1931 Chevy coupe
Discussion in 'The Hokey Ass Message Board' started by hotrod56cars, Jul 10, 2010.
  1. gear jammer
    gear jammer
    from tucson az
    handle is 31 chev, I have 2, 31 chevys, the dash on a chevy is one piece, top and bottom, not like a ford, where the lower dash is the gas tank, and there is an upper rail, earlier chevies are the same, 1 piece, but different in design than 31 and 32, 32 is slightly different on the top reveal.
  2. hotrod56cars
    hotrod56cars
    Maybe it's a Pontiac? Olds? Buick? :confused: It doesn't really matter.
    The body can not be attached to the frame to build a sub frame because the body does not attach to the frame, the subframe connects the body and frame together. "Rome wasn't built in a day" and I"m just getting started on this one, it will be tied together left to right.
  3. Ghost28
    Ghost28
  4. gear jammer
    gear jammer
    from tucson az
    Who said attach the body to the frame, all I said is build the sub frame for the body with the body on the frame, do this only if you want your doors and everything else to fit ...hey you know what your doing, im only trying to help. oh yeah the visors wrong for the car.. not chevy either, looks like it goes with the dash, model a probably
  5. kopperkart
    kopperkart
    from Wisconsin
    Here is a Chevy I sold a couple years back after pulling it out of the woods.[​IMG]
    This is a frame i still have. HAMB members have told me it is '31 Chevy?
  6. gear jammer
    gear jammer
    from tucson az
    heres some dash pictures for you, blue dash with all the gauges is 31, The other dark blue one is orig 31, copper one is 30, non have a seperate rail on top,
  7. hotrod56cars
    hotrod56cars
    Yep, I agree. That upper dash rail is out of a model A Ford and the visor, probably the same. I definately don't know the details of any of the early years, except for deuce pickups. The upper dash rail wood had these steel brackets that were held on by screws, they looked like a stock part should look, and the dash was green... so I thought they were original to the car... :p
    So that's great, I know it's a 1931 Chevy. Thanks for the help! :D
  8. oldskooljc
    oldskooljc
    from Fresno CA.
    DAM THAT DASH IS SWEET lol i thought that thing would be almost done by now keep at it jim
  9. 6t5frlane
    6t5frlane
    from New York
    Now put a Ford in her just to keep things even .....
  10. wingman9
    wingman9
    from left coast
    Ohoh, I think I just threw up in my mouth a little bit. :eek:
  11. hotrod56cars
    hotrod56cars
    Progress has been very slow on my project, after over a year and a half of unemployment I got a job. :)
  12. edgeabilly
    edgeabilly
    Great thread !!
  13. Yeagley
    Yeagley
    Great build! I just picked up 2 1931 Pontiac 4 door sedan bodies. They are just sheet metal. I will be doing what you are doing. I like your rocker idea. Keep it up.
  14. Normbc9
    Normbc9
    I have a '32 sedan and the wood is under attack from termites and rot. I'm just getting up enough nerve to try and tackle the replacement of the wood. I did find a supplier in New Hampshire but it isn't cheap.
    Normbc9
  15. TFoch
    TFoch
    Keep up the good work. I have a 33 Chevy Cabriolet that I'm replacing the wood with steel. I bought it in pieces and I'm slowly putting it together. Looks like you're on the right track.
  16. bald_1
    bald_1
    good lunk on that coupe .im building one also .i had all wood intact kind of made it sort of easy .anything can do give me a shout ..crhody1489@aol.com
  17. ratamahata
    ratamahata
    from Argentina
    Chevy outsold Ford especially when Henry closed the factory to begin producing the Model A and in subsequent years, Chevy, used a wooden frame for its cars, Ford used steel, one too good to last until this time...
