Technical 18-7006 transmission question
Discussion in 'Traditional Hot Rods' started by soonrodder, Jun 28, 2020.
  1. soonrodder
    soonrodder
    from germany
    Hi all,
    I get an old ****** - 18-7006 instead the 4 speed truck transmission we wrote last time - yiiihaa.
    I know, not the best ****** to go, but there is a groove in the housing and I guess there are later gears in from 1938 a 48.
    The Cluster was sitting in a very stinky soup in the transmission case.
    Please see the picture in the attachment.
    It has a nice side and a not so nice side.
    Have I got to change it, or is this re-workable? and if yes, how?
    If not, I have to accept it.... :-(
    Perhaps someone has one of this, cause finding one here in germany is not sooo easy.
    thanks for all your opinions again.
  2. Mac VP
    Mac VP
    The ge****t is from a 1936 to 38 transmission. The shifter housing is 1932-35. The rear support appears to be the 1933-34 type. There could be an issue with the fit of the low/reverse shifter fork to the low/rev gear but I would have to see closer details to confirm that. The cluster gear has the appearance of being badly pitted. If this is the case, you should replace it. Good used 28 tooth cluster gears are in demand and getting harder to find. We do have the new reproduction gears available at this time.
    soonrodder and Hnstray like this.
  3. soonrodder
    soonrodder
    from germany
  4. Boneyard51
    Boneyard51
    That groove was probably due to a very loose bearing at some time in this transmissions past. It does not have the appearance of a machined groove for clearance for a larger gear.........but could be!
    Bones
    soonrodder likes this.
  5. soonrodder
    soonrodder
    from germany
    Great to hear you got repros, could you give me the correct number, so I could order that one?
    It is 28 24 18 14 teeth
    Thanks a lot in advance.
    ..also do you have the correct overhaul kit..? :)
  6. soonrodder
    soonrodder
    from germany
    autschn...[emoji33]
    Boneyard51 likes this.
