Projects 1930 Coupe traditional build
Discussion in 'Traditional Hot Rods' started by ECMFab, Oct 22, 2023.
  1. ECMFab
    ECMFab
    Damn that ****s! Good thing Oceanside isn’t as strict as OC. Funny enough, we actually have an HOA here but I’m so friendly and help with everyone in my neighborhood that I think they let me get away with more stuff here haha
  2. God they're basically trying to turn my entire town into an HOA lol
  3. 1946caddy
    1946caddy
    from washington
    Welding on grade 8 nuts and bolts makes them brittle.
    Not recommended
    Welding on Grade 8 nuts and bolts is generally not recommended due to the potential for mechanical property degradation and embrittlement. The heat from welding can alter the microstructure of the steel, reducing its strength and toughness. Additionally, the yellow chromate coating on Grade 8 bolts can release toxic fumes when heated, and it may interfere with the weld quality. It is crucial to ensure that the fasteners are made from weldable steel and that any heat addition will not adversely affect their strength and safety.
  4. ECMFab
    ECMFab
    That’s interesting, thanks for the info! I was wondering about that. My buddy has been doing it a long time on the driveshaft on these old fords, and has never had an issue, once. He’s been building cars over 30 years. I’m hoping also in my case the HAF is on the head far outside what part I would need which is the shaft to hold as a shear pin IF the collar somehow came off or spun on the driveshaft itself. I think it would be impossible, but we will see. I’m sure I didn’t even need to put a pin in the coupler at all.
  5. ECMFab
    ECMFab
    Running this setup to get my caster angle correct. How have yall done it? I have to be out of my buddies shop today so they can make money tomorrow.
  6. ECMFab
    ECMFab
    Got the wishbones tacked, then raised the car and got small beads on them so they wouldn’t move, then lowered and checked angle of axle and I ended up around 7.8 degrees. I think the car should drive nice. We will see. Took the bones out, bench tig welded, took outside and painted them. Installing now.
    Was also able to install the splash apron and hardware. Tightened the body down today with some additional shims trying to get the hood aligned. Not easy!
    Cotter pinned the front end, adjusted brakes, and torqued wheels, then installed hub caps.
    Outback and Deutscher like this.
  7. Grumpy ole A
    Grumpy ole A
    It’s looking good. You will soon be driving it all around, burning up the roads.
    Outback likes this.
  8. ECMFab
    ECMFab
    Gosh I sure hope so. Thank you for the compliment and following along! It’s been a journey for sure and finally feel like the light is at the end of the tunnel. Definitely underestimated how long it would take to learn everything and how much time it would take for each step.
    Outback likes this.
  9. ECMFab
    ECMFab
    Here’s how she looks when I got her off the rack! Time to take to a muffler shop to bend up the exhaust and work on getting my smithy’s mufflers installed.
    Bugguts, Soviet, Outback and 4 others like this.
  10. Outback
    Outback
    from NE Vic, Oz
    Looking good!
    ECMFab likes this.
