Projects 1925 Model Tchev banger
Discussion in 'Traditional Hot Rods' started by Andrew Mccann, Aug 6, 2016.
  1. Outback
    Outback
    from NE Vic, Oz
    Very interesting, I've got an M type Vauxhall 14/40 engine & g'box put aside for my T roadster project & had been thinking about a Bull Nose Cowley radiator. That Oxford one looks great, will be a very interesting addition :D
    Lil'Alb and Six Ball like this.
  2. 282doorUK
    282doorUK
    Nice to see you back on this.
    No idea how high you're intending revving it, but I get scared around 3,000 (60 mph in top) with my '28 chevy beach racer.
    Unless you're planning to go a lot higher, maybe weaker valve springs might give the rockers an easier time and also act as rev limiters.
    Blackbob, Six Ball and Outback like this.
  3. Outback
    Outback
    from NE Vic, Oz
    It's a real balance isn't it! We recently put together an 20's French twin cam, valve Springs were very light - 40lbs valve open, we ended up with Carbon on the seats & valves not shutting after 50miles. We went to 95lbs, valve train worked as it should but the extra load was noticably higher.
  4. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    Nowhere beyond 3000 for sure, above that is daft without pressure oiling
    @Outback whats this French Twin cam we need to hear about.
  5. 282doorUK
    282doorUK
    It is, but I've never noticed valve bounce or had any problems with my prehistoric stock springs which are pretty weak.
  6. Outback
    Outback
    from NE Vic, Oz
    Salmson GS 1100cc will try to dig up a photo :D
    282doorUK and Six Ball like this.
  7. Six Ball
    Six Ball
    from Nevada
    Very cool honeycomb I've never seen one like that before.
  8. 282doorUK
    282doorUK
    I have a huge jump up 2rd to top, I found a small low revs points activated rev counter so I could see when to ****** it into top, worth having or else I would never dare hang on to second for that long.
    My engine is stock and in need of refreshing, max power at 2,200 revs, but the soft sand just kills it if I change up then.
    I get the 3,000 revs being safe from this chart from the on line 1928 Chevy specs book.
  9. Gary Addcox
    Gary Addcox
    If you are in the market to sell the 153, I would like to have first refusal. I put one in my '34 Ford in '72 and it was fun.
    Outback and Six Ball like this.
  10. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    I could really use a set or 4 standard 1:1 rockers if anyone has any, I have 4 here
    Six Ball likes this.
  11. Six Ball
    Six Ball
    from Nevada
    Still chipping away at i† and when it goes together it'll have the built 153, but I have been gathering parts & information for an early build. Just got a Genuine Chevrolet Parts book for four cylinder models from 1940 today. Good illustrations and information. Putting this one in a T is really cool.
    Outback likes this.
  12. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    Slicing the pan to fit the timing cover and fitting the oil lines
    Deutscher, RMR&C, Blackbob and 5 others like this.
  13. Blackbob
    Blackbob
    Still got all the Chevy parts and Olds head, just had to put it into storage for a while as I had to go back into full time work.. hoping to get back on it soon
  14. Outback
    Outback
    from NE Vic, Oz
    So glad you are still about, I understand how projects blow out or get put on the back burner. There's so many cool projects around here that just fall away. Looking forward to seeing your updates when they happen
  15. Six Ball
    Six Ball
    from Nevada
    I saw this on eBay. It sorta fits.
    Blackbob, Deutscher, Outback and 3 others like this.
