1930s Era Champ Car - new project
Discussion in 'The Hokey Ass Message Board' started by THE FRENCHTOWN FLYER, Nov 20, 2007.
Another question: Posi or non-posi?
Poll closed Aug 18, 2021.
  1. Posi for two-wheel traction
    100.0%
  2. No Posi for better handling in the corners.
    0 vote(s)
    0.0%
  1. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I have had a nagging fear that joining the fuel filler cap to the fuel tank was going to be problematic. It looks like with the current standpipe stubs on the tank and the filler cap that the connecting hose was going to have to run uphill to the tank. No Bueno. Not good for five-second pit stop refuelings LOL.
    To make it better I cut and welded the filler tube coming out of the tank with a right angle bend. That helps, but still not enough for me to be comfortable. I cannot lower the bustle down onto the frame completely to complete the routing - the bodywork is still standing proud of the frame because of interferrence with the rotisserie, preventing accurate placement of the filler tube. I am going to have to cut-n-weld a bend into the cap filler tube also. I will wait until the frame is off the jig to do this.
    On to ssomething else...
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Well, I stared at the gas tank filler cap for a few days and finally said "Screw it. Its getting installed." I welded it into the bustle. The standpipe will probably get a bend added to it like I did with the tank filler pipe. I will wait to finish that when everything is installed so I can get the alignment close. Note the overfill drain pipe; keeps fire risk to a minimum. I wish I had ordered the full size cap, not the scaled down cap, but I didn't want to take up lots of body panel space better left for the car number. Plus I'm in no rush for fast pit refueling stops LOL.
    I added filler to the headlight stanchions. They are now near to net shape.
  3. Dave G in Gansevoort
    from Upstate NY
    But, without the giant size filler how are we going to pit you fast enough to win at Altoona on the boards?
  4. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I thought of that. I'll win it on fuel economy!
    SR100 and Dave G in Gansevoort like this.
  5. Dave G in Gansevoort
    from Upstate NY
    But if you need more power and we add a little pop to the mix, you might not get the mileage…
  6. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Then I'll put big(ger) tires on the rear so I'll always be going downhill.
    Dave G in Gansevoort likes this.
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Like the fuel filler cap, here's another WELL-I-SHOULDA-DONE-THIS-THING-SOONER thing.
    I need to add a means of supporting / stabilizing the nosepiece. I decided to add an attachment point to the nose.
    From the gitgo I had intended to produce a racer that may have been built in the late '30s and survived racing into the late '50s. That enables me to add "update" features like a roll bar that were eventually mandated. So I thought I would add another feature - a hole for a starter motor. Earlier cars were push- (or pull-) started and then aircraft starters became the norm. So I decided I'd put in a starter hole that could conceal a mounting point for the front clip.
    First I hammered out a stainless steel escutcheon plate, similar to the rusty plumbing escutcheon, but more substantial.
    Then I made a recessed well from 1.5" thin walled tubing to contain and hide a 3/8" bolt and welded it into a hole in the nose. It's now ready for some filler mud.
    I will fab a stainless bracket that attaches to the front spring mounting bolts and joins up to the nose.
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I finished the starter hole and the accompanying attachment bracket. Now on to filler and primer / paint.
    HJmaniac and CoolHand like this.
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Since its been a week since I last posted an update and all I really have to show for this week's work is a pile of sanding dust and Bondo shavings, I thought I'd share a little tip.
    The starter hole cover is held on with three sheetmetal screws. The holes are too close to weld beads to use Rivnut inserts. Hence the need for sheet metal screws.
    I inherited an Ingersol piercing air tool. I put pierced holes in the nosepiece. Pierced holes offer twice the holding power of a sheet metal screw run down through a drilled hole. They have roughly 1.5 times as much screw engagement.
    I may use sheet metal screws to fasten the grill shell to the body too, with pierced holes.
  10. Dave G in Gansevoort
    from Upstate NY
    I remember doing that with a hammer and a nail. Okay so it was crude, it was cheap!
  11. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That reminds me - it helps to back up the hole location. Even a piece of tubing or a wooden block will minimize unwanted distortion around the hole.
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    It's been a month. I have been doing body prep for painting. The cowl and nosepiece are just about ready for primer. I did lots of
    filler apply
    grind off
    filler apply
    grind off
    etc lather-rinse-repeat
    until I got the panels straight enough. Not perfect, but race car good enough.
    After all the car is in primer I plan to mix up some ch***is paint, called Frenchtown Grey, i.e., one part black to 4 parts white. Sorta like a battleship grey, I have been using this for years on ch***is and interior of panels. paint 20.JPG paint 21.JPG paint 19.JPG
    Tim, Sky Six, HJmaniac and 3 others like this.
  13. 1-SHOT
    1-SHOT
    from Denton
    That about all the tools you need to do Bondo work maybe a hammer & dolly.but it’s looking good. I mix my gray paint the same ratio. Love following your work. 1-SHOT
    THE FRENCHTOWN FLYER likes this.
