1927 chevy. The next build.
Discussion in 'The Hokey Ass Message Board' started by Ghost28, Apr 9, 2010.
  1. Everything looks great John. I still have to figure out my window mechanism mounting. Yours looks great, clean and simple!
  2. Ghost28
    Ghost28
    I have extra window mechanism and some handles if ya need them.
  3. Thank you for the offer. I have them, I just have not addressed it yet. :)
  4. mink
    mink
    from CT
  5. rustydusty
    rustydusty
    Looking great! You are a glutton for punishment with the early Chevy builds. I'm on my 2nd with the '29.(the first was a '34 3-window). I would like to turn mine into a sedan delivery, but the kids would not be able to see out!
  6. Ghost28
    Ghost28
    Just put dark tinted window on the rear sides, and make it into a rear door flower car like they had back in the day. The kids could see out using jump seats and you could have your delivery. I am going to build a 26 buick flower car next.
  7. Okie Pete
    Okie Pete
    Thanks for showing us your progress and pictures.
  8. Ghost28
    Ghost28
    I ordered a radiator and found out even with a 5 inch firewall set back, I did not have enough room for a fan :eek:, damn short 4 cylinder 27 chevy hoods. I decided the only option to correct this OOOPS, was to stretch the previously modified 29 chevy grille shell by about 2 inches and hope it wont look too bad, all in all it came out pretty good and it gives it a truck look, so I continued on and finished up the lower steel work on the shell. now I can make my radiator mounts, and modify my headlight bar.
  9. 41 Dave
    41 Dave
    John, Love the progress on your '27 to make room for a fan. I am not a big fan (no pun intended . . . .) of electric fans but may be you only option. I much prefer a belt driven fan.
  10. careyohio
    careyohio
    I really like this build !!!
    Carey
  11. hasty
    hasty
    Nice work. Keep the updates coming please
  12. Ghost28
    Ghost28
    Well I got the radiator mounted, it is a 32 ford style cut down 5 inches. I used some old body structure mounts from the 27 for the lower mount fabrication, and a 33 chevy interior grille support modified for the upper mount. I guess I am a recycler after all. I have 2 inches exactly for a fan, and it will have to be electric other wise the lower radiator hose will have to be sacrificed on every startup :( I still have a 16th inch gap for a grille insert up front this will hide and protect the aluminum radiator a little bit.
  13. 40StudeDude
    40StudeDude
    Just cut a small notch in the radiator hose...use JB Weld, fiberglas bondo, black silicone or that black 3M stuff in a tube...you're sure going to a lot of work for an old car...!!!
    R-
  14. Ghost28
    Ghost28
    After I got the radiator mounted. I decided to figure out the guage area of the dash. This car will have ac and heat cuz I like to be comfortable. And there is not much room under the dash for the ac unit, and the back side of the guages in the same space. I made a guage holder out of 18 guage steel, and wrapped it with a 1 inch steel band welded from the inside and then ground the outside edge. This will cover the old guage holes and pull the guages out far enough to clear the ac unit.
  15. Okie Pete
    Okie Pete
    Nice shape and it flows with the rest of the dash.
  16. Ghost28
    Ghost28
    Thanks. It has been one of my favorites.
    Thanks. I like posting the updates. It gives me a reason to keep working on it, and fires me up.
    Thanks. the dashes on these cars are so flat in some areas, sometimes they need a little customizing. Within reason of course
  17. Ghost28
    Ghost28
    I wanted to run a mechanical fan but the space did not allow for it, so electric will be the ticket. Thanks
  18. Ghost28
    Ghost28
    Well I decided the mechanical fan just wont work, but a 16 inch electric will.:( I had exactly 2 inches from the radiator to the waterpump pully bolts, but I needed a shroud of some sorts, and a way to mount the fan to the radiator, in building the shroud I lost 1/2 inch of space. To get the 1/2 inch back, I moved the grille forward 1/2 inch and moved the hood forward, along with the aluminum belt line trim on the cowl. It's tight but I think it will work.
  19. 41 Dave
    41 Dave
    John, Car is coming along great. Looking forward to your progress to getting this rod on the Highway. Being in Colorado, hope you and the '27 make several fishing trips.
    Dave
  20. nailhead terry
    nailhead terry
    Wow that is a lot of work if we had fords we could buy it all done for us ! Car looks good!!
  21. Jim Lohman
    Jim Lohman
    from Colorado
    No kidding! What happened to all the Chevy dies, I need steel fenders...
    It's being able to talk to master fabricators like John that keeps me going somedays!
  22. Ghost28
    Ghost28
    Thanks guys. I am gonna take this car along on some fishing trips. Been kinda side lined on the 27 because of another car commitment, but hope to be back on it soon.
    Jim We will find some fenders for ya.
  23. 40StudeDude
    40StudeDude
    When...??? Is this another one of your fishing stories...???
    R-
  24. Ghost28
    Ghost28
    Aww cmon. Some ones gotta slay the fish might as well be me.
  25. 40StudeDude
    40StudeDude
    Actually I wanted to know the date, like WHAT day/month, you're going to take this car on a fishing trip...I mean this summer...next summer, before December, 2012, when the world is going to end...??? WHEN...???
    R-
  26. Ghost28
    Ghost28
    I haven't given up on this summer yet. If I can get the 28 body back on it's ch***is, then I will have room to blow the 27 apart for it's final push and hopefully get er done before the world ends.:eek:
  27. HotRodBen1987
    HotRodBen1987
    Looks like it's coming together nicely. That gauge holder is cool and looks like it'll do just what you need it to. So when you gonna be driving this thing, it sure has taken long enough ;)
  28. 40StudeDude
    40StudeDude
    C/mon John, that's about as non-committal as you can get...
    I sure get tired of you showing up at every event in that rat-trap of a truck you got...what's it been now, three years since you've had a rod on the road...???
    It's time...quit milkin' it...!!!
    R-
  29. Ghost28
    Ghost28
    Rat trap of a truck. I'll have you know that is a quality vehicle and what else would everyone lean on at the events.
    I am trying to Get a rod on the road. JEEZ.
  30. 40StudeDude
    40StudeDude
    Sooooooooo, where was that rat trap (and YOU) last nite...??? You missed a great cruise...I couldn't find anything to lean on...
    R-
