Projects 1932 5w Coupe project continue
Discussion in 'Traditional Hot Rods' started by AULIZ, May 28, 2016.
  1. Deutscher
    Deutscher
    from Germany
    :D
    Regards Harald
    Stogy likes this.
  2. AULIZ
    AULIZ
    today I washed 2nd engine cylinderblock. I sanded orange colour increased little epoxy primer where needed, taped and painted.
    Im gonna use later model Mercury water pumps with 1936-37 truck 2row pulleys.
    Then I can install McCulloch supercharger + Cirello magneto (426cid)+ 8BA style timing cover.
    I can make 5" 2row crank pulley.
    Not easy to get all same line,.... but I have make some measurement and plan.
    Aulis
    rod-coupe1691.jpg rod-coupe1692.jpg rod-coupe1693.jpg rod-coupe1694.jpg rod-coupe1695.jpg rod-coupe1696.jpg rod-coupe1697.jpg rod-coupe1698.jpg rod-coupe1699.jpg rod-coupe1700.jpg
  3. AULIZ
    AULIZ
    4hours and I have pumps ready. I pieced those, blowed with gl***, cut neck shorter, machined pulleys inside, installed all, test measurements... Now pulleys are 10mm more near engine block than if I would install pulleys direct on shaft.
    I dont know if somebody has done this before, but now I have 1950-53 mercury pumps with 1936-37 truck 2row pulleys. Aftermarket 4.25"stroke crank has long "neck" so easy to make crank pulley. I use industrial pulley. maybe 4.5" OD or bigger if possible to use it.
    I dont have timing cover yet, so I cant make 426hemi magneto ready, but I suppose all is going OK.
    I need to make new bracket for idler and have to use Red power (obtibelt) or Hi-Power (gates). Those are better for this kind of use when v-belt is turned both way.
    a
    rod-coupe1701.jpg rod-coupe1702.jpg rod-coupe1703.jpg rod-coupe1704.jpg rod-coupe1705.jpg rod-coupe1706.jpg rod-coupe1707.jpg rod-coupe1708.jpg rod-coupe1709.jpg
    Outback, AHotRod, 63fdsnr and 6 others like this.
  4. patsurf
    patsurf
    will the idler be adjustable ?-nice work!
  5. AULIZ
    AULIZ
    Idler bracket is last job this belt drive case.
    Just today I ordered from Italy SPB 150-2 solid pulley. I make hole and my friend have "keyway slicer".
    Today I made oil line plugs (br*** = rear, black hardered steel = front) and installed those.
    Also started to install crank, rods and pistons.
    Problem with **** "China ****" connecting rods. All upper bushes are too small. those are not cylinderical.
    Pin is going 60% (over half way) when stack very strongly. When push it from another side, its going only very little and stack. I have adjustable reamer, but it´s not easy to get bushing cylinderical if bushing is like "hourgl***". I did it very very carefully and get 4 rods ready + installed with pistons and rings in to cylinderblock. 6hours 4set installation.... I reclamate to ****.
    I called to my friends who bought those 2 another 304cid stroke kits. They try to push pin thru rod and same problem. stacks very strongly. I wonder when american race, street and hot rod -parts companies are stop to manufacture stuff in China. Everytime something problems. Sometimes OK, but mostly "russian quality".
    I had my street race 1968 nova Currie Enterprice 9" rear axle. They ordered couple of Years ring & pinion sets from china...... Yes, very much problems and they lost big money when customers didnt trust them anymore.
    My car ring and pinion broken in Sweden 2019 Scandianvian finals. front wheels 1meter high in start and You know what happens when suddenly it drop down..... Oilpan broken, lower arms.... Yes, we installed new US Gear pro ring and pinion, new oilpan and fixed arms. 24h and I was racing again. China ****, damage american manufacturers reputation.
    Aulis
    rod-coupe1710.jpg rod-coupe1711.jpg rod-coupe1712.jpg rod-coupe1713.jpg rod-coupe1714.jpg rod-coupe1715.jpg rod-coupe1716.jpg rod-coupe1717.jpg rod-coupe1718.jpg rod-coupe1719.jpg rod-coupe1720.jpg
  6. Stogy
    Stogy
    I honestly think they should do better QC on the processes and product coming out and make them get it right. Obviously they are not doing that...so who's to blame...you're right their reputation is being soiled and they're letting it happen...
    Glad you can find a way around it...