  14. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thanks 1-SHOT. I do have an ***ortment of hammers and dollies and some metal moving tools I've made. While my tools are abundant my metal forming skills are rather meager, and as such, this part of the project moves slowly. With luck, I'll get paint on this ride by the end of the year.
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    More parts primed. From ten feet away it's not looking too bad. Lots of wet sanding in my future. I wish I could do it sitting in front of the TV. Ms. Frenchtown would not be happy.
    Tim, CoolHand, loudbang and 4 others like this.
  16. Dave G in Gansevoort
    from Upstate NY
    Get a Roku, and a flat screen tv for the garage. That way you can… of course you need to focus more on the project than the tv. Oh, and she gets to watch all of those Christmas in July shows, while you can watch MAV tv. Or your favorite cooking shows
  17. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    On to the last piece of the Bondo puzzle - the bustle.
    As I squeeged on the filler I remembered an early TV restoration show for DIY gearheads. The host of the show demonstrated applying filler and he said "Never re-use the spreader paddle. Discard it."
    I thought, WHAT!!!??
    If I had to discard every paddle after one useage I would go bankrupt. I s****e and clean my small collection and wipe it with acetone if necessary. Maybe he figures it is cheaper for him to discard and use new than to pay his help to clean off the used ones. Whatever... It was at that point that I began watching TV "experts" with a critical eye.
  18. jaracer
    jaracer
    I try to clean my paddles before the bondo dries. A freind who ran a body shop showed me a trick. He would glob any remaining bondo on the paddle and let it harden. Then all he had to do was flex the paddle and the bondo would break off leaving the paddle much cleaner than my method.
  19. CoolHand
    CoolHand
    Alliance Vendor
    I was just getting ready to post this.
    Let's you do a quick check on how your material is curing as well, without disturbing anything that matters.
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    louvers 01.jpg louvers 02.JPG Due to home maintenance and improvement projects I did not accomplish a lot last week. Plus, I tore up the transfer case / PTO drive in my lawn tractor and it is terminal so I am in the market for new tractor and implements. I did enlarge the 1/8" Cleco holes in the bustle-to-frame valance panels to 1/4" and welded nuts to the backside of the panels so removal will not take two hands.
    HJmaniac, loudbang and CoolHand like this.
  21. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Woohoo! I found a sweet deal on a John Deere lawn tractor with only 80 hours on it, so I can mow my yard once again.
    In the meantime, I smoothed and primed the bustle and the valance panels.
    Tim, jaracer, GirchyGirchy and 3 others like this.
  22. CoolHand
    CoolHand
    Alliance Vendor
    Lot of work in that tail, but it looks to have turned out pretty well.
    My racecar bodywork has always been of the "lay it on the floor and walk on it until it's kinda flat" variety, so I certainly ain't gonna throw no stones.
    Good to see progress continuing to happen.
  23. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thanks Ryan.
    Some of the surface is not perfect. The first three front inches is going to be covered by the attachment flap on the upholstery so i did not try to get it smooth only to have it all covered up. The inside will get paint first, along with all the inner and ch***sis pieces.
    Maybe the number, trim, and paint graphics will make it all look good.
  24. Dave G in Gansevoort
    from Upstate NY
    It’ll look great going by at 100 mph kicking up the dirt!
  25. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That is my thought too. I doubt if these cars were even bumped out and smoothed down when they had an altercation. Probably just a quickie bump-n-paint? Mine will look like a "survivor".
    I am nevertheless happy with the overall lines of my design.
  26. CoolHand
    CoolHand
    Alliance Vendor
    Yeah, they got repainted, with a brush. :D
    There's no use being too awful precious about a racecar that you actually race, 'cause that bodywork (or the whole thing) can get written off in pretty short order.
    Every season starts with a shiny new body . . . but it very seldom ends that way.
  27. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I did a little watercolor rendering of my car in its final livery.
    Prep for painting continues...
  28. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Today I did more sanding and mixed up the paint color for the ch***is and interior surfaces. I should get about a gallon out of this mix. I hope that is enough. Painting round tube and other round surfaces always seems to consume much more paint than I expect. I'll use a HVLP gun.
    We'll see.
    Some surfaces, like the grill opening tunnel going back to the radiator, will get painted in black-out black so as not to draw attention to it. Other surfaces, like the holes in the front axle, may get painted accent black by hand, to draw attention to them. paint 11.JPG
  29. Dave G in Gansevoort
    from Upstate NY
    Nice blue color, oh wait, I’m colorblind and the blues all look gray to me. Nice color choice…
  30. CoolHand
    CoolHand
    Alliance Vendor
    I painted a modified ch***is in early 2024 and that took a gallon and a quart, but that was Rustoleum which doesn't get thinned a lot, and I used an HVLP gravity feed gun. It reminded me why I hate painting.
    You should have plenty of paint there for an old school champ car ch***is (IMO anyway, depending how heavy you want to lay it down).
