Projects 1925 Dodge Roadster Speedster
Discussion in 'Traditional Hot Rods' started by Snedhead, Mar 25, 2018.
  1. Snedhead
    Snedhead
    Hey guys introduced myself a while ago and it's looking like I'm ready to get rolling now that my shop is cleaned up. I bought this car kind of on a whim and realized I need help. I have built 60s cars and have 20180215_115742.png 20171118_110104.png loved muscle cars since forever. This is my first entry into the traditional world and I just don't know anything. I don't even know the right words to search. This car was built in the 60s and been in storage since. I think it's too 60s hotrod on the front. How do I fix this? Or am I wrong and just building a hood and sides will fix it. I have a stock model a axle I'm going to send out to be dropped and ditch the tube axle. I'm not sure the year of the frame but it's ford. Wish I had a dodge grill but that is proving difficult to find. Let me know your thoughts.
  2. HOTRODPRIMER
    HOTRODPRIMER
    Actually,it's a pretty nice looking car,kinda got a trackster look going on,i really lie to boat tail look.
    I do agree with replacing the tube axle,especially with the split bones.HRP
  3. panheadguy
    panheadguy
    from S.E. WI
    I agree with HRP
  4. dodge35
    dodge35
    from kentucky
    I like it just like it is.
    Atwater Mike and Stogy like this.
  5. bondojunkie
    bondojunkie
    That thing is freakin cool! The axle and finned drums do look a bit too 60's to me.
    Cosmo50 and chryslerfan55 like this.
  6. exterminator
    exterminator
    I like it too!
  7. plym_46
    plym_46
    from central NY
  8. Snedhead
    Snedhead
    So you guys don't think I should move the radiator forward and put the grill shroud so that it covers the leaf spring mount? I think I am used to seeing so much less of the spring on some of these other cars that are "traditional" built in the 40s and 50s.
    Motor is just a stock 4 banger with a down draft early holley 2 barrel.
  9. Man, that car is cool. I could see a beam axle, yes. I wouldn’t bother hiding the mount, or anything else, for that matter. But that’s just me.
  10. rusty rocket
    rusty rocket
    How about a mopar double dip front axle? Post in the parts wanted for a dodge radiator shell. I'm sure someone out there would have one or a Kool little track nose would look right at home on it.
    flynbrian48, chryslerfan55 and Stogy like this.
  11. plym_46
    plym_46
    from central NY
    What's wrong with the tube axle?? Probably from a 35/6 Plymouth. Needs some lever friction or houdaille type dampers up front. If memory serves that has a combo starter generator, and odly enough is a 12 volt system. Does it still have the vacuum fuel pump? Big canister looking thing on the p*** side firewall.
  12. junkman8888
    junkman8888
    (1) Tube axles and split bones don't mix, so you're on the right track replacing the front axle with a dropped vintage beam axle.
    (2) Dump the Buick drums if you want to keep the wire wheels. Yes, I know you can adapt the two but the spacer required gives you an incredible (and dangerous) amount of scrub radius.
    (3)The boat tail. As a concept, I absolutely love it, at present, the execution leaves much to be desired. My advice: Replace the Dodge body with a '26 T cowl and doors, then remake the boat tail. My justification for this change is every other component of the car, (frame, engine, suspension) is vintage Ford, the replacement of the body would make the car less of a "mutt". Best of luck with your project.
    chryslerfan55 and trollst like this.
  13. flatheadgary
    flatheadgary
    from boron,ca
    i think you should try and get a '26/27 turtle back and take the boat tail off. it would go with the body better. you could sell the whole front axle with brakes, but keep the bones, for a good price to some street rodder, to off set the cost of a i beam axle and juice brakes. with the type of body you have the boat tail should be longer anyway.
  14. Snedhead
    Snedhead
    I just looked up this axle and now it is on my want last but probably a later upgrade. I will try the wanted section. Track nose might work but some reason I have yet to find one I like.
    It is setup with a modern alternator I need to downgrade that as well. The tube axle I'm pretty sure is a catalog order axle but from the 60s. Frowned upon if I want to be able to enter it into TROG.
