1929 Ford Model A Roadster
Discussion in 'Cars For Sale' started by HerMink, May 30, 2020.
  1. HerMink
    HerMink
    City: Indianapolis
    State: Indiana
    Price: 39,800
    1F4B2698-BBB3-4A10-8DAF-74648D1B33C1.jpeg A77ACD03-A75E-4E0B-A2D2-0B8EF2652C2E.jpeg Testing the waters on my 1929 Ford Model A Roadster. This thing is as close to a brand new, turn-key, Model A that you can get. This is a finished car, that has had countless hours of labor and high attention to detail put into it over the course of a two-year build.
    The body is an all-steel new body from Brookville Roadster - the absolute best and safest reproduction body you can buy. The ch***is is a ‘32 Ford - completely boxed, seamless, that looks closer to artwork than a car frame.
    ***led as a 1929 Ford Model A
    Valid registration in the state of Indiana
    If you have built one of these cars, you know that getting the paperwork is one of the hardest tasks.
    Everything on this car was either painted, chromed or powder coated. The drivetrain was been worked and sprayed just like you would the exterior of a car. Same goes for the underbody, and the inside of the body - everything is painted, clear coated, and as clean as the exterior paint. This car was built to drive and have fun but could have mirrors put underneath of it at a car show as well.
    We didn’t build this car to just to sell it. We built it as good and safe as we could knowing that my family would be in it.
    Body Specs:
    Brookville Roadster Body; body was ***embled by Brookville Roadster.
    Paint - Toyota Sunset Bronze Mica; painted by Von Dust of Cooper’s.
    100 Louvered Trunk Deck
    1932 Ford Grille (Chopped 2”)
    Stainless Grille Insert
    1932 Style Windsheild
    Windsheild/Stanchions chopped over 5”
    1950 Pontiac Taillights
    Guide Headlamp Asemblies
    Granite Casting Rear Plate Light
    Ch***is Specs:
    Brookville Roadster ‘32 Ford Rails
    Pretty much all of the steering/suspension is SoCal including 4” Drop Axle, Front Leaf, Spindles, Rods, Hairpins, etc.
    Brakes are pretty much all Wilwood components - front discs, calipers, Rear drums, all lines are polished stainless steel.
    1940 Ford wheels, 16” in the front, 18” in the rear. Coker Firestone tires with less than 500 miles. 1941 Ford Hubcaps.
    Drivetrain Specs:
    Freshly built 383ci striker SBC engine. I got this as a new ***embled short block so I don’t know the exact specs of everything. I do know the cam sounds incredible, it’s 4-bolt engine and the roller rockers appeared to be made by Harland Sharpe.
    Rochester 2G TriPower Carb Setup, all three are functional and all lines are stainless including under the car.
    Offenhauser Intake Manifold
    Offenhauser Valve Covers
    Pertronix Distributor / Coil
    GearDrive Headers
    PowerGen Alternator
    Walker Z Radiator
    Transmission is freshly built TH350 Auto
    Driveshaft was custom made by Charlie Patterson
    Ford 9” Rear Axle; 3.50 Gears
    Custom Bench Seat by Coverall Customs
    ‘32 Ford Dash
    Stewart Warner Gauges
    Brian B*** Kustom Fuse Block
    18 Gallon Fuel Tank
    Way to much to list.
    Car located in Avon, Indiana
    Curb Weight: 2,160 pounds.
    EST HP: 400ish?
    I will still continue to cruise this car until it sales, current odometer is at about 200 miles - I figure I put on about 500 miles shaking it down before the odometer was hooked up.
    Serious inquires only. Price is pretty firm.
    Call or text Matt at 317-945-5849
    4313B163-2797-496B-9CB4-3F22CE9B66DD.jpeg 39008B6B-7643-4402-9C45-6F73F7FCDB1B.jpeg B9D8FCD3-81CA-40CE-B0F3-B558F46665CC.jpeg 892CCE7C-F09F-43A0-8CF2-3ABF560C95F1.jpeg BD409FA7-E183-4E13-87AE-B40A473159EF.jpeg A339863C-24C2-4101-9EF5-3CB68FB91924.jpeg AB685406-626E-4701-8853-73E784A5EC19.jpeg
    bonesy, jimmysweden, GonzoMN and 6 others like this.
  2. HerMink
    HerMink
    Roadster weather today.
  3. HerMink
    HerMink
    Stash31 likes this.
  4. HerMink
    HerMink
  5. HerMink
    HerMink
  6. HerMink
    HerMink
  7. HerMink
    HerMink
