Ford Tudor hot rod. fresh paint top and bottom, the undercarriage and frame is done with POR 15 wich is the next best thing to powder coat tough stuff. The body is done in satin black enamel with gold accents. The Hand built spiderweb grill that is the radiator support eliminating the wishbone support that gets in the way when your working on it form meets function. 350/350 combo. Demon 750 carb, torker 2 aluminum intake, aluminum roller rockers, fresh accel spark plugs, wires, cap and rotor, msd coil, nice lumpy cam, customized and ceramicoated lakey style headers. She runs like a rapped ape no issues. The Custom br*** knuckle motor plate keeps all that power from snapping motor mounts, form again meets function. Ford 9 inch posi rear end with ladder bar suspension hooks up and launches straight. New Drilled and slotted disk brakes in the rear, 67 mustang drum brakes in front. Thanks.
