Hot Rods 1930 Coupster
Discussion in 'The Hokey Ass Message Board' started by underwk@hotmail.com, Jan 16, 2015.
  1. 1-SHOT
    1-SHOT
    from Denton
    Put a coat of DP sealer on it . The dark sealer red and black will make the colors darker and the white and grey will make them lighter, when you finally pick a color. This is the best coupster I have ever seen. Frank
    underwk@hotmail.com and Stogy like this.
  2. Aaron D.
    Aaron D.
    Great looking Coupster. What did you use for the tapered exhaust pipes?
    Aaron
    Stogy likes this.
  3. Just 2 inch pipe and some exhaust flares from speedway.
    lothiandon1940 and Aaron D. like this.
  4. farmer12
    farmer12
  5. Atwater Mike
    Atwater Mike
    You really nailed with careful planning, great fitting of W/S stanchions, and the cut-and-finish work around the ****pit.
    The seat is another achievement, looks like a Tony Nancy job!
    Very sharp roadster, plus it fits a tall guy!
  6. Thank you. My friend Matt Seret did the metal work. He has a shop in Vallejo and does amazing things with metal. I sold the coupster body to a friend after I found an amazing roadster body.
  7. fortynut
    fortynut
    The '37 pickup/truck grill is a cl***ic solution that goes back to the roots of our hobby. I like. Even if it's been sectioned, or looks like. Don't forget, there were also tubsters done from sedans. The tough sell is the cowl and windsheld, especially the posts. The one that is shown in primer manages the task perfectly, though I have always liked severely chopped windshields and slightly lower seats. Take a look at the lakes racers in Don Montgomery's books for ideas for building stuff
    It makes your brain itch with ideas. The early timers who raced at Muroc and El Mirage built some strange variations on the theme of speed that will knock your socks off for the directness and simplicity they use. And, the wonderful thing about it is the really fast cars used Flatheads primarily and kept pushing the boundaries. They challenge us even, now, to think outside the box and don't take "no" for an answer. If you have a desire to attempt something never done before. Go for it! All success stories have failures as part of it. Those who get there do so because they didn't let a few screwups stop them. As long as you come out alive, the sun comes up tomorrow. Enough already!
    underwk@hotmail.com likes this.
  8. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Best one coupster I have seen in a long time!
  9. lothiandon1940
    lothiandon1940
    I p***ed up on reading this thread for the longest time.....my mistake. I generally don't like the vast majority of Coupsters that I see, but this was one of the all-time best conversions.
  10. Bill Rinaldi
    Bill Rinaldi
    2 comments---I think the primer absorbing comment was based on the look of the primer is like red oxide primer. The other is, can any one explain WHAT they did to the cowl to make the roadster stanchions fit so nice. I'm also curious why you sold the body for a roadster body, after all the great results and the size advantage you achieved. Sure do like the car, one of the nicest coupester set ups I've seen. Bill
    lothiandon1940 likes this.
  11. bct
    bct
    Looks like 28 29 stanchions nicely grafted on
  12. Yes I noticed that if you took 28/29 stanchions and reversed them they were a very similar profile to the Coupe posts. Then you just pie cut them to lean them back to the desired angle. The coupe posts were cut off at door height then a vertical flange was welded in place with two threaded holes that line up with the stanchion fittings. I didn’t originally plan to sell the body but when the roadster body turned up with its original Ford paint and zero rust or patch panels it seemed to good to miss.
    X-cpe, flynbrian48 and lothiandon1940 like this.
    My friend is doing a good job of putting it back on the road.
    brEad and lothiandon1940 like this.
  14. meryl shawver
    meryl shawver
    Am new to hamb, trying to convert a 30 sport coupe as you did yours. I wonder if you might have a few photos of the dash-a pillar area. Any help would be appreciated, Thanks
  15. mgermca
    mgermca
    Flipper likes this.
