Projects 1930 Ford Sedan ....twisted tudor
Discussion in 'Traditional Hot Rods' started by Flop, Jan 20, 2015.
  1. 40Standard
    40Standard
    from Indy
    lot of nice work
  2. chiro
    chiro
    Saw this early this morning. Immediately went into my shop and dismantled about 10 hard drives to repurpose the magnets. Those little things are STRONG!
  3. Roger53
    Roger53
    Very nice would like to see pictures as you do some panel fab.Roger
  4. Flop
    Flop
    chiro . they are awesome ! thanks guys
    shaving the roof attatchment points
    tb33anda3rd and volvobrynk like this.
  5. leadfootloon
    leadfootloon
    Nice work did you replace all the wood with steel?
  6. Flop
    Flop
    Thanks ! No sir no wood will be replaced with steel . No real reason to do that in my opinion .
    tb33anda3rd likes this.
  7. Flop
    Flop
    found a roof skin to put on . wasted 2 days prior rolling one out ....
    finally a good side profile
    and the back
    tb33anda3rd, kiwijeff and willbe like this.
  8. Corn Fed
    Corn Fed
    Very nice work. But how are you going to remove the rest of the rust on the body? Did you sandblast the areas that you covered up before welding on the new patch panels?
  9. bigheadbaxter
    bigheadbaxter
    Flop just curious what your donor roof section is from? Looks fantastic
  10. louisb
    louisb
    Very nice! How did you get the A pillars to line up with the wedge chop?
    Thanks,
    --louis
  11. Flop
    Flop
    corn fed anywhere that was covered was either wire wheeled or spot blasted . the rest of the car will be blasted .
    thanks big head !!
    A pillars were no problem . b pillars needed some love .
    back at its home
  12. Roger53
    Roger53
    Very nice the wedge cut looks great along with the rest . What size tig wire do you use most of the time? And is it 70s 6 ? Roger
  13. raidmagic
    raidmagic
    I really like the wedge chop,
  14. 340HilbornDuster
    340HilbornDuster
    Impressive Work!
    Like the Wedge!
  15. Always outstanding work!
  16. kidcampbell71
    kidcampbell71
    You're always soooo money ... I love seeing your work. Unfortunately, the harder you work, the more fun it is to see. Thank you man. Once again, greatness.
  17. olskoolrodder
    olskoolrodder
    brings back similar memories... great work!!
