1930 Ford Coupe Project
Discussion in 'The Hokey Ass Message Board' started by BenLeBlanc, Dec 5, 2014.
  1. BenLeBlanc
    BenLeBlanc
    10-4. Cleaned my tip, turned the shielding gas up a little bit as it was a little below 20, and it worked ok for the remainder of holes. As for the leaf, I ain't got a press, so I am going to procrastinate on that.
    Put the control arm back together. Got the shortened pitman arm as mine was really worn.
    Got the crank finally ready to come out. That woodruff key was tough! Here are pics of the babbitt. The middle section actually has some cracked off, so I am thinking babbitts will need replacement.
  2. mike bowling
    mike bowling
    Read the chart on the inside of the access door to set up according to material thickness, and read the literature that came with the machine. THEN take a piece of s**** and practice. An old friend told me to check for penetration, beat with a 3lb sledge; no cracks or breaks? good penetration. Make sure your lead is seated with the "O" ring into the machine before you tighten the wing nut- press the trigger and listen for an audible hiss of gas at the tip, not in the machine ( go ahead and laugh- it happens).No gas via a bad connection or an empty bottle will make the welder sputter and pop, and the welds will be all full of what look like air bubbles (and no good).Rule of thumb, when everything is right, sounds like the crackling of frying eggs (go ahead and laugh again, it's true)( smell the toast?- just kidding)
    You've got to practice short bursts with a Mig, or you'll get a pile of what my buddy calls "rabbit ****" ( lots of little balls of wasted material that do nothing) plus it will overheat and blow the circuit breaker. Lots of heat being produced so go slow and skip around on your work. It's a lot more fun to weld than to grind!
    Hiss, fried eggs, beat with a hammer, done.
    norms30a likes this.
  3. treb11
    treb11
    and make sure the polarity is correct.
  4. BenLeBlanc
    BenLeBlanc
    Yup. Lookee at my fabrication of z- boxing brackets.
    Start by going to your local USPS. Grab some flat rate boxes for free and they are the perfect thickness for templating. Cut em up and tape them in.
    Now you have a real boxed frame! Take the panels off by removing a strip of tape so that all the sides are still connected. If you try to make it as one piece, the large sides will actually hit each other, so you can't. Darn.
    So you can make it out of two pieces instead. One side and one end cap per.
    Trace out your design using your favorite sharpie and cut it out. I used an angle grinder. Put her back in the vise and bend the end cap pieces over using your trusty 3lb hammer. Make sure you do this the correct direction! You will get something like this:
    And you need both sides, so...
    Now for the outer most piece, you must note that you are going over a rivet. Dang it. Anywho, take your cardboard cutout and press it onto the rivet. It leaves an indentation. Line it up with your metal piece and center punch through. Drill it out with a 1/2 inch bit and you get two sweet pieces.
    Fit and finish with a hand file, and you're good to go.
    /tech week impersonation.
    -Brent-, volvobrynk and patmanta like this.
  5. mike bowling
    mike bowling
    Now you're cookin'! ( just don't burn the meatloaf!) Frame cleaned up nice, but I won't say I told you so!! You using 1/8 or 3/16" for your boxing material?? I prefer 3/16 myself, especially up front if you're going to weld motor mounts to it. Make strong like bull. And don't forget plating inside, plug welding and angling the ends with your grinder for a nice strong **** joint. Get that thing rollin!
  6. BenLeBlanc
    BenLeBlanc
    Bending up cross member braces this week; will box around them, so I need them before boxing. Have the plates prepped though. Here are some pictures of what I have been up to. Still don't know about the rear spring.
    patmanta and volvobrynk like this.
  7. norms30a
    norms30a
    I think you are sandbagging us, first you show us a ****py frame bada bing a really nice one shows up, then you show us a ****py 4 banger then ****, a V8 shows up. I can't wait to see what other surprises you have in store for us.Keep em coming.Oh and we need more info on the engine too.
    volvobrynk and BenLeBlanc like this.
  8. wheeldog57
    wheeldog57
    Ben is sneaky. Before we know it, this Bad Larry will be runnin!
    norms30a and volvobrynk like this.
  9. patmanta
    patmanta
    from Woburn, MA
    Wow, real Isky adjustable lifters, that's a score in and of itself.
    volvobrynk likes this.
  10. dentisaurus
    dentisaurus
    from Boston
    Nice haul, good luck with the flat head build!
  11. mike bowling
    mike bowling
    Around here we spell "bada-bing" "Candia Swap Meet", frame imported by Mr. Elliot Brown, Vinyl Haven Maine , via the "Roll-A-Bone" hot rod emporium.
    Cut to; background noise, oil and gas smell, crowd roaring: " And here in post position comes Ben LeBlanc in car # 20 , 50 laps into the 500 lap Enduro!! He's lookin' good folks!!! He's got the right team behind him, and he's headed for Victory Lane!!! Keep an eye on this one !!"
    norms30a and patmanta like this.
  12. BenLeBlanc
    BenLeBlanc
    The Iskendarian cam is just the box; not a real isky, so I am hesitant on calling them the real deal; will have to do a little searching.
    The cross brace I cut out is in 1/8 inch plate; trying to bend it into a C-shape wasn't happening so I outsourced it today. Just going to be hard to get it perfect bend wise; but I supplied the bender with a rubbing of the frame.
    As for the surprises; I have to keep it a little entertaining for you guys.
  13. patmanta
    patmanta
    from Woburn, MA
    1/8" is tough to brake. You can do it but not long short pieces like that. Long thin strips will go though.
    I'd have tried to do that with tubing or angle iron personally.
