History ...
Discussion in 'The Hokey Ass Message Board' started by sgtlethargic, Mar 27, 2007.
  1. ...
  2. Crusty Nut
    Crusty Nut
    It looks to me that the tool you pictured could be modified with an extended arm. That or just make a whole new one.
  3. plan9
    plan9
    how about using a piece of string attached to an anchor point at the center to draw the circle then cut it with a hacksaw or pair of tin snips? i can see where it'd get out_of_round but take your time to minimise cleanup... is there a reason why it would have to be a perfect uniform cut?
  4. Retrorod
    Retrorod
    yeah......then make sure you have a nice rigid pilot to rotate around, and spin it fairly slow in a drill press or mill.
    I've seen hole saws that big but they do a nasty job usually.
  5. JPMACHADO
    JPMACHADO
    from Not Listed
    Do you have access to a plasma cutter? I used a piece of welding rod and hooked one end to the nozzle of the plasma cutter (the metal nozzel) and hooked the other to a screw I put in the center for a pivot. I coiled the rod around the nozzel and screw so it wouldn't slip out. I cut a PERFECT circle the very first time, and I'm an idiot most of the time. I guarantee you could do this. I was surprised how easy it was.
  6. ProEnfo
    ProEnfo
    from Motown
    They are called 'circle cutters' or 'adjustable hole cutters', although I've not seen one that could go that big.
    If you decide to 'extend' that one, clamp your stock to a piece of plywood or pressboard & cut halfway thru from both sides using plenty of coolant and a low rpm.
    A carbide bit in a router would be much safer....
    JMO
    CC
  7. paco
    paco
    from Atlanta
    Can you say large Beverly shear?
    paco
  8. gahi
    gahi
    from Moab, UT
    find someone with a pullmax and circle cutting attachment. no hole in the middle.
  9. LUCIFR
    LUCIFR
    from Seattle
    draw your circle and use air shear/nibbler
  10. sawzall
    sawzall
    those "cutting tools" are also called "a fly cutter" they are pretty dangerous and actually designed for wood.. (although I'm sure someone will say otherwise)
    I am actually working on a circle shear project.. but at 1/8 inch thick the aluminum is thicker than what my project will be able to cut .. (what grade alum is it?)
    as far as other methods.. there was a thread on here a few weeks ago about milling aluminum with a wood router..
    I would suggest you give this fixture a thought..
    it would require that you drill a small hole in the center (where the blue arrow is) you might possibly need only drill halfway through?) and that you use a wood router with a new carbide bit..
    IF YOU DO ATTEMPT THIS.. WEAR THE BEST SAFETY GL***ES, A SHEILD, GLOVES AND FOR GOD SAKE EAR PROTECTION. BECAUSE IT WILL BE LOUD..
  11. norton
    norton
    find a sheet metal fabrication shop with a "ring and circle shear". they can cut circles from around 2 inches diameter up to 5 feet or more depending on the depth of the throut. they leave a small dimple in the center equal to a mark from a center punch . long beach city college has one and I'm sure you could probably find one at a city college or trade school near you and they would probably cut a circle for you if you ask.
  12. Rand Man
    Rand Man
  13. mikflathead
    mikflathead
    Find someone with a Rotozip and make a comp*** type fixture and use a metal cutting end mill.
  14. Wild Turkey
    Wild Turkey
    The "fly cutter" is a real hazard at 3" -- 10" and it would be deadly.:eek:
    If you've got (or can borrow) a "nibbler" you could mount it to a rod as described and make a pretty good circle.
    Got a jig/saber saw? Get a metal cutting blade and hook the saw to a rod (make sure rod is aligned with front of blade)
    Or do your best with a set of tin snips and cut a circle about 1/2" smaller than the tank, make half-inch long cuts 1" apart around the circle and fold the tabs back, then cover with something.
    I'd consider some kind of split rubber tubing (maybe filled with silicone) or window gasket type material for the seal.
    Or find a steel ring the right size, put it under the Al and grab a hammer and cold chisel and start cutting!:cool:
    HTH
  15. sko_ford
    sko_ford
  16. ProEnfo
    ProEnfo
    from Motown
    ..and that would probably be me :D , these are basic metal working tools found around just about any machine shop and yes they can be used on wood also...
    CC
  17. sko_ford
    sko_ford
    those do look abit beter than the harbor freight one that i had try to brain me last summer but then i also was not using a drill press
  18. bills model a
    bills model a
    MSC sells the cutter you are looking for but you will need a milling machine to cut the large diameter you need
    But if you have a band saw and a wood working router and a 1/2" shank flush trim router but you can make a part with in +or- 10 thou.
    its not all that hard once you understand that you can cut aluminum like you do hard wood with a good cutter (carbide) and a little less rpms on the cutter and a little lube wd40 wooks good.
    make a wooden template and router a blank of 1/8 alum with a flush trim bit
    make sure its a 1/2" shank or it will over heat and make a mess
    pm me if you need the details
    Bill
