Projects 1930 Model A Project
Discussion in 'The Hokey Ass Message Board' started by billthx138, Oct 18, 2009.
  1. billthx138
    billthx138
    Being a **** is ok, we all are!!! anyway, nooo the shell is lower than the cowl....here is a straight on view.
  2. Hitchhiker
    Hitchhiker
    I retract my previous statement of this car being to nice to cut up. Having bought a rough project in February I can appreciate wanting to use a nice body to begin with.
  3. billthx138
    billthx138
    Ok, just for clarification for those nay sayers, with the frame at ride hight and a level from cowl, to radiator shell you can see the drop from cowl to shell. with a hood top on it should be visually appealing even to the most discriminating tastes.
  4. billthx138
    billthx138
    Yes, the better the start, the better the whole project. I like my desert cars, but they will adjust nicely when i move (retire) to your neck of the woods. Ill be hauling both the roadster and the coupe up to the olympic peninsula sometime next summer.
  5. MR. FORD
    MR. FORD
    from Austin, TX
    Except for the boring motor choice (my .02$), this coupe is looking great. Keep it up ...
  6. billthx138
    billthx138
    I know, if we could all have hemis then yours wouldn't be a stand out. Nice car, we are moving in the same direction, only different at times. Dig the tradition.
  7. JimSwann
    JimSwann
    Cutting up a rare Model A, there were only 4,849,340 made. Why start with junk if it's cost effective to start with a nice body. My friend bought a nice A coup, sold about everything but the body and built a rod. People gave him **** too, but he saved a ton of money and time. Great looking car.
  8. Hitchhiker
    Hitchhiker
    I didn't know a solid lifter 283 with trips was boring.:rolleyes:
  9. billthx138
    billthx138
    ditto!
  10. Strange Agent
    Strange Agent
    Ballsy move cuttin' up that nice car. I don't blame you, though.
    The car is coming along very nicely. Keep up the good work.
  11. GaryB
    GaryB
    from Reno,nv
    sweet build ,what color are you going with?
  12. billthx138
    billthx138
    Very dark solid blue
  13. GaryB
    GaryB
    from Reno,nv
  14. mritech
    mritech
    Where on the peninsula are ya moving to, There are a few hot rodders up that way I know, my Dad lives near Lake Cushman.
  15. seventhirteen
    seventhirteen
    from dago, ca
    what a boring car, chopped model A coupe, 32 rails, 4" dropped drilled axle, small block chevy, multiple carbs, 32 shell, ect, ect......
    boy you just couldn't get anything right with this thing, next time maybe build something original OK? On a serious note, looks like the car is coming along great
  16. awesome build!!!! is that bump in the back floor to clear the diffferential or??
  17. billthx138
    billthx138
    We will be settling in Se****, and I am surprised every time I am up there how many hotrods are around, and the quality of them is outstanding.
  18. billthx138
    billthx138
    You are correct, that gives me enough clearance when the suspension is is fully collapsed. Hoping that I never hit a bump that hard, but the roads around here **** and I've hit some big ones in my roadster that just about launched me out of my seat.
  19. Fixxxr
    Fixxxr
    from Sk, Canada
    Awesome build so far! Just a question...what are the headlights off of? I just love big headlights on a Model A.
  20. billthx138
    billthx138
    The headlights are off my '32 when I changed them with smaller ones. They have the hologen bulb conversion and hidden turn signals behind the gl***. The only problem is they throw light everywhere except down the road. On coming traffic hates em and they are alway flashing me to turn down the high beams. But they do look good!!
  21. billthx138
    billthx138
    Got back into the garage and spent the whole day working on the coupe. I needed to clearance the firewall for the distributer and wanted to keep as much of the original look. So, with my cutoff wheel, hammer and dolly I dove into the project. A lot of welding later, some bondo and primer, voila, done.
  22. Uncle Bob
    Uncle Bob
    from Salado, Tx
    Missed you at Goldstrom's today, but looks like you made some good progress.
  23. billthx138
    billthx138
    Yeah I got busy and forgot about the swap meet and show. Cant complain was a good day, I also bobbed the front frame rails. I'll probably Pick up some tubing and make the spreader bar tomorrow. I also plan on rounding the front like a Model A frame. But that cant wait until after Coffee.
  24. The37Kid
    The37Kid
    Now you have me rethinking the firewall bottom chop. You need a shorter radiator, grille shell modification and what else? [​IMG]
  25. Kool build,I am just wanting to ask one question,Where the subframe is channelled over the ch***is in the middle of the door opening,how far is it out from the ch***is rail edge?If you channelled it 1 1/2 " and it's only 1/2" or so from the edge I'm just wandering if you had to modify the subframe door area?
    Just going thru this myself and trying to work it out.
    Thanks Chris
  26. billthx138
    billthx138
    You have to relocate the toe kick and raise the cross sub-rails flush with the top of the floor. The rear sub-rails have to be removed and remade to fit the 32 frame kick up. Lot of labor, but not very hard to complete.
  27. billthx138
    billthx138
    Once the cross sub-rail was removed and raised and the rivets that where there removed, there was no issue. so the door area looks completely stock no modifications. At the middle of the door, the body is about 3/4' out from the frame sort of like a duece.
  28. Cheers for that.The 3/4" out from the frame tells it all.
  29. I'm jealous. All I've ever got to start with were rusty heaps. LOL
  30. Ford Mike
    Ford Mike
    Any more progress? I can't wait to see this thing with paint!