  14. BenLeBlanc
    BenLeBlanc
    So nice... Having my other brace rebent cause they messed it up. The one thing you farm out...
    ImageUploadedByH.A.M.B.1443305957.168805.jpg ImageUploadedByH.A.M.B.1443305986.551900.jpg ImageUploadedByH.A.M.B.1443306011.269694.jpg ImageUploadedByH.A.M.B.1443306043.572617.jpg ImageUploadedByH.A.M.B.1443306068.024185.jpg ImageUploadedByH.A.M.B.1443306087.526933.jpg ImageUploadedByH.A.M.B.1443306107.780072.jpg ImageUploadedByH.A.M.B.1443306130.764897.jpg ImageUploadedByH.A.M.B.1443306169.218363.jpg
    patmanta, volvobrynk and norms30a like this.
  15. BenLeBlanc
    BenLeBlanc
    Having an issue installing my front. I had my A spindles rebushed and also picked up the kingpins to go with a little over a month ago; following the shop's suggestion on the kingpin. Well, take a look. Tell me how you think I can fix it... A spindles with 37-41 pins
  16. patmanta
    patmanta
    from Woburn, MA
    There's nowhere for that bearing to go. I think the KP boss on an A is larger than the 37.
    http://www.droppedaxles.com/FORD_AXLES.html
    Only way I see to do it is to put the washer and soft bushing there then line the pin up and lock it in. Looks like you may have a quarter inch or so sticking up the top. Add washers as needed I'd say. There's nowhere for that bearing to live, shelve it. Is there a thin thrust bearing under the axle there already?
  17. -Brent-
    -Brent-
    The bearing is in the wrong spot. It's correct for the earlier kingpins but they switch bearing positions, later. IIRC.
    patmanta likes this.
  18. patmanta
    patmanta
    from Woburn, MA
    I think the mechanical brake KPs with the cup on top needed the bearing there. Those KPs you've got are for a juice brake car.
  19. -Brent-
    -Brent-
  20. BenLeBlanc
    BenLeBlanc
    Ah, ok. My bushings on the spindle actually stick out a little due to the guy who rebushed team did so. I can put a washer on there as a spacer and it will actually look sharp.
    Should the new washer (since I am taking out the bearing) be made out of br*** or just keep it steel and lay on the antisieze? Thanks in advance.
  21. patmanta
    patmanta
    from Woburn, MA
    Steel should be fine. I don't think I've seen them in br*** and properly lubricated, should not really see much wear.
  22. KustomCandy
    KustomCandy
    from Australia
    Envious of your opportunity to take on such a build at your age Bud. Your making good time now.
    Subscribed.
    Dan
  23. cmichael
    cmichael
    Looks great man! Just one thing? What's going on with the rear brakes? You got the wheel cylinders at the bottom?
  24. BenLeBlanc
    BenLeBlanc
    On the years with an A banjo, the stock wheel cylinders hit the spring perch. The simple solution is to mount the drum upside down on the opposite sides. A crescent then needs to be cut out and added back onto the other side of the backing plate in order to flip the wheel cylinder back right side up. Cool, eh?
  25. cmichael
    cmichael
    Yeah that's interesting.
  26. BenLeBlanc
    BenLeBlanc
    You don't sound that enthused... That was the quick and dirty of it. Way more than I thought was going to be involved.
    And I've been moving along, but now am wondering which master cylinder to get? I am trying to mount pedals, steering, and such and this is crucial to the whole set up, as one would imagine. Anyone have a suggestion?
    My thoughts are dual reservoir drum drum, but I don't have any part number in mind. I want to keep it traditional though, but don't like tardel's single reservoir idea...
  27. patmanta
    patmanta
    from Woburn, MA
    I would suggest you go with a dual master.
    I think the most common are GM style that have a horizontal 2-tab mounting layout, so you'd just need to get it level to your bracket and mark it hopefully. Try to go for something that you can get parts for easily and that suits your needs. I think the one I have came off a 60's Mustang and I see a lot of mention of Corvette masters too.
    Hopefully this'll bump up and get you more answers.
  28. patmanta
    patmanta
    from Woburn, MA
  29. norms30a
    norms30a
    Looking good. Do what Patmanta says,dual cylinder brakes all the way. No harder to install at all and no one will see the thing. Also ask Hamb guys about an E brake setup, need one on your hot rod, tuning that 8 with it running in neutral, gotta have an E brake.
  30. BenLeBlanc
    BenLeBlanc
    For sure. I actually picked up an A e brake conversion kit for juice brakes at a swap meet a couple months ago. It was the one from clings I believe, and it came with the cables as well as some brackets, which I am tossing up actually using. I think it also came with the A handbrake mounting bracket as well, but unsure about that. Worth it for I think forty bucks? Bought it with my trans.
    And just to give some background to everything, my engine that I bought was actually from a guy with a forties coupe. He bought the car off of someone and it came with this block, which seems acid dipped and cleaned. Anywho, the car was only pumping 5psi oil pressure, but the guy didn't care. So he took that running engine out for a swap (unsure what he was going to), and just sold the other one to me. The poor running one was also apart, but selling for 800.
    I believe that what I got was the engine that the first owner had bought and cleaned and prepped to build for the car, but just never got around to it. The guy was a very tough negotiator, but I got everything for the engine (minus drivers water pump!) along with new clutch and a couple other goodies for 300. Good enough for at least a placeholder!
    Right now I am working on fitting the A pedals into the correct place; but the brake pedal mounts only a half of an inch away from the trans, and the clutch is not going to be able to actuate correctly if the brakes are in the way. Any more questions, ask away!
