Projects 170ci inline six bent pushrod
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Apr 2, 2023.
  1. iwanaflattie
    iwanaflattie
    Hello hambers.
    I've been working on the econoline,,it was running great.
    Today I decided to work on the p***enger seat,started it and it was running rough then it started to run but with a metal clancking noise..bent pushrod..fffffuuuuuuck!
    What's the reason and how do I go about fixing it??
    Thanks in advance
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Timing set took a hike.
    Bill Whitehurst likes this.
  3. If the gas is old you may have bent a pushrod because of a stuck valve. I've seen a few intake valves get stuck because of this (old gas creating a liquid - sticky- mess that causes the valve to stick in the guide). If you're lucky the pushrod bends and the valve doesn't get stuck in the open position, getting smacked by the piston and bending the valve. Let us know what you find.
    RmK57 and Wanderlust like this.
  4. iwanaflattie
    iwanaflattie
    The distributor looks pretty old.
    Everything else looks new.
  5. iwanaflattie
    iwanaflattie
    Gas was new.
    Only used new gas..I guess I have to take the head off
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Timing set as in timing chain and sprockets.
    ottoman and gimpyshotrods like this.
  7. iwanaflattie
    iwanaflattie
    I guess the only right way to check is pull the motor and put on a stand.
    This is what I found when I first pulled it out to clean and paint it. FB_IMG_1680534825654.jpg FB_IMG_1680534820814.jpg FB_IMG_1680534813583.jpg FB_IMG_1680534807021.jpg FB_IMG_1680534802956.jpg FB_IMG_1680534799781.jpg FB_IMG_1680534795684.jpg
  8. gimpyshotrods
    gimpyshotrods
    Not sure how to tell you this, but here goes.
    That is a 200.
    The 144/170, and even the first year of the 200 had four main bearings.
    The 200 and the 250 had seven (and this is not a 250).
  9. gimpyshotrods
    gimpyshotrods
    I cannot read the part number on the cylinder head at the photos, but it appears to be a mid-1970's head, from the log size, but it is hard to tell exactly. The flat top on the intake log indicates later than 1960's, all the way to the 1980's!
    It has adjustable rockers, which means that someone has been in there. As far as I know, all 200's have hydraulic lifters, and non-adjustable rockers.
    You will need to know this when sourcing a replacement pushrod. A "regular" 200 has pushrods with a ball-end a the top, which interface with non-adjustable rockers.
    You have adjustable valvetrain, which has pushrods with cups, which interface with the adjusters.
  10. gimpyshotrods
    gimpyshotrods
    Check and report back two things:
    The part number on the head. It is on the intake log, on the rearward end, as raised letters and numbers.
    -And-
    The part number of the block. It is on the p***enger-side of the block above the pan rail, below the line of core plugs.
    The reason why I suggest this is that early blocks were equipped with dished pistons, to be used with small-chamber heads.
    Later blocks had flat-top pistons, to be used with large-chamber heads.
    While everything bolts together, if you put unmodified later heads on and early block, you get large chambers, and dished pistons, and a very low compression ratio.
    Toss in a modern composite head gasket, instead of the original steel shim head gasket, and it goes even lower.
    When I say low, I mean like 6.5:1.
  11. 62rebel
    62rebel
    Ya see some weird **** when opening up old engines. I wonder if I put that one together
    seb fontana and TA DAD like this.
  12. gimpyshotrods
    gimpyshotrods
    I run a 1966 200 block, with a 1980+ 200/250 head (largest log, runners, and valves of an OEM part) in my Flacon.
    To get the compression where I wanted, to took am 0.080" cut to correct the chamber size, and to compensate for the modern gasket thickness.
    These heads, if not previously cut, can take a 0.090" cut. If already cut, then you're already closer to where it would need to be to correct the compression ratio.
  13. 62rebel
    62rebel
    Gotta love Thriftmaster sixes; the LEGO of Ford engines. (well; as long as you don't try to put the 250 crank in a 200)
  14. gimpyshotrods
    gimpyshotrods
    Or a 235 crank in a 200, 'cause the Thriftmaster 6 was a Chevy. ;)
    The Ford small-6 was the ThriftPower 6.
    Kerrynzl and SS327 like this.
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    ...unless it was the 200 in my college girlfriend's '67 Mustang; then, according to the air cleaner, it was a "Sport Sprint".
  16. gimpyshotrods
    gimpyshotrods
    That's OT here.
  17. 62rebel
    62rebel
    OOOPS. Should have remembered that name; I had a hood emblem off my great-granddads AD for years
    Gotta love the names everybody put on their engine families before they lost their imaginations
  18. gimpyshotrods
    gimpyshotrods
    Like Turbo Fuel Stratified Injection?
    62rebel likes this.
  19. iwanaflattie
    iwanaflattie
    I put the 170 in the ***le so it wouldn't get ****canned
    '34 Ratrod likes this.
  20. iwanaflattie
    iwanaflattie
    Hi.how do I check if exh valve is stuck?
  21. gimpyshotrods
    gimpyshotrods
    The 200 came out in 1964.
  22. gimpyshotrods
    gimpyshotrods
    Push the rocker arm to the side and zip tie it there.
    Gently rap the top of the valve with a hammer.
    If it moves, trying levering it down a little with a pry bar against the rocker shaft.
  23. iwanaflattie
    iwanaflattie
    Thank you!that worked.the valve stuck(it was in the open position) it wouldn't move til I got it free with the hammer..
    I already order 4 rods from rockauto...
    Thanks!!
  24. seb fontana
    seb fontana
    from ct
    As a note the adjustable rockers were in the 1965 200's at least in the new off the floor Comet I had and was told by the service manager that some did some didn't.
  25. gimpyshotrods
    gimpyshotrods
    Ford did some weird stuff when they had extra parts.
    Truckdoctor Andy and Wanderlust like this.
  26. BamaMav
    BamaMav
    from Berry, AL
    They sure did. They’d use the last years parts until they used them up, totally redesign parts in the middle of a year run, lots of crazy stuff. Probably still do, I don’t have any knowledge of what goes on after the Windsor series, I’ve owned several , just didn’t work on them.
    That’s a big reason Chevy guys dislike Fords so much, it takes more work to find out what will interchange on Ford stuff. There’s probably 20 different accessory drives across the Ford line, where you can put a tin can on a Chevy and it will work.
    Algoma56 likes this.
  27. HEATHEN
    HEATHEN
    from SIDNEY, NY
    ...as is the vintage of the vehicle your cylinder head came from that you mentioned. Maybe we can share a jail cell.
  28. gimpyshotrods
    gimpyshotrods
    I have counted 23 in the Windsor family, so far.
    I won't touch a partial. If it comes in bare or missing parts, it gets a complete aftermarket drive ***embly, sold as a unit.
    Algoma56 and Truckdoctor Andy like this.
  29. gimpyshotrods
    gimpyshotrods
    Yup, but Ford, for all the nightmares that their "better ideas" about revisions brough, revised that head every few years.
    The end-of-line head had the largest log, runners, and valves, and flows very well.
    62rebel likes this.
  30. gimpyshotrods
    gimpyshotrods
    There was once a company called Cl***ic Inlines, but the owner p***ed, and the site disappeared.
    Much of the business was taken op by a new company called Vintage Inlines, so the parts went there (mostly).
    They managed to preserve the excellent tech section from the previous site here: https://fordsix.com/ci/Tech.html
    I s****ed the entire Cl***ic Inlines site when it went zombie, so I have the tech section, too, in-case that link above stops working for some reason.
