1930s Era Champ Car - new project
Discussion in 'The Hokey Ass Message Board' started by THE FRENCHTOWN FLYER, Nov 20, 2007.
Another question: Posi or non-posi?
Poll closed Aug 18, 2021.
  1. Posi for two-wheel traction
    100.0%
  2. No Posi for better handling in the corners.
    0 vote(s)
    0.0%
  1. Dave G in Gansevoort
    from Upstate NY
    Oh, you know you will!
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I finished up the hangers. For the welded stud I ordered two extra long bolts to insure there is enough shoulder to slide over the bronze bushings. Then I cut the bolts to length and put a pilot on each. Turned the hex heads down round for looks and ground off the grade 8 markings before welding. rear axle 05.JPG rear axle 06.JPG rear axle 07.JPG
    loudbang, CoolHand and chryslerfan55 like this.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Here's another silly little time saving tech tip. For TIG welding I carry a "quivver" full of tungsten electrodes to the welding site. That way, when I inevitably contaminate one in the weld puddle another clean and ground one is at my fingertips, saving me several walks over to the grinder. Made from a s**** rubber strap that I punched full of holes.
  4. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    It took three hoodlums to install the new bronze bushings in the rear spring - two to steady the 40# spring pack under the press and me to pump the ram. After that we removed the frame from the rotisserie. It'll hold up a deuce roadster build one of us are working on. I snuggled the frame over to one side of the garage bay so we can fit a drag car and my wife's DD in there for the winter. Work on the champ car is winding down for this year so I can turn to getting the engine in the drag car rebuilt. Stay tuned...
  5. Dave G in Gansevoort
    from Upstate NY
    Just don’t keep us waiting too long…
    THE FRENCHTOWN FLYER likes this.
  6. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    This Post is going to take a bit of a sideways vector.
    I would imagine some of you readers read this build thread because of your interest in old sprint cars, midgets, and champ cars.
    Some of you may read this post for a detailed example of a ground-up build.
    Some may even read it beacuse of my ebullient witticisms on the subject of building a vintage race car.
    But I suspect a small percentage of readers follow me because of your interest in the Ford 300 ci six engine as a performance engine.
    This posting is for the Ford six afficionados. It is only tangentially related to the era-correct Ford 300 six. I have raced these for nigh on to six decades during which I witnessed the engine's few weak points.
    One of the engine's weak points turns out to be main bearing caps. I have seen two engines with broken main bearing caps. These were on built up race motors so the power level is considerably above the stock engine. With the help of a fellow retired Ford engineer who has an extensive home machine shop we milled the caps straight across, to make room for reinforcing straps made from 1/2" x 1" bar stock. Several sets were completed to help other six banger racers. My buddy set up a locating jig to insure every piece is exactly the same. The caps were then ground flat on a surface grinder to insure flatness. I then took a bare block and a set of caps and reinforcing straps to my block machinist who will align bore the main journals.
    If you happen to be building a 300 race motor I highly recommend you reinforce the main caps with a set of these reinforcement straps. I will sleep better with a set of them on two of my race motors.
    broken main 01.jpg broken main 02.jpg main caps 01.JPG main caps 02.JPG main caps 03.JPG main caps 04.JPG main caps 05.JPG main caps 06.JPG milled caps 01.JPG
    GuyW, loudbang, Sharpone and 2 others like this.
  7. Dave G in Gansevoort
    from Upstate NY
    I’m surprised you haven’t machined up a set of billet main caps.
    Sharpone likes this.
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thought about - for a second.
    But when the guys on the national drag circuit showed me what they used on their 750 HP, seven second drag cars I felt this way was more than adequate and easier. No need to reinvent the wheel.
  9. Dave G in Gansevoort
    from Upstate NY
    But, but, but, remember the motto. If some is good, more is better and too much is just enough. And besides that you know that you want to over engineer it! Me, I never do that…
  10. Sharpone
    Sharpone
    Nice
    Dan
