Technical 175 amp fuses???
Discussion in 'The Hokey Ass Message Board' started by Mike_B, Mar 12, 2023.
  1. Wow! Just WOW!
    Ben
  2. I've got a question. How many individual strands in the #10 wire you use in your harnesses?
    firstinsteele likes this.
  3. Mike_B
    Mike_B
    I actually ended up using a 60 amp mega fuse instead of fusible link to protect the 8 ga wire. It's mounted on the inside fender lip next to the battery.
    After reading AAW's post, it sounds like I should use a 100 amp fuse instead, due to the derating at under-hood temperatures. Correct? I still haven't done anything to protect the 10 ga panel feed wire
