Projects 1920 t build
Discussion in 'The Hokey Ass Message Board' started by patrick english, Jan 27, 2013.
  1. patrick english
    patrick english
    from La puente
    Bord today,decided to put the body on the table and pretend..
    Also,quit smoking 3 days ago so I've been tring to keep busy.started tearing down the rocket.It was supposed to be a running engine,but im guessing it sat for too long.this one cylinder was rusted out.was seized up.
  2. Ford Mike
    Ford Mike
    I like where this build is going, I'm subscribed. That mol***es does an amazing job! I have one question though, what are you going to do with all of it when you are done cleaning all your parts? Keep up the progress, and congrats on kicking the cancer sticks!
  3. Rickybop
    Rickybop
    From what I've been told, the effectiveness of the mixture only lasts for about a month or so. Then you dump it...it's non toxic. I'll be using this method in the future...no warping or any other damage to the metal at all, and truly removes all the rust.
    Cool project!
  4. 226 flattie
    226 flattie
    from orange,ca
    Hey Patrick,
    Your off to a good start . I'm in orange not to far from you let me know if you could use help set up,you project.
  5. patrick english
    patrick english
    from La puente
    Yes i here its non toxic as well..Also,they feed this **** to farm animals so its most likely delicious.I was planning on pouring it in the gutter or on my lawn.I'm pretty white trash like that.
    But for the next round of stuff ill use those big 300 gallon containers.They have a valve on the bottom so draining will be easy.
    If anyone local wants one feel free to come get one.I paid $20 for both,but i thought i was getting one(my Spanish isn't so good).I just really don't need 2.
    I got that rocket engine freed up pretty easily with some pb blast.Only took me a few hours..lol.Im planning on doing a poor man rebuild.new rings gaskets and paint.
  6. patrick english
    patrick english
    from La puente
    Thanks!.I'm usually in the garage everyday till about 6.I could always use help..coulda used it today moving that engine..things frekin heavy!
  7. patrick english
    patrick english
    from La puente
    (Oh yeah,it works for over 2 months with a 5 to 1 ratio)
  8. patrick english
    patrick english
    from La puente
    Thanks bro!yeah today was ruff..fingernails chewed off.But its for a good cause though,i quit so ill have that $200 extra a month for hot rodding.
  9. thommoina33
    thommoina33
    Alliance Member
    from australia
    Subscribing to this, this is what the HAMB is all about
  10. patrick english
    patrick english
    from La puente
    Thanks mate!..I'm guna finish stripping the engine tomorrow and hopefully get some sanding discs and start sanding the frame rails and knocking out the rivets.I would have did the mol***es treatment to the frame rails too,but they dont fit in anything...less i dug a trench and lined it with tarp..
    (Those blue tarps **** by the way.If you're thinking about doing that.They leak)
  11. 60galaxieJJ
    60galaxieJJ
    comming along great.
    best of luck on quitting smoking!
  12. Looks great! Subscribed.
  13. patrick english
    patrick english
    from La puente
    Thanks guys.I had big plans for yesterday and today,but i got food poisoning.barfing and pooping all dam day..its been a ****ty week..lol
    But i cleaned up the cylinders and got the engine freed up.I was just that one piston that was stuck.Alll the other cylinder walls look really good.I'm just guna slap it back together and try to run it..I bet it'll run.
  14. Olderchild
    Olderchild
    from Ohio
    Patrick I would hope you dont just put gaskets on it and run it there is a lot of loose gunk in that lifter valley that will end up in the oil pan and kill your oil pump imho you should clean that up and drop the oil pan clean it and oil pump screen just my .02 . got my mol***es going this weak. And for gods sake's leave the cancer stick alone, my dumb *** wife did it till she has cancer now and still cant stop." its worse than cocaine"good luck with your build.
  15. patrick english
    patrick english
    from La puente
    oh yeah ill clean that **** out for sure.i meant i'll clean everything up without taking the whole thing apart.Then slap it back together..
    hell yeah,mol***es is the bomb.
    Smoking is gross for sure.sorry you're wife got cancer from it.
    Thanks!
  16. patrick english
    patrick english
    from La puente
    I got the rest of the body parts out today and cleaned them off.
    Did another pretend mock up today.
    This is my neighbor holding up what i would like to use for a windshield frame.Its a dodge or something non ford windshield frame upside down.My bud said it seems rat rodish,but everyone else i ask that doesn't know what a rat rod is says the same thing.."looks like he's mad"...What do you think?
  17. Olderchild
    Olderchild
    from Ohio
    I like it. It looks like it will have a permanent smile:):D i see things in a weird way.I have a question, what do put on the metal after you wash off the mol***es.
  18. patrick english
    patrick english
    from La puente
    Thanks!..well i was using oil,but that kinda ****s for welding..gotta clean it real good...But now what i do is wash the part with soap,water and baking soda.Then hit it with the wire brush.
  19. i've hear "Metal Prep" from POR15 is the **** to use after mol***es,keeps the rust off,easy to clean too..
  20. patrick english
    patrick english
    from La puente
    I herd that stuff works real nice..But im poor and baking soda and soap & water work for me.
    Here's an old brake light another hamber gave me.I think its from an old school bus.It says "old lamp co", Cincinnati Ohio on it.Gl*** lens.pretty neat.It was rusted solid too.
  21. leakyboatlouie
    leakyboatlouie
  22. patrick english
    patrick english
    from La puente
  23. so do you use a 5:1 ratio? what type of mol***es?
  24. Bcometfx
    Bcometfx
    from NC Indiana
    Love the windshield frame. Has a cool mean look.
  25. Waking The Dead
    Waking The Dead
    Def subscribed.
    I am very interested in the mol***ses as a rust remover. Can someone explain this more.
    what type, were do you get it, the ratio of mol***es and whatever you mix it with. Does it remove paint. I typically use air craft stripper but it makes a mess of the garage. T
  26. patrick english
    patrick english
    from La puente
    Yep about 5 to 1..Its not very scientific though.On my last batch my tank leaked about 15 gallons or more and i just filled it back up with water.Still working.Not leaking anymore though.
    Its called feed mol***es.You can buy it from feed stores.They usually ask you what its for.I guess potheads pour this stuff in they're soil?Anyways,The lady at my local feed store calls it liquid mol***es.
    It does not remove paint.only rust.And the cold weather slows the process.
    Theres a good thread on this already.That's where i got the idea.It's pretty simple though.Get a container,fill 1/5 with mol***es and the rest with water.let it sit for a few weeks(for heavy rust).
  27. patrick english
    patrick english
    from La puente
    Thanks dude!
  28. Waking The Dead
    Waking The Dead
    hey thanks patrick im gonna have to try it out. it seems like it worked out well for ya. love the build man.
  29. patrick english
    patrick english
    from La puente
    Yeah try it out.You cant really mess it up..unless you take the part out everyday to look at it..Thanks!More updates tomorrow!
  30. Olderchild
    Olderchild
    from Ohio
    Thanks for the help Patrick now all i have do is sneak mom's detergent and soda out of the house now:D It's amazing all you have to do guy's is type mol***es and rust up on internet and it's all over youTube
