Original 1929 roadster. Original 29 roadster body. Good complete subrails front to back and body is fully bolted down on a really nice original 32 frame. Frame has model a front and rear crossmembers, 40 Ford x member behind nice original 32 k member. Frame is fully boxed as well. Original dago axle front end has been completely gone through and restored as needed. Spindles have been restored with new bushings kingpins and torrington needle bearings. They have also been dropped to clear the axle. 40 Ford hydraulic brakes are all new front and back. 36 rear end has been professionally rebuilt with 3.25 gears and torque tube and driveshaft have been professionally shortened to fit the frame. Has good set 40 Ford wheels front and back, with original nos Indian motorcycle tires in front and older unused firestones in rear. Original 32 grill shell and insert, grill has been filled and mildly peaked, both nicely done a long time ago. Good pressure tested old radiator modified with new outlets to fit flathead v8. Hood sides are 32 Hudson. Nice running 41 Mercury motor, factory relieved and has old isky track cam. Came out of a 32 coupe that got parted out as a running car. New water pumps, rebuilt Holley 94 carbs with old stacks, old homemade carb adapter. Original thickstun aluminum heads. Motor needs head gaskets and studs ****oned up, I have everything needed to do so. Has neat old chrome oil pan and timing cover. Gas tank has been removed from cowl and neck has been filled. Original 33 Chevy dash modified to fit, and has been filled and ready for gauges to be added. Original f1 steering box modified to fit 32 frame and has been completely rebuilt . new stainless column tube with new bushing. Nice original 39 transmission with good gears. Drivers door is tacked shut, p***enger door is not, and fits nicely. Original ww2 aircraft seat. This car was put together with very nice original parts. I am calling this a project but it really just needs a few things addressed and ****oned up. I have lots of paper work on this car including a clean 29 roadster ***le. Located in Portland, Oregon. Call or text 503 953 3248
