Projects 1928 Model A build
Discussion in 'The Hokey Ass Message Board' started by Bigsmoothy, Oct 11, 2015.
  1. Bigsmoothy
    Bigsmoothy
    No noise from anywhere! I let the clutch pedal out with the shifter in any position and nothing happens. Both axle keys are intact as well.
    I have not taken the inspection off the top of the trans yet. I'm going to do that tonight I think.
  2. AmishMike
    AmishMike
    Think I would jack up the rear, brace the car well. Try turning the wheels by hand, any noises in the rear? Crawl under & turn driveshaft -noises? Start while in the air. Something broken or locked up somewhere.
  3. Bigsmoothy
    Bigsmoothy
    So..... I pulled the left rear hub off tonight and low and behold.. No axle key in the slot. So I got looking through the box of extra parts that came with the car and found one! Guess what?! The car moves now.
    The clutch still won't disengage but at least the car moves when I step on the starter but I still haven't pulled the top cover off the trans yet so we'll see what's going on in there when I do that.
    MOTOV8N likes this.
  4. MOTOV8N
    MOTOV8N
    from Manitoba
    Nice to hear the progress ahead, even if it is under the power of the starter motor! Keep up the good work man! ... Such a cool car
    Bigsmoothy likes this.
  5. Bigsmoothy
    Bigsmoothy
    Thanks! I'm excited to get it driving!
  6. MOTOV8N
    MOTOV8N
    from Manitoba
    That engine sounds so smooth, man...i can't wait till You are mobile!! Keep up the good work!!
  7. Bigsmoothy
    Bigsmoothy
    Thanks! Me too!
  8. Bigsmoothy
    Bigsmoothy
    I pulled the drain plug on the transmission last night, some fluid came out but the rest was this.
  9. Bigsmoothy
    Bigsmoothy
    I got the cover pretty clean now so I just have to disconnect the parking brake lever and remove the bolts around the cover to take it off.
