Projects 1929 Roadster Build “the marauder”
Discussion in 'The Hokey Ass Message Board' started by rgrhoward, Jun 11, 2022.
  1. alchemy
    alchemy
    I'd call the spring manufacturer and ask the perch width for a Model A roadster. If it's made to custom specs, they are the only ones who would know the distance required.
    chryslerfan55 and brady1929 like this.
  2. rgrhoward
    rgrhoward
    That's what i ended up doing. Told me 44" so that's how far I spaced my mount. Don't know why I didn't think of that before.
  3. It was great having you stop by the shop man. That QC looks great mocked up in that ch***is. Boling Brothers make a nice frame. We'll be watching this thread, but hit us up if we can answer any questions about that rear along the way.
  4. rgrhoward
    rgrhoward
    Got some more mock-up done.
    Does this gap look right? Between the body and frame. Seems excessive, this is my first model a build.
    2AFC1E18-5A11-4326-99E7-06DE64DCFA87.jpeg F67FD89B-8829-41B2-902B-F500AF2BB5E8.jpeg FFD1EDEF-CD4D-41EC-A858-35979CE58FE4.jpeg 123E8DCE-E607-4F78-9473-F08BB1DC8F65.jpeg
  5. j ripper
    j ripper
    from napa ca.
    What does it look like in the trunk area? I’m pretty certain you’ll need to cut and modify subrails, but I’m not versed in how those are done from Brookville. Or just lopping off the ears of the A style crossmember? Does Boling make their frames narrower in the rear to fit between subrails so no modification is needed?
    looking closer at photos. Removing the outboard ears of crossmember should do it. Then the rear mounts should land right down in your wood block. Again, not versed on these products, but that’s what I see.
  6. rgrhoward
    rgrhoward
    I did some t******* to the a crossmember and the sub rail.
    getting better.
    C695BE2D-80E9-468F-92C2-1CB237717DD8.jpeg FCE0ABCE-84BF-4864-8A9A-D2911CB8A306.jpeg 9A5987CC-FDF4-42A2-B887-AC8A6237FAA0.jpeg C69591E2-9926-4582-AA41-1F6142B97A87.jpeg D2990F04-2228-430E-ABD6-52983C307ACC.jpeg 5D5A70F1-546D-43D4-B9DF-D4D2FD3A8667.jpeg
  7. alchemy
    alchemy
    Still needs more. I'd make the bottom of the body parallel to the frame rails under there.
    Okie Pete, Just Gary and rgrhoward like this.
  8. rgrhoward
    rgrhoward
    For sure, I ran out of cut off wheels. Looks like im going to cut down the rear wood blocks also.
  9. rgrhoward
    rgrhoward
    AE3239A7-5E11-4AF5-A0B3-DDDA5F642A54.jpeg 7E6F056B-739B-4E4A-BFF8-E5D56CCF06C4.jpeg C4D1825E-3B20-48E5-AAB6-F1EBC64FB295.jpeg Ok, some more t******* and I’m happy. Little more mock up also. Took 2” out the bottom of this grill shell, think 2 more will do it.
  10. wheeltramp brian
    wheeltramp brian
    Looking good man
    rgrhoward likes this.
  11. rgrhoward
    rgrhoward
    18FAFB4F-BC8D-4CDD-B7D0-F1FD37D7E039.jpeg 469680A6-0339-449C-9B10-4614FA214C43.jpeg 8157CF06-71AC-4A48-90C6-FDE834AFB686.jpeg Got some more mock-up done.
  12. ClutchDumpinDan
    ClutchDumpinDan
    Always exciting when they roll! Looking great.
  13. Hitchhiker
    Hitchhiker
    Looking great!
  14. brady1929
    brady1929
    Looks amazing. Any tips on where I can find an original model a roadster body?
    lothiandon1940 likes this.
  15. rgrhoward
    rgrhoward
    Do what I did. Scour the internet for months and months and don’t see anything. Then just order a brookville, after that original bodies will be all over the place for sale at great prices. Maybe that’s just how it works for me.
