Projects 1929 Model A Roadster
Discussion in 'Traditional Hot Rods' started by jjsound, Dec 12, 2021.
  1. dsiddons
    dsiddons
    from Indiana
    Looks like mine. Can we see the interior? Some bias tires would be cool.
  2. jjsound
    jjsound
    Yeah, I’ll definitely grab some interior shots when I’m around. It’s old chill tuck and roll.
    Bias ply tires will be killer.
    dsiddons likes this.
  3. jjsound
    jjsound
    New header doesn’t clear this gearbox. Any thoughts on an efficient solution? Relocate? Replace?
  4. dsiddons
    dsiddons
    from Indiana
    Send it back go with lake pipes? Speedway sells a cheap kit you weld it .
  5. dmar836
    dmar836
    Waiting for those interior pics!
    Probably out driving it too much to post. ;)
  6. jjsound
    jjsound
    Ha! Sorry, brother. I’m not on the HAMB like I was prior to my Facebook addiction.
  7. jjsound
    jjsound
    These are from the listing last year, nothing has changed.
    87154400-F6A5-45BF-BA5B-EE79F87B4A4E.jpeg 8C005D7D-D910-4D21-A5A1-41682F1B2043.jpeg E4F7B5E8-982C-4B49-B7BD-FC623803A005.jpeg 6A35F9C9-67F2-4FAE-908C-0354051F5774.jpeg
    Dedsoto likes this.
  8. dmar836
    dmar836
    Cool. Thanks! FB will make you crazy!
  9. jjsound
    jjsound
    Ugh, preach.
  10. jjsound
    jjsound
    The dog and I made a burger run earlier this week. The weather has been perfect lately in Wisconsin. 294680925_10160049071229292_7319884148137254218_n.jpg
  11. Atwater Mike
    Atwater Mike
    Nice li'l A-V8! The zerk fitting in the steering box fill plug was probably installed to use grease, yes.
    Reason? The old 90wt. gear oil will run out past the sector shaft seal if a header is too close! (ask me how I know)
    All flathead Ford/Merc V8s have 7/16" std. bolts on front exhaust ports, the others are 3/8" std.
    As mentioned above, the reason was because the earlier exhaust head pipes mounted on to the front 2 bolts, sandwiching the exhaust manifold on the front flanges.
    Good info above on the stainless bolt specs!