  7. AULIZ
    AULIZ
    You are 100% right. You can produce stuff in "banana countries" but You need to have waterproof production control. We have here rather much foreign people working in machinery, welding ...jobs. They are coming from Romania, Bulgaria, Belarus.... They earn here much more than homecountry, but their understanding about Quality is so different than we have here. This same problem is in Far east, China. Their qulity is not stable.
    When Japan was produce very much stuff to USA (50´s....) they had very high quality level. They were (and still are) proud what they are manufacture. Japan was best subcontracting country ever.
    I can fix those bushes, but it´s expensive if need to use professional machinery company help.
    I think **** need to react.
    Aulis
    Outback, The 39 guy, patsurf and 3 others like this.
  8. Zax
    Zax
    How long are you staying in the US?
  9. AHotRod
    AHotRod
    You're doing great!
  10. 3blapcam
    3blapcam
    Auliz... I preach Chinese garbage all the time... I think my close friends and colleagues are probably tired of hearing it! I'm sick and tired of having to fix Chinese quality **** ups... And just don't trust it all together.
    I was reading a thread the other day about building flatheads and I was surprised that **** cranks will fail under boost. I guess these guys were pushing the limit, but they described them as failing quickly!
    I was planning on putting together a 304 street engine for my next car, I will be watching this closely!
  11. AULIZ
    AULIZ
    Hello
    Sorry, I was not read jalopyjournal nearly week.
    Now back home. It was only +week short visit in US.
    Very expensive travel like that and very hard when travel time 14hours side....
    Edelbrock "big letter" heads + 501 levis + 2 x racing t-shirt for me.
    Cap + 2 t-shirt for Oskar. That was all what I bring
    Today I slowly continued engine project. 4 hours to fix 4 conn.rod upper journals.
    Made gasket and installed rear cover (under flywheel), nothing else.
    Today arrived rock auto shipments. Some stuff my 1965 GS buicks, 2 x 1,6" SS valve, lifter c-clips and 2702 camshaft gear for this engine.
    Tomorrow I get SPB 150-2 2-row v-belt pulley and 1949-53 timing cover.
    Maybe get installed flywheel, oilpump and rest of rods, pistons before weekend.
    Aulis
    nb. You´r correct. China quality is not stable and they never get "western quality manufacturer reputation".
    I made my reclamation (twice, before trip and yesterday) to ****. They are not answer. I promise, I kick their *** twice aweek as long as they pay that job , I fix 3 stroke kit rod journals.
  12. 3blapcam
    3blapcam
    Good! I hope that works out for you and **** pulls through!!! I love and hate Speedway... love them because they have stuff in stock and it ships quickly, but hate that it's mostly Chinese GARBAGE.
    I believe you'll keep us updated on any communications with ****, but I really wish there was an affordable alternative!
    3blap.
    Outback likes this.
  13. 19Eddy30
    19Eddy30
    from VA
    I watch / look @ your & other build's,
    There are Quite a few that are well built
    Detailed Ect, .
    I have same ***** about quite a few manufacturers now "Quality"
    "" Just asking """, after One or Two times
    Any one dealing with issues with parts Recived , Manufacturer or company does not take care of issue,,, Most time they try to say it's You Not them. Look to another , In this case , seem you are a Die Hard F -H user they can be Expensive , 10-15 K why not look into having Custom or well known /manufacture company to make part ? ****t is low Quality performance Part , better then stock some time's.
    I also know you are not in states so shipping is not cheap or have to do a relay shipping , parts sent to friend here
    Then to you because certain companies will not ship overseas , Not trying to spend other's $$ my pockets are not so deep either, But if I need a 1,500-2 k crank , same with Rods , piston's I have made , when not off self Quality part's.
    Why not to save the Headache ,
    taken a chance that crank break's ect , taken out
    5-8k below heads . I do not know any thing about your Country Is there No one there that can tool up & make custom parts ?
    Outback likes this.
  14. AULIZ
    AULIZ
    Hello
    You´re correct. Many companies products quality is lower than 10-20y ago.
    I think this kind of **** cast crank is enough OK for normal hot rod use. I know, problems are come thru if You have methanol FED or other racing combination and parts are made in "far east" as we say here.
    I wonder how they can make upper pushing like hourgl***. If somebody is manufacturer, have all machines, rods look normal good H-profile stuff with ARP bolts and upper bushings are not cylinderical inside.... How it is possible to hone it like that. OK, my working in garage is free, it takes just little time, and I can fix those, but what about those who can´t do it or they are afraid to fix it...
