1930 hudson
Discussion in 'The Hokey Ass Message Board' started by choptvan, Jul 5, 2010.
  1. fleet-master
    fleet-master
    just stumbled upon this thread and wonderin on the progress on this coupe? looks like it was shapin up pretty nice..:) , PB
  2. Shaggy
    Shaggy
    from Sultan, WA
    Very cool, i wanta see a hornet 6 in that!!!
  3. You've done so much work to that body so far, why skimp out? Go for the gusto and get the 308 with Twin-H power!
  4. choptvan
    choptvan
    Still tryin to gether parts. I have 2 hudsons I am looking for parts for. This 31, and a 42. The 31 needs doors, decklid, and a grille before I really get into her. The 42 has a nonfitting 40 front clip with a 47 hood. Plus the car was wrecked pretty damn bad. The 42 has a 331 caddy while I have no motor for the 31. We will see which one gets the parts quicker. Whichever does gets built. Thanks for the interest guys.
  5. fleet-master
    fleet-master
  6. choptvan
    choptvan
  7. BISHOP
    BISHOP
    What a cool car, I had no idea these cars existed.
    Very nice.
  8. Nice, I really like Hudsons.............
  9. mastergun1980
    mastergun1980
    from Alva OK
    I like this car. I especially like the all hudson theme.
  10. fleet-master
    fleet-master
    must be parts around for your Hudsons Choptvan...they're like belly****ons!! :D:D:p
    like the 31..very cool PB
  11. jazz1
    jazz1
  12. choptvan
    choptvan
    Damn.. dont tempt me! Thanks guys for helpin keep this towrads the top. I REALLY need those partsfor the 42 first. But if the parts for this one came up, I might just change my mind!
  13. Ramblur
    Ramblur
    Don't give up on a Hornet motor. Running one in my 49 sedan but broke both compression rings in one cylinder on the way to Viva last year.
    The old Jahn's pistons were done and the crank was already 30/30 so plan B was the spare engine that came with the car. The head wasn't on it when I got it and had some rust so it just got oiled down and slid under a bench. Imagine my surprise when teardown revealed a NEW standard bore,standard crank never run engine.
    Both of my engine are 55-6 vintage when Hudson was on the rocks and being absorbed into AMC and are a little different from the earlier 308's.
    For starters the cranks are a 1/2 inch shorter to the flywheel flange and
    the flange is threaded wereas the earlier motors used through bolts/nuts.
    Still there were lots of these motors left when Hudson went under and in the early 60's JC Whitney would sell you a carbs to pan complete engine
    for a couple a hundred. There still out there...somewhere... An easy way to spot a 308 is the cast rib running the length of the block just above the oil pan rail on the drivers side.
    The Clifford head and header are still available new afaik and I've heard that a brand new finned aluminum head is now or will soon be available from another manufacturer. Best of luck on your Hudson builds.
    BTW, the wire wheels you've seen on my 30 Es*** earlier in this thread are/were optional in place of the standard wood wheel BUT use a different hub/drum to accomodate the wire wheel and they may be harder to find than the wheels themselves,plus you would need later axles to get juice brakes.
  14. choptvan
    choptvan
    SWEET lookin engine! I will have one. Someday. Thanks for the replies!
  15. HELLVIS
    HELLVIS
    **** it just go to the cl***ifieds and buy my 32
  16. choptvan
    choptvan
    Does it have doors? Deck lid? Hood? Hood sides? Grille? What do you want for it?
    edit
    after looking at the add, and noticing it is the same as the link above, no thanks. Way over priced IMO. I know it is hudson, but it isn't even close to the same as far as doors, deck, nothing I am in need of.
  17. 1933BOB
    1933BOB
    I have the back half of a coupe with the deck lid and quarters and cross sections!!!!!
  18. choptvan
    choptvan
    How mcuh do you want for it?
  19. MATACONCEPTS
    MATACONCEPTS
    Whats up with the Hudson?
  20. choptvan
    choptvan
    Gone. Sold it to a family friend. To a guy I can buy it back from when the chance arrizes. My sister got in a real bad jamb financially. So she had to go. Still have my 42. And still following leads on parts for it.
  21. nhmikel
    nhmikel
    from NH
    I may have a 30 31 light bar and head lights
    Do you need? send me pm
  22. 1933BOB
    1933BOB
