'The Hokey Ass Message Board' started by kiljoy, Sep 20, 2011.
  1. kiljoy
    kiljoy
    i am in need of a bead roller that will role 16ga steel. i have found a few but they are all 5k plus. has anyone made a heavy duty bead roller that will do 16 ga? would it need to be a powered unit?if so i would love to see some pictures.
  2. kiljoy
    kiljoy
    Anyone use any of the cheaper brands (HF etc) to role 16ga with success? if so what brand and did you have to modify it? did it hold up well?
  3. Blue One
    Blue One
    from Alberta
  4. Da Tinman
    Da Tinman
    Mittler Bros standard one will do it if you use the steel rolls and dont do it all in one shot.
    It wont like and it might complain a bit but it will do it with no ill after effects.
  5. zman
    zman
    from Garner, NC
    My Mittler Bros. does it no problem, but when I bought it they were rated for 16g, they have since lowered the gauge that they are rated for. But I think Jay is correct, go slow and don't try and do it all at once.
    http://mittlerbros.com/proddisp.php?ln=1113
  6. lawman
    lawman
    I have a Pexto and would never go over 18ga. Anything over that
    is asking for trouble.Just my 2cents.
  7. kiljoy
    kiljoy
    thanks for all the help! i think i am going to build this machine here http://youtu.be/8aAOQAGsV38 he claims it will do 16ga no problem without distorting the heads (multi p*** of course) any thoughts on the design?
  8. kkustomz
    kkustomz
    from Texas
    i have a severly modified hf bead roller, i use it to do 16 guage steel with pretty deep beads in one p***, it also has a 3' handle for who ever has to turn it. what exactly are you going to be doing?
  9. kiljoy
    kiljoy
    i would love to see the picture of the one that u use for 16ga kkustomz. i am going to be using it to make floorboards and a bed for my 72 IH scout II i will be making some 1'' dies to use for the bed. i plan on doing it in sections so depth isnt a huge problem
  10. kkustomz
    kkustomz
    from Texas
    ok, if i think of it i will take some pics tomorrow.
  11. Dyce
    Dyce
    Sounds like a job for a press brake to me. I've done some 16 ga in my modified HF bead roller but you're talking alot of wear and tear on a machine doing a whole truck bed. I'd use 18ga for the floorpans, and maybe even the bed.
  12. Da Tinman
    Da Tinman
    why not just bend it up on the brake, thas how I did this one. its 16 gauge and needed no subrails when welded up. (yeah my brake is built for doing that stuff)
    You could do much the same using 18 gauge and some subrails if your brake is girlie in stature.
  13. dabirdguy
    dabirdguy
    If you add about 60 pounds of steel to an Harbor freight one it will do it as well.
  14. kkustomz
    kkustomz
    from Texas
    yes you will have to tack weld all the gears in place after you set your correct end play alignment, those hf set screws are junk. who cares there only 100 bucks or so
  15. kiljoy
    kiljoy
    good idea, i will probably just bend the bed up at work ( i have power brakes at work that will do it no problem) i still plan on building the bead roller but i probably wont use it for the bed
  16. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Here is a less expensive solution:
    Bead roller / English wheel http://www.youtube.com/watch?v=f6FQ3dQQzxY
  17. my guess would be to use a Niagra 180
  18. Canuck
    Canuck
    Just tried this yesterday with my modified Eastwood econ version bead roller (similar to HF) with a 24" wheel turning it. Used the supplied dies in the widest bead version. No flex in the frame.
    Rolled it with a little effort (the wife was complaining that it was a little heavy to turn the wheel) in two p***ed with a little spinning of the dies to the maximum depth of the dies.
    Problem is the beads are not very deep and pronounced:(. Works OK in 18G. Going to a different solution for the trunk floor.
    Canuck
  19. kiljoy
    kiljoy
    ya that english wheel trick is cool Baileigh but at this point in my life i can only afford one or two of your smaller pieces of equipment :(. for now i have to make everything or keep an eye out for good deals on used stuff. i will post some built pictures of whatever i end up building
  20. choke
    choke
    The best way to roll 16 ga. I found is tie the top and bottom of the frame work together with a piece of steel. This works best if your just doing a bead around the work piece. I Have a Irvan beader that's made out of two pieces of 1 1/2 square tubing. I put a piece of tubing between these and clamp it in place. It gives you a nice defined bead in 16 ga.
  21. Irrational Metalworks
    Alliance Vendor
    from DFW
    Try Lowbuck tools. They make a very affordable one that will roll 16ga. all day long. I bought one 15 years ago, and I still use it as a secondary. Some of the best dollars spent!
  22. kiljoy
    kiljoy
    lowbuck is the winner. their unit is cheaper then building one myself. looks like i will use their bead roller for the base then maybe power it.
  23. gotwood
    gotwood
    from NYC
    TINMAN What brake are you using to do that reverse bend in what looks like 1/2-3/4" an inch apart? What gauge?
    I had a TENNSMITH and could never get that without it slipping and not anything less then say 1 -1 1/2"between bends.
    WHATS THE TRICKK?
  24. JimSibley
    JimSibley
    That baleigh oneooks way cool. How much is it?
  25. kiljoy
    kiljoy
    the Baleigh one is def the best available hands down but the price reflects this at over 5k. if i had a full on shop i would consider buying one for sure