    Next summer we spend 5-7 weekend in racetrack. Yesterday I send money to Alabama. I bought racecar, Oskar is driver and Im only and one mechanic. 3years I have try to find interesting drag race car and now I found it.
    Need to do something else than only hot rods, feels good to cut and change what to do.... I can left my 1965 GS buick to daily summercar use.
    Yesterday I drove to my old friend place. He was bore and hone another friends French Flathead cylinder block while I was in USA. He told that difference between normal flathead blocks and those French are big. Material tickness, overall quality is very much better. I didnt know that. I have used just those 59A blocks....
    Saturday morning 8.00. Now need to continue engine building. Oskar is come after few hours. I have big working list for him. His side of my garage is like after bomb attentat...
  15. 19Eddy30
    19Eddy30
    from VA
    Myself I have heard /know of the French block, I do not Really remember
    The history of , I do know it's a much heavy duty block, I think it was for military use ? I don't know quite how long it's been because time kind of flies but it seems like maybe five years ago somebody had found military surplus
    NEW in crate's blocks or complete that were for sale either here on the HAMB or Ford barn,,
    Also I do not know for sure if it came to be reproduced but Someone was advertising /marketing aftermarket flathead blocks.
    Deutscher likes this.
  16. AULIZ
    AULIZ
    Yes, if I remember right they still made those blocks 90´s. Its +20kg heavier than normal 59A, 8BA style blocks.
    Today rest of rod-piston sets installed and are tighten right torque.
    Also installed camgear. I decided to use 400jr cam.
    Oilpump and pick up test installed. Im sure if I have flywheel bolts. If not, Monday I need to buy those.
    Edelbrock heads looks OK, Old head studs UNF and UNC thread need to fix.
    also installed 1/2" plugs to waterpumps. There is extra hole those 49-53 waterpumps which need to plug when block
    is early pre 1948.
    Aulis
    rod-coupe1721.jpg rod-coupe1722.jpg rod-coupe1723.jpg rod-coupe1724.jpg rod-coupe1725.jpg rod-coupe1726.jpg
  17. Tim_with_a_T
    Tim_with_a_T
    That’s a sweet oil pan!
  18. AULIZ
    AULIZ
    Thanks Tim.
    +10y ago I made those. Still few left. 2pc "semiready" and this one ready.
    Simple as builder himself.
    End of this month they have Ekens G***ers swapmeet in Stockholm Sweden.
    Oskar and I are drive there. I need to remember take those 2pc and sell there.
    Swedish are cool hot rodders even their money is more like "monopoly" money...
    :D
    Aulis
    Outback, Tim_with_a_T, NoSurf and 3 others like this.
  19. j hansen
    j hansen
    Hey,,,I resent that:D
    Outback, NoSurf, lurker mick and 2 others like this.
  20. AULIZ
    AULIZ
    Hahaaa,.... That was good pics. Tre Kronor money is now smaller. Earlier sizes were bigger. Still value is weak. If I get Krowns, Euro value is too small..
    I remember "lakan" 1000kr, was huge "old size". Lakan means english bedsheet.
    It was huge size.
    AH
    Flathead sounds are like birds singing.... :
    1) coupe outside of garage , when painted stuff
    20251102_130638.mp4
    2)Roadster yesterday
    20251101_150717.mp4
  21. AULIZ
    AULIZ
    timingcover flywheel and oilpan installed.
    ah
  22. Tim
    Tim
    from KCMO
    Such a cool oil pan!
    clem and j hansen like this.
  23. AULIZ
    AULIZ
    All 48pc old head studs are rebuilt today. Also fixed old original Howard Johnsson -lifters.
    Rest of time I used making measurements concern 426hemi magneto. I lathe it to fit this engine.
    Magnetos final position is 60mm lower than it is now in pics
    Aulis
    rod-coupe1731.jpg rod-coupe1732.jpg rod-coupe1733.jpg rod-coupe1734.jpg rod-coupe1735.jpg rod-coupe1736.jpg rod-coupe1737.jpg
    A
  24. 59sedandelivery
    59sedandelivery
    I LOVE to watch AULIZ work and progress!!!!!! And yes we have large problem with chinka junk being sent back to U.S..... We used to make and machine TOP quality parts here @geee...eeeee... now we cut the tarps and rinse the cosmoline off and hope for the best from arounf the world.....
  25. AULIZ
    AULIZ
    Yes, I know TS is good for this car.
