Projects 1928 Ford Tudor
Discussion in 'Traditional Hot Rods' started by 28TudorAZ, Dec 29, 2016.
  1. loudbang
    Nice sounding lope :)
    els likes this.
  2. 28TudorAZ
    28TudorAZ
    Lots!!! Lower the front end, tires, rag top, finish interior, and paint it. I also think I am going to do an AOD, and if so I want to put a metal floor in it. Actually the next thing I am working on is the brakes. The master cylinder is not correct for the booster and the tires are locking up after I drive it so a new one should be her on Friday and the new proportioning valve is leaking so I have a replacement from Summit that will get put in this weekend with the new master cylinder.
    It got it. That was right after I got it started and moved out of the garage.
    Yes just what I was going for and the extra 150HP. I went from about 150-160HP to 310-330HP. Drives like a different car.
  3. sloppy jalopies
    sloppy jalopies
    I have used AODs ... behind a flattie, 302 and 351... they used 350;1 or 411;1 rearends, were great on the highway but they shift in and out of OD at the crest of every hill...
    lost OD in my '89 LTD... I left it in OD all the time... the shifting in and out so often ruined the way it shifted up... if I leave it in drive = no problem...
    if you use an AOD don't shift to OD till you get on the pike... gas is cheap...
  4. 28TudorAZ
    28TudorAZ
    Yeah I plan on an AOD in probably a year from now. I want a few other things done before I head down that route. Here is a little run the other day.
    I was adjusting the emergency brakes and noticed the axle bearing is leaking. I guess that is next.
    lothiandon1940 and loudbang like this.
  5. 28TudorAZ
    28TudorAZ
    Also looking to get input on whether to put the hood on...or keep it off.. or do a partial hood.
  6. Schwanke Engines
    Schwanke Engines
    28TudorAZ and loudbang like this.
  7. Dean Lowe
    Dean Lowe
    Unless you have a big nasty motor to show off, put the hood on it. The 28/29 cowl is a thing of beauty and the hood carries the line right down to the radiator shell.
  8. loudbang
    Love the sound of FORD power in the morning.
    28TudorAZ likes this.
  9. Tim
    Tim
    from KCMO
    I vote all of thee above. I've collecting bits and pieces so we can run several different hood set ups. But most of the time a stock full hood
  10. 28TudorAZ
    28TudorAZ
    This is what I want to car to look like after its painted. My photoshop on this one was terrible but you get the idea. That is why I have been floating the idea of the top of the hood.
    rfraze, Tim, Dean Lowe and 2 others like this.
  11. Schwanke Engines
    Schwanke Engines
  12. Dean Lowe
    Dean Lowe
    Yes, at least run the hood top. That Photoshop illustrates my point perfectly.
    lothiandon1940, verde742 and loudbang like this.
  13. Be careful of those rear radius rods, does it have an upper torque arm. The casting have been known to crack or break without the torque arm especially with the powerful V8.
    anothercarguy and loudbang like this.
  14. sloppy jalopies
    sloppy jalopies
    I ran '35 pick up truck hood sides only on my '33 fiver...
    IMO....
    donar hood sides are easy to lengthen, trim to match the cowl, match the frame's top edge and they can easily be bolted to the cowl and grill sides...
    lengthening of a hood top is for the pros...
  15. What he said....if you're working around the rear end next.
    Nice fix up of an old build btw.
  16. 28TudorAZ
    28TudorAZ
    What do you see wrong with the rear end setup? Please explain further.
  17. 28TudorAZ and loudbang like this.
  18. 28TudorAZ
    28TudorAZ
    I will keep an eye on it. Its definitely not the original trailing arms. Definitely thicker. Not sure what they are from. It has been on there since the 80's with the V8.
  19. 28TudorAZ
    28TudorAZ
  20. Schwanke Engines
    Schwanke Engines
    Now your talking.
  21. 28TudorAZ
    28TudorAZ
    Well got it installed. Waiting on a steering arm which should be delivered tomorrow. I actually ended up going back to a regular spring vs reverse eye because I thought it was too low. Now the back needs to come down. I can only come down an inch though. 19284inchdrop.jpg 19284inchdrop2.jpg
  22. Schwanke Engines
    Schwanke Engines
    There is no such thing as too low. If you tuck the rear wheels under the fenders you should be able to lower it more.
    Sent from my XT1585 using The H.A.M.B. mobile app
    CapeCodBob likes this.
  23. dubnutty
    dubnutty
    Where did you pick up that front axle? I'm looking into putting one in my '29 Woody but getting confused on width and spring location. Great looking ride.
  24. 28TudorAZ
    28TudorAZ
    It didnt look right with the back end up so high. Its going to be big money to get the tires tucked in because the axle housing will need to be shortened. I figure if I am in there I want to switch to coil overs, do a 4 link setup, and rebuild the rear end.
    I picked up the dropped axle at SoCal. They only have the reverse eyed springs so I picked the matching regular spring up at Speedway. Just make sure you buy the matching spring to axle and you should be all set. This was a 46" which really brought the wheels in.
  25. NashRodMan
    NashRodMan
    This car gets better and better with each step you take!!
  26. 2935ford
    2935ford
    2x
  27. 28TudorAZ
    28TudorAZ
    Here is a better picture.
  28. Schwanke Engines
    Schwanke Engines
  29. Schwanke Engines
    Schwanke Engines
    I'd personally prefer more rake, but definitely better with the drop axle.
  30. redo32
    redo32
    Looking GOOD!! A little bit bigger rear tire and it will be just right. Out here in western Oregon it rains too much to even think about a sliding roof, I bet it leaks. You've got nothing but sunshine and it's your car so carry on, but I like it the way it is.
    bymanr and 28TudorAZ like this.
