Projects 1928 rpu
Discussion in 'Traditional Hot Rods' started by Tedders, Feb 28, 2014.
  1. Tedders
    Tedders
    Found a brake set, awesome help from fellow HAMBER Denis, found an article here that's a total step by step..thank you HAMB. I am using the stock clutch and so need to figure out what master cylinder will work best and how to hook it up...keep here the aftermarket stuff is junk so any suggestions are welcome.
    Finished painting the box..
  2. jmiller1918
    jmiller1918
    from Tulsa, OK
    Will be interested in how you handle/like the conversion to hydraulics, I'm still clinging to the thought of staying with mechanicals. Good luck and your sheet metal is looking good!
  3. Tedders
    Tedders
    Looking for information on having my flywheel lightened. The normally links keep send me in circles
  4. Tedders
    Tedders
    Slow progress
  5. Tedders
    Tedders
    Front
  6. OFT
    OFT
    Been spending time on the sedan next to rpu? Looks like your making nice progress.
    Earl
  7. Tedders
    Tedders
    ok seasons over..time to get back at it…turning 40 next year s this needs to be done.
    currently she is in pieces, frames blasted and painted, wheels are done, engines out and going to get cleaning and checked out..nothing much happing to it. single down draft and a higher compression head 6.1.1 and a new distributor from a jamb member
    i need drum brakes to work with the stock spindles, anyone who has then to sell let me know or i am going to have to buy the kit and she's expensive..
    then order a front axel from joe with just a 3 inch drop as i don't want her to low, reverse eye on both ends..
    still debating ******..open to suggestions
  8. Tedders
    Tedders
    I have a few cracks in the firewall located around the hood supports at the top, very small was wondering best way to repair?
  9. Tedders
    Tedders
    Time to get this build back on track
  10. Tedders
    Tedders
    Ok so after a far to long break due to moving, losing the garage to an apartment etc etc I should be able to start again next week.
    Update
    Engine:
    Engine is at a local builder for tear down, see what kinda shape she is in. Once the condition is known I will go from there with the rebuild. If the Babbitt is in good shape, I will go with a low compression head 5.1 get it cleaned up, paint it and call it a day. I have a new distributor from Bubba, reds headers to dual outlet, single down draft intake, 97 stromberg (will use very small jet). If I have to put bearings in then I will go with a higher head comp 6.1
    Frame:
    Blasted, painted, done
    Body:
    Body and truck bed are off blasted and primed, door has dents from where it was pushed into the spare on the fender will have to fix that
    ******: using stock ******, had to replace bearing etc cost $35 from snyders, blasted painted done
    Brakes:
    Picked up some 40's backing plates for the rear, need drums, bought some 50's f100 front drum brakes. Have to order bearing adapters, and 28-48 spindles
    Wheels:
    16 wire, 4.5 front 7.5 back, blasted painted done , need to order adapters that will support the wire wheels on drums
    Front:
    Pulling leaf sprint to get it reversed at local shop, ordered 2 1/2 model a drop axle from Joe, front wish bones, leaf all need blasting and paint
    Rear:
    Have to pull axle and replace seals, pull spring and get it reversed, axle is blasted and painted, been emptied have to order oil
    Then figure out brake lines, figure out what I'm doing with master cylinder as I will using stock ******, figure out my 2 inch chopped windshield posts, bought from speedway but fit like ****, figure out seating position..and everything else that will come up..lol
    Will do my best to keep this updated as its overwhelming at the moment..good knowledgable friend says it's easy once you get going...hope so
    ImageUploadedByH.A.M.B.1414604722.026528.jpg ImageUploadedByH.A.M.B.1414604742.771309.jpg ImageUploadedByH.A.M.B.1414604759.219456.jpg
  11. Tedders
    Tedders
  12. Tedders
    Tedders
  13. Good to see progress on this one again!
  14. phil
    phil
    Looking good!
  15. OFT
    OFT
    Good to see your progress.
    Thanks for the update!!!!!
    Earl
  16. slv63
    slv63
    Keep it up!
  17. Tedders
    Tedders
    Got some news about the engine today, few replacements but overall looks good. The Babbitt is in good shape but since I'm in deep anyway may replace with bearings so I can use a high comp head. Any suggestions on size, what works better then others
  18. Tedders
    Tedders
    does anyone have a blueprint for lack of a better term that I can take to a machine shop to alter my rear backing plates?
  19. Soviet
    Soviet
  20. Tedders
    Tedders
  21. Tedders
    Tedders
    Some updated pics should be up and running in a few months ImageUploadedByH.A.M.B.1432498939.001506.jpg ImageUploadedByH.A.M.B.1432499007.371304.jpg
    waxhead, kidcampbell71 and Jet96 like this.
  22. Tedders
    Tedders
    Update pics
    Okie Pete and slv63 like this.
  23. Tedders
    Tedders
    Mock up
  24. waxhead
    waxhead
    from West Oz
    Looking good.
  25. Tedders
    Tedders
    Engine finished pick it up Monday
  26. waxhead
    waxhead
    from West Oz
    Good news. Post some pics when you get it back.
  27. Tedders
    Tedders
    Looking for some ideas on running my exhaust for model a roadster pick up. I'm using reds headers, runs into duals.
    Anyone using this set up let me know and pics would be great. The rpu is fender less
  28. Tedders
    Tedders
    I would like the shocks to be angled out more but if I switch the bottom mount it won't clear the steering...suggestions ImageUploadedByH.A.M.B.1434926898.844857.jpg ImageUploadedByH.A.M.B.1434926916.667895.jpg
  29. Tedders
    Tedders
    Realize once engine is in the weight will push down but will not change angle much
  30. Tedders
    Tedders
    Engine is in, as mentioned I would have liked to have the shocks angled more but then they would be in the way of the steering.
    With the engine weight on the front end the shocks are about 16inches apart.
    Have a look let me know if you have any suggest? Observations?
    ImageUploadedByH.A.M.B.1435525410.960515.jpg ImageUploadedByH.A.M.B.1435525426.706127.jpg
