Projects 170ci inline six bent pushrod
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Apr 2, 2023.
  1. Beanscoot
    Beanscoot
    That engine sure is clean inside.
    As for Ford using up old parts in later years, we got a lot of that in Canada.
    Non-synchro first gear three speeds behind sixes and 260s in 1964, and of course the Flathead lasted until 1954 here.
  2. iwanaflattie
    iwanaflattie
    Was just Rereading your post when it hit me..I just ordered non-adjustable ones..it was 10 dollars so no big deal..
    Where can I get a set??
    Also I read that there could be different sizes
  3. spanners
    spanners
    Take the bent pushrod out, roll it on a flat surface and tweak it straight with a soft mallet till it rolls straight. I did this approximately 500 p***es ago with the engine in my avatar and it's still going strong. If you believe I don't give it a pizzling have a look on the HA/GR forum where I post videos.
    chessterd5 likes this.
  4. chessterd5
    chessterd5
    from u.s.a.
    I like to roll pushrods on a pane of gl***. It makes it very easy to see any discrepancies.
    X-cpe likes this.
  5. Beanscoot
    Beanscoot
    The suspense is too much, are you going to tell us the casting number?
    Budget36 likes this.
  6. iwanaflattie
    iwanaflattie
    Sorry the head casting number is
  7. iwanaflattie
    iwanaflattie
    D7BE 6090 AB
    Beanscoot likes this.
  8. Black Panther
    Black Panther
    from SoCal
    You said it was new gas...but was it in a clean tank and lines? If you put new gas in an old tank, I'll guarantee that there was varnish in that tank that got reliquified with the new gas. Essentially it's a glue. I've had it happen twice. Never again. All this ***umes it wasn't a tight guide from improper machining...but if it looks like it ran for any period of time..id say it was varnish in the fuel system. The way it happened to you is exactly how it's happened to me. You get something running thats been parked for years...engine runs great. You shut it down and try to restart it after the engine cools off or the next day or two and the engine is cold. What happened in the meantime is that the varnish glued that valve (or valves) open when the engine cooled off.
    Algoma56 likes this.
  9. Beanscoot
    Beanscoot
    That head has hardened exhaust valve seats so is good with unleaded gas, and has the large valves.
    It was used on both 200 and 250 engines.
    It probably has a large chamber though, unless it's been skimmed.
    gimpyshotrods likes this.
  10. iwanaflattie
    iwanaflattie
    D8BE 6015GE is the block number.
    Has a br*** tag that says REMANUFACTURED 191936
  11. iwanaflattie
    iwanaflattie
    New gas tank,New lines,New carb..the oldest gast must've been a month old...and I threw in 2 bottle of heet every during winter
  12. gimpyshotrods
    gimpyshotrods
    That is, I believe, the second highest flowing head they ever made for the small 6.
  13. gimpyshotrods
    gimpyshotrods
    There are different lengths for the 144-200, and the 250.
    There are, in the 144-200 group ball-ball, and ball-cup pushrods, for non-adjustable, and adjustable rockers, respectively.
    Other lengths are for accommodating aftermarket cams, small base circle regrinds, etc.
    I will check my stash tomorrow. I might have some.
  14. Beanscoot
    Beanscoot
    Cool, it looks like it was rebuilt January 9 1936!
  15. gimpyshotrods
    gimpyshotrods
    The part number for for ball-cup pushrod is MELLING MPR81.
    The alternate is SBI 1901280.
    I will check the bins when I get back to the shop at the end of the day.
  16. gimpyshotrods
    gimpyshotrods
    It is a large chamber head, but it is not on an early block.
    The head is from 1977, and the block is from 1978.
    Since part numbers were carried to the next revision, this could have been a factory-matched combo.
    Chambers and pistons changed in 1969.
    This head is indeed the second-highest flowing head that Ford produced, with the only difference between this one, and the top is a larger log.
  17. iwanaflattie
    iwanaflattie
    Thanks for all the info
  18. iwanaflattie
    iwanaflattie
    Gonna have to try this first thank you
  19. gimpyshotrods
    gimpyshotrods
    I have a full set of ball-cup pushrods, and RockAuto has them sold as singles, if straightening it does not work out.
  20. iwanaflattie
    iwanaflattie
    I didn't find them on rock auto.
    Found a pair on speedway, mine are about 8" so I bought the 7.890 from speedway..
    I tried to straight it out but the neck was too bent and the lip of the cup damaged.
    Thanks for the offer tho
    received_209823678345993.jpeg received_552359580314904.jpeg received_529294059282269.jpeg received_778602370364996.jpeg
  21. gimpyshotrods
    gimpyshotrods
  22. Budget36
    Budget36
    I could see trying to straighten a pushrod if it was Sunday and you had to be at work the next day. But maybe 20 bucks to your door and install it next weekend is the route I’d take.
  23. iwanaflattie
    iwanaflattie
    I swear this van is cursed..its been fighting me all the way..
    I ordered the wrong pushrods from rockauto using my paypal,it was only 14 bucks no big deal.
    They never showed up.
    I ordered the right ones from jegs.com using my PayPal and their system fu ked up sending both items to my old house..
    I've been using PayPal to buy stuff for 2 years!! Not an issue til I ordered those parts..
    I'm waiting on the new resident to see if someone in the picked up the package..WTF!!!!
  24. iwanaflattie
    iwanaflattie
    Thanks for all the replies!!
    Retrieved the( 1 out of 2 push rods) from the person that lives in our old house installed it and it runs beautifully...
    Any simple task seems complicated without the proper guidance...thanks a lot..
    Now to fix the other vans pushrod!!
    gimpyshotrods and Budget36 like this.
  25. BamaMav
    BamaMav
    from Berry, AL
    I bought a couple of AN heater fittings from Jegs store on eBay. Tracking number never worked, apparently fedex screwed the label up and put a new one on without telling anybody or issuing a new tracking number. After two weeks, I contacted Jegs through eBay and got a refund. Six weeks later, fedex delivered the original fittings! Nobody could find them, then suddenly they were delivered. Didn’t need them by then, I had ordered two from Summit and they were delivered the next day.
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Are you paying attention to the ship address that PayPal put’s up automatically? For me it’s like a slot machine and never know which address will pop up. I have to scroll and pick an address to be sure where stuff ends up.
    LWEL9226 and Budget36 like this.
