Technical 181 Stovebolt gasket question
Discussion in 'Traditional Hot Rods' started by Lizzard, Sep 14, 2021.
  1. Lizzard
    Lizzard
    A friend of mine has a 1933 Chevrolet Standard Mercury with a '34 Stovebolt engine (181cui).
    Now, he's needing new gaskets (for valve cover, oil pan etc) but he has some trouble to find a store/online shop.
    What do you recommend guys? btw, are these parts interchangeable with newer stovebolt engines?
    Thanks for helping my friend.
  2. Check out bestgasket.com Shows 1934 Standard 182 engine rebuild gasket set. RSU729
  3. Lizzard
    Lizzard
    Thanks. But 182 is confusing. It's actually a 181 engine. Anyway I'll give it a try.
  4. They show two listings- 1 for the 182 engine in 1933-34, and 1 for the Master 207 engine.
    Wikipedia shows the 181 engine as being in the 1935-36 Master, and does not mention a 182 engine anywhere, so I'm thinking that is the right one?
  5. Lizzard
    Lizzard
    I suppose 182 and 181 are the same.
  6. egads
    egads
    Olson's gasket's Port Orchard, Wa. 360-871-1207. Always have what I need at a decent price.
  7. Lizzard
    Lizzard
    Thank you. You've helped me a lot. Cheers!