    6.0 spec frame etc. 3-4 tubes more, under 6.0 frame but we dont need that.
    Car is race ready. Oskar is driver and first we use 1150hp 582cid (nat aspirated). Later next summer with NOS (1800-2000hp).
    If all works, next winter I will modified engine. F3 procharger.
    No ******** racing. Only for fun only I and my son.
    Yes they race here ProMod (1/4mile) and TS (1/8mile). I dont have so much money that we can race under 4sec 1/8mil or 5sec in 1/4mile.....so we just race and learn, enjoy. I hope car is as nice as it looks and what parts are used....
    Hot Rodding is built hot rods, Racing in salt lake and track (drag racing).
    We dont have salt lakes here (nearly 200 000lakes in Finland, but no salt), so Hot Rods and Drag racing are possible. Dark long winter is now coming,... and spring need to have toys for fun...
    Aulis
    No, too much hot rods. I want to built those future too. If all the time built those,... not good for health.
    Vintage racing is not big deal here, I had FEDs but not cars, or those are not real thing like mine was.
    Yep, if somebody things that few pics of topic is too much, they remove it or pics.
    Everytime after that (they have done that many things) I stop increasing pictures.
    I feel that I have try to keep one style hot rod building channel open.
    Im learning daily, I hope somebody get some inspirations sometimes.... Here in Hamb is so much not so "important" topics...
    Zax, 19Eddy30, hotrodA and 1 other person like this.
  26. AULIZ
    AULIZ
    Days are gone fast.... Weekend we were see my father in North-Finland. Sunday evening I and Oskar removed and pieced my F-150 Roush pick up driver seat. Monday I left it to Vaasa city (40miles from here. Westcoast) where Miss Paula has her upholstery company. Now she has fixed seat, tomorrow I need to pick it up. She made my 5w coupe interior too.
    Monday-Tuesday I pieced my trailer. Its Stainless steel, homemade, yearmodel 1998. First time one compact wheel bearing was bad condition. OK, bearings are free for me, all brake wear (shoes, springs) for two axle was only 60euro, new brake cables 85euro. Tomorrow need to put all together and trailer is ready for inspection (every 2nd year).
    If You didnt know we have mechanical brakes in trailers, caravan.... I have electric brakes in my 24' haulin closed US trailer.
    Today worked with flathead engine. Friday all valves were installed. Today just worked with magneto. Cirello 426hemi magneto is now fit to flathead. I need to buy magneto coil, then ignition is OK.
    6" OD 2row crankpulley is "semi ready". Im test and tune little more bigger crank pulley. I get more RPM to McCulloch... Im porting orig. early 30´s intake manifold to get better flow...
    Aulis
    rod-coupe1741.jpg rod-coupe1742.jpg rod-coupe1743.jpg rod-coupe1744.jpg rod-coupe1745.jpg rod-coupe1746.jpg rod-coupe1747.jpg rod-coupe1748.jpg rod-coupe1749.jpg
    63fdsnr, Deutscher, Outback and 2 others like this.
  27. Ryan
    Ryan
    ADMINISTRATOR
    Obviously guys... We don't feature Pro-Mod stuff here. If you want to post it, please use our off topic forum.
    Troublemaker427, Tim and Outback like this.
  28. Chris L.
    Chris L.
    @AULIZ how is the flathead coming along? I ***ume the weather there has changed from driving hot rods to working on them in your heated garage. I'm always looking forward to your updates!
    3blapcam likes this.
  29. AULIZ
    AULIZ
    flathead is ready, just continue with hot rod.
    Ryan, or somebody else can continue posting project pictures.
    I have try to send pics daily/weekly. I know that many hate that, but I think
    I have show that You can make very much things alone, low price, not need expensive machines or pro investments.
    I have think, that maybe somebody has "seen light" and realized something from my postings. Inspiration, function, trying, failure,.... those are part of way to goal.
    Promod is hot rodding. too. much more than many other things. Few pic of my 30-40years dream is too much. This was still 99% my hot rod topic, couple of pics are too much --> so no pics anymore. You can delete all topic. Ryan can do it, he is King, Im just nobody from nowhere.
    Yes, no updates. Maybe Ryan is wrote something what he is doing in his garage?!
    Yes, Im again there (garage) tomorrow morning 5.30
    Aulis
  30. 3blapcam
    3blapcam
    Auliz... what was that Mag for originally? It's super cool looking!
    3blap.
