Projects 1930 fordor front... coupester start ?
Discussion in 'Traditional Hot Rods' started by sloppy jalopies, Apr 20, 2020.
  1. sloppy jalopies
    sloppy jalopies
    Not working on it, but just picked up the remains of a 1930 wooden fordor...
    a '3o hood, cowl, doors, roof panels, w/s frame, visor, dash, instr. cluster, both murray garnish, B pillars, seat frame, f. fender, splash apron, running board bracket, was a wooden cage car with a steel cowl...
    note the B jam is wider than the A jam is... the top edge of the door is arched... odd garnish / door top... armrest edge is a much sharper radius...
    not going to use the door tops, visor, garnish, roof panels, seat, f. fender, splash, inner door panels, remote inner door latches...
    View attachment 4653043 DSCN6089.JPG View attachment 4653045 View attachment 4653041 View attachment 4653039 View attachment 4653037
    tb33anda3rd likes this.
  2. sloppy jalopies
    sloppy jalopies
    Same guy had a '30-'31 open car w/s frame and 13.5" stanchions... right side is broken wide open...
    I have very little time working with stainless … is this fixable and will it stay together if I do ?...
  3. sliceddeuce
    sliceddeuce
  4. RICH B
    RICH B
    How about a roadster pick-up like can't think of his name in FL built.
    bill gruendeman and luckylou like this.
  5. sloppy jalopies
    sloppy jalopies
    yup...
    just welded this baby up, pushed it outside a week ago, looks like they were twins... DSCN5550.JPG
    kidcampbell71 likes this.
  6. dumprat
    dumprat
    from b.c.
    That look like the start of a woody delivery!
    Rough out a steel structure out of tubing and cover it in plywood. Could haul all sorts of nifty stuff or sleep in the back.
  7. sloppy jalopies
    sloppy jalopies
    last 3 project bodies started with less... a lot less...
    sportster.
    .roadster-esque pick up.
    . coupester #5.
  8. A Boner
    A Boner
    This would be right up your alley!
    1C139FBC-0465-40FE-A09F-37B9ACDD8F2C.png 135DAAE6-40EB-44D6-9053-70297B6EA717.png
  9. sloppy jalopies
    sloppy jalopies
    Went tin shopping today...
    buddy set up tables in a row in his shop... in one door run the gauntlet and out the big door...
    wear a mask and stay 6' behind the shopper in front... better safe than sick.
    got a '30 grill, door garnish, '28 car dash, 2 roadster w/s frame top rails, pr. '30-'31 truck headlights w/ 3 bezels/ sealed beam conversions and 2 king pin sets...
    he has a ruff T touring body... [free ?]
    with the new '30 cowl and doors ... a set of quarters and this would officially become a "pile" ...
  10. sloppy jalopies
    sloppy jalopies
    Grabbed my shopping cart ;
    1930 cut down cowl, [4] male hinges...
    pair of 1932 rear frame covers...
    and a 1932 left qtr. garnish...
    buddy bought a 1932 truck cowl, cut short frame rails, welded front crossmember, firewall, dash and a cut up K member...
    ... not a bad day !
  11. Your windshield post is a some-what easy repair. I had done many repairs of them in the 1970's when I had an early Ford business. Just use good quality stainless wire and you should do okay.
  12. sloppy jalopies
    sloppy jalopies
    Got one on ebay for $44.. but is missing the inside ribbed, stainless piece...
    How do I replace it with the one from the broken stanchion ?... removed the side curtain pins and the windwing mounts... nothing left screwing them together... what is the trick ?
    Repaired 5 places on a roadster w/s frame... well... there is always my lawn art collection...
