Projects 1931 Model A Coupe Y-Block Build (Father&Son)
Discussion in 'Traditional Hot Rods' started by NathanxStewart, Jan 4, 2016.
  1. metal man
    metal man
    You would be surprised. The sides of a Deuce shell are not perpendicular, and the lens on the directionals is bulbous, so they are quite visible even from directly in front of it. They're just as visible as the usual bullet shaped directionals that are on a lot of hot rods, including mine. Finding a decent looking front turn signal for these things that doesn't look like an afterthought is a challenge. I really can't stand those bullet shaped type, I only have them on my tub because I found a nice OLD pair made by Guide, that match my Guide 903 headlights. I like Nathan's better.
    NathanxStewart likes this.
  2. Blue One
    Blue One
    from Alberta
    That's one thing I like about the Guide 682C, the small light on top. Perfect for signals.
  3. Tim
    Tim
    from KCMO
    Any reason you made a metal insert and then put wood over it instead of just making a wood panel from the start?
  4. vtwhead
    vtwhead
    What year Dodge caravan did that seat come out of? I have looked at a few and they are all too wide but they were all 2000+???
  5. metal man
    metal man
    Nathan is gone on tour with his band, so I'll answer you guys. He made the guage panel that way to keep it thin. You see the original bead in the dash, around the guage panel? He really likes that and wanted to keep it, and also wanted to make the polished stainless ring to fit inside it, and not stick out past the bead. That's a .050" thick piece of stainless, with a thin walnut veneer on it. Solid wood would have needed to be a lot thicker. Also, he was able to make one pattern and get the guage panel and the ring laser cut to match, with the mounting holes and everything. We have a neighbor who runs a laser cutting facility and he works cheap for friends on a cash / trading favors basis. He even made him a few extras so he can do different finishes and change them out if he wishes.
    The seat is from a first generation Dodge caravan, we don't know the exact year. It was a freebie from a friend.
    NathanxStewart and Tim like this.
  6. tikiwagon13
    tikiwagon13
    All that talent AND he's in a band?
  7. metal man
    metal man
    Yes, he's been playing guitar since he was 10,and playing in heavy metal bands since he was 13. Got his record contract about four years ago, when he was 16. So sometimes that cuts into his hot rod building time. He really enjoys his band, though,and now he's playing blues as well. His coupe is his main focus, though.
    NathanxStewart and tikiwagon13 like this.
  8. Blue One
    Blue One
    from Alberta
    Name of the band ?
  9. They're LED's and pretty bright, I can't for sure say if they will be useless during the day time yet or not. But you can see them looking at it straight on ImageUploadedByH.A.M.B.1462390520.801569.jpg
    D-Russ and loudbang like this.
  10. Thank you Jim!!
  11. Death Of An Era, I'll warn you, it's very heavy hahah
  12. We were trying to come up with some cool ideas for an overflow bottle so we thought an old antique gl*** bottle would be cool. My grandfather found me this bottle at an antique mall, Old Quaker whiskey bottle. I can't remember the year of the bottle, I'm not home right now otherwise I would look at the bottle cap. When I find out I will let you guys know! This was tricky to figure out how to mount, my dad helped a lot with coming up with how to mount it, I made everything. Very happy with how it came out.
    ImageUploadedByH.A.M.B.1462391607.927170.jpg ImageUploadedByH.A.M.B.1462391629.508477.jpg ImageUploadedByH.A.M.B.1462391646.783663.jpg ImageUploadedByH.A.M.B.1462391664.871831.jpg ImageUploadedByH.A.M.B.1462391687.450465.jpg ImageUploadedByH.A.M.B.1462391727.905584.jpg
    Luke W, Fixxxr, v8paul and 8 others like this.
  13. cretin
    cretin
    I like that overflow mount. I just might think of adding some rubber isolation. And swapping that Allen head out for a flat head screw, but that's a small detail.
    Nice work.
  14. Blue One
    Blue One
    from Alberta
    The rubber isolation is a good idea, however the swapping out of the Allen bolts for flat head screws is just over the top to the point of being ridiculous.
    NathanxStewart and greaser like this.
  15. BradinNC
    BradinNC
    I prefer Allen head fasteners. Working in a injection mold maintenance shop spoiled me. They are mechanic friendly as opposed to slotted screws and of higher strength.
  16. metal man
    metal man
    This isn't the final ***embly. I'm sure that was just the first 10-32 flat head he found. It will get a phillips or slotted , domed SS screw later, and some channel tape so it doesn't rattle.
  17. Thank you sir!!
  18. Thanks guys! Like my dad said, this isn't final ***embly, a lot of the screws/ bolts I've used on the car were just bolts I found in the shop that worked
  19. Made a bracket for the switch to the air bags, it's part of one of the seat legs. ImageUploadedByH.A.M.B.1462727422.904194.jpg
  20. Made an L bracket for the fuse panel and mounted it to the floor board right under the seat for easy access
    D-Russ likes this.
  21. Inside of the car (this picture was taken before I did the veneer finish on the dash insert)
  22. Looking great Nathan!
    NathanxStewart and metal man like this.
  23. Limey Kid
    Limey Kid
    Coming along nicely.
    Cheers,
    Stewart.
  24. Dig the car and the band (checked it out on youtube)...it's a actually a little lighter sounding than what I crank out in the garage, ha! I think we are the minority of people on here that like extreme metal. Side note, I went to high school with Danny from Suicide Silence, finally got to see them live when they rolled through Oakland with Korn.
  25. Thank you sir!
  26. Thanks Stewart!!
  27. Thanks man!! Wait until you hear our new stuff, it's a lot heavier. We have a different line up than we did on the last album. I'm sure it's just me and you that do haha. What! Really? That's awesome!
  28. The car is very close to being pulled apart and finished up!
  29. 365window
    365window
    Great build. Gives me some cool ideas for my '30.
