1930 model a window feathers?
Discussion in 'The Hokey Ass Message Board' started by noowife, Apr 10, 2011.
  1. noowife
    noowife
    from Lansing,MI
    Is there a piece of rubber that goes between the gl*** and outside of the door? The area between the gl*** and door when window is down. I have tried to find info and have gotten no where. I know most cars have a door"feather" but can find no ifo on this. Thanks for any help. I am wanting to install side windows soon.
  2. 325w
    325w
    No feathers. Look at a Mac's catalog.I think you get a couple of rubber bumpers. that keep the gl*** from hitting the metal. Not to say you can't get the material in stick form from the gl*** shop and make feathers. You must have worked in a car factory. No one else uses the term feather.
  3. spooler41
    spooler41
    What you need to look for is "Window channel" ,this is the "U' shaped piece that the gl*** runs in inside the door/window frame.
    ............Jack
  4. BuiltFerComfort
    BuiltFerComfort
  5. noowife
    noowife
    from Lansing,MI
    thanks forthe help. I have new channels. I did work in the trim department at a old Fisher Body plant lol.
  6. firepilot
    firepilot
    325w is right, it is 2 rubber bumpers that go in there. I am sure you could make something of your own that would work just as good. Ride looks nice.
  7. green53ford
    green53ford
    from Wisconsin
    The pieces you are looking for are available in reproduction, They are a piece of rubber mounted in a metal strip. It has been so long since i purchased mine i forgot who i got them from.
  8. modelaman
    modelaman
    from sunland ca
    the part goes on the inside of the gl*** under the garnish moulding. On a 2 door sedan they did not use one on the outside of the gl***. It is called a window anti rattle and is avaliable from most model A parts vendors Like Brattons antique auto parts, Mikes afordable parts, snyders antique auto parts.
  9. noowife
    noowife
    from Lansing,MI
    I did buy the new ones for the inside as pictured. I also bought everything else including the rubber bumpers. I just found it odd that there was nothing keeping water from running down inside the door. I have never owened a car this old. Thanks for the help.
    Thanks for the compilment. My avatar is how it looked the day I bought it 2 years ago. I didnt relise it would take this much work or this long.
    I bought it from a Model A guy in Lowell,MI. I believe his name was Butch. If anyone knows him I would like to get him some pictures. I dont believe he had Internet access. Thanks
    Lance
  10. noowife
    noowife
    from Lansing,MI
    Ok so I put the windows in and I dont have the rubbers you speak of. Where do I order the rubbers on the outside of the windows. My windows just fall out.
  11. go-twichy
    go-twichy
    snyders antique auto parts, new springfeild oh.