  15. rogg49
    rogg49
    from michigan
    Did you pick this up in Ohio?
  16. Stogy
    Stogy
    Jalopy racer...as eluded...exposed springs were common...whats the history?
    No speedster backs but why not and maybe there were and if
    you can't live with the boat tail style back turtle deck it...
    Last pic has tube axle.
    Some of those racers were pretty sharp looking.
    Credit to Photographers, Owners
    Okie Pete and chryslerfan55 like this.
  17. waxhead
    waxhead
    from West Oz
    Love the boat tail, looks pretty cool how it is now
    Stogy likes this.
  18. rusty rocket
    rusty rocket
    I'm pretty sure the last pick is a mopar double dip.
    Stogy likes this.
  19. exterminator
    exterminator
    I love your car just the way it is and would not change anything much less than put a T body on it.:eek:
    RMR&C likes this.
  20. plym_46
    plym_46
    from central NY
    Keep the body! Lots of folks like ****rels. Putting more ford parts on it just makes it like most others. Start different stay different.
    thebearded1! and exterminator like this.
  21. Cosmo50
    Cosmo50
    That is one cool car. I would keep it the way it is, just get it street legal so you can drive it around.
    thebearded1! likes this.
  22. RMR&C
    RMR&C
    from NW Montana
    Really cool as is! Make it safe and go.
    Body appears to be early 20's Overland, not Dodge.
    thebearded1! and Atwater Mike like this.
  23. Atwater Mike
    Atwater Mike
    Yes, the axle is a 'double-dip'. But it's a mid '30s Chrysler, (proper) not a Dodge or Plymouth; Moot point, but the Chrysler dipped down in the center, where the Dodge/Plymouths dipped forward.
    This roadster was pictured in Mark Morton's 'Hop Up' magazine, third edition.
    The 'scheme' of this 'Boattail' roadster may be 'vague', but to simply change everything for the sake of conformity...Chrysler/Plymouth front axle would be great, but consider that the originals were semi-elliptic in design, and it binds up when used with split 'bones...
    A stock Ford wishbone could be subs***uted, with transverse leaf.
    Agree on finding or building a bulbous nose that would cover the 'bulldog' mount, just for aesthetics. A nice aluminum hood top would tie the cowl together nicely, and separate it from the rash of '27s that make up the majority.
    Just 'clean up what's here'. Ford spindles work on MoPar 'double dip' axles, just larger diameter king pins. Stainless steel bushings in the axle for Ford pins, or ream the Ford bushings to MoPar pin diameter.
    If using stock Ford wishbone, hanger bores must be fitted with good steel tubing bosses.
    Doane Spencer had a 'double dip' axle on his famous '32 Hiboy for a short time, one of many. That axle was more popular back then, I recall 4 drag cars that ran them at the San Jose drag strip ('Little Bonneville') in 1952-1955...
    Best thing, I've seen them at Turlock and one in the swap area of Eagle Field last year, they are still around. (found one on Craigslist, under an old trailer, $50 or best offer)
    Love that axle...but '37Kid had a Franklin axle awhile back...the Holy Grail!
    Every car I've ever built revolved around the front axle. The first was a '37 Ford V860 tube, man...I loved that axle.
  24. rusty rocket
    rusty rocket
  25. The boat tail has hard points in the what should be "fair" curves ,thats about all i would change. It looks like a lot of fun and bet it draws alot of attention being just what it is
  26. Snedhead
    Snedhead
    Alright so it sounds like swapping the axle is really the only mandatory thing. I'm going to work on cleaning up the rough weld work and try to get this thing rolling soon. I have more questions but will wait till I get to those problems. Thanks for all the replies guys.
  27. 62pan
    62pan
    Stogy likes this.
  28. Last edited: Mar 27, 2018
  29. dwollam
    dwollam
    Nice looking car but definitely not a Dodge Brothers body. I agree, probably Overland.
    Dave
  30. Doctorterry
    Doctorterry
    Such a cool car... I'd put the different dropped axle on it, powder coat all your suspension stuff black, paint the body, distressed leather interior, banjo steering wheel and perfecto! Maybe chopped windshield and lean it back. That's just me, just look at pictures and decide what you like
