1930 Model A Pickup Project-SOLD
Discussion in 'Parts For Sale' started by blacknwhitedog, Dec 7, 2020.
  1. blacknwhitedog
    blacknwhitedog
    from Sonoma, CA
    City: Sonoma
    State: California
    Price: $3850
    I'm selling my 30 Model A pickup project. It has a clear California ***le, and comes with the following: Model A frame, sandblasted and primed with weld through primer. Frame is not boxed, but I have the boxing plates which will be included. Frame is stepped and lengthened to use a model A spring behind setup and an 8" ford housing and retains the stock wheelbase. I have the axles, backing plates, and third member to go with it. I also have the motor mounts and biscuits to install an SBC
    The pickup body is like most, with rust on the bottom of the doors, cowl, and back of cab. I have two sets of doors, both of which need work. I have patch panels for the cowl, cab back, door bottoms, and the subrails have already been replaced. I also have the wooden blocks to mount the body. The cowl has new hinges with br*** bushings and the doors line up well, and open and close as they should..no latches yet. I have the visor, good windshield frame, the roof panels, one original, and one repop.
    Also includes a 30-31 grill shell and brand new Champion radiator still in the box set up for an SBC.
    F1 type front Shock mounts and also two sets of F1 pedals included.
    The front axle, spindles, wheels and brakes are NOT included. I will however throw in the Model A wishbones which already have the bungs and tie rod ends installed.
    With one grandchild and more on the way...I realistically have no time to finish this project...I'm open to reasonable offers, and this needs to be picked up..NO SHIPPING.
    I can send more pictures of any detail you require, short of re-***embling the body.
    wrenching machine likes this.