    But seriously, join some Facebook model a groups. They do pop up.
  16. rgrhoward
    rgrhoward
    5113F26C-0287-4E61-965F-F51B47A43BB8.jpeg 10481C2D-59C6-4C4B-BF30-ECF1D3CE9877.jpeg C8C45BC7-B907-4119-A333-1373B1F733A6.jpeg Sitting on its own rubber for the first time.
    also, I have taken 3” out of this grill shell. I feel like it still needs a tad bit more removed. I can always shim the radiator up a little.
    thoughts?
  17. Just Gary
    Just Gary
    I agree but not too much. Maybe 1/2" or 3/4".
    Can you roll it outside & take pictures from 30 or 40 feet away?
  18. rgrhoward
    rgrhoward
    I’m going to try that tomorrow.
    RAT "T" and Just Gary like this.
  19. Aaron D.
    Aaron D.
    If you put your hood on, the panel line between the hood and cowl will tell you if the height of the grill shell is to high or to low.
    chryslerfan55 and rgrhoward like this.
  20. rgrhoward
    rgrhoward
  21. Fitnessguy
    Fitnessguy
    Nice build so far brother. Brings back lots of memories on my coupe build. Good that you're asking questions. that's how you learn. Lots of good guys on here that are more than willing to help with their knowledge. Will be following.
  22. ModelAMitch
    ModelAMitch
    Great job so far, Im really enjoying watching this come together.
    Next time you make a cut on the grill shell, could you maybe take a photo looking inside the shell at where the cuts are being made? Im trying to visualize.
    Thank you!
  23. rgrhoward
    rgrhoward
    4F0EDFB0-D258-4FC5-9A95-02D57E700629.jpeg Just t******* the sides, leaving the front alone so the actual grill doesn’t change dimensions at all.
  24. rgrhoward
    rgrhoward
    2ECFDBF4-712D-4031-9D13-26D49512D9A0.jpeg Little radiator checking before the order is final.
    I gotta say, the guys at US RADIATOR have been great to deal with. Told them what I needed, they sent me a drawing and I made a quick template to check things out.
  25. rgrhoward
    rgrhoward
    BC31C869-859A-498C-9B1B-BCCC82E3FAFE.jpeg F50963B3-264B-47BF-A2C5-8DD1B46B3BB1.jpeg A 32 roadster riser with a little t******* fits great.
  26. Jeff34
    Jeff34
    Couldn't agree more about US Radiator. They have been super helpful with my build!
    Your roadster is looking SWEET! Keep at it!
  27. rgrhoward
    rgrhoward
    ED78A369-5A0C-430E-8BB9-493D1E744D1E.jpeg A4AB9C66-3AE5-4B9E-93F4-7516943AB04F.jpeg 4762199F-B326-4C4C-B52D-29D1537E283F.jpeg Shaw wheel. Playing around with some under dash storage. Maybe tuck my battery up there.
  28. rgrhoward
    rgrhoward
    Sunday night photo dump. Got the grill and radiator mounted, few more things mocked up.
    8B487789-91EA-4A19-B8CF-C219EA0D5A8D.jpeg 0D060B6B-FE55-4E44-BF88-07CAFE04DB9D.jpeg 99C6D6D6-88E0-41DC-BAE6-9546E7A117DF.jpeg 618275E5-B0C8-49FB-B662-0A135030BF3A.jpeg A735B9E3-99B5-4CE7-82AA-8AA2A0D677CB.jpeg 7097EBDF-FA03-4D9F-A360-C8C442FBAD40.jpeg
    hfh, chryslerfan55, WC145 and 5 others like this.
  29. ModelAMitch
    ModelAMitch
    The car looks great, I've enjoyed following along. Cool radio flyer you've got hanging on the wall as well
  30. rgrhoward
    rgrhoward
    Built it for the little ones first birthday.
