1932 Chevy coupe
Discussion in 'The Hokey Ass Message Board' started by logride, May 12, 2012.
  1. TFoch
    TFoch
    Are you going to replace that wood with steel?
  2. logride
    logride
    from CB IA
    No I made new sill plates and had the wood from 2 cars. I used the stuff that was solid and made some new parts. It's way more solid than I had imagine it would be.
    The progress has come to a very slow crawl. Too much work.
    I have a few little projects I would like to do sometime soon.
    Put 7" outers on the chevy rims for the rear. I found some 8" rims but they are to wide for the fenders.
    Also I would like to dissemble it and sandblast the frame and body and give it a coat of epoxy primer.
    Just need to find some time.
    volvobrynk likes this.
  3. Brads MONSTER
    Brads MONSTER
    from Buford GA
    Look good just hammer down and you will be done in no time
  4. 31CHEVY
    31CHEVY
    Some white spoke wheels have 12 5/8 centers. I searched the swap meets for a pair 7 in. wide and found a pair off a trailer. I am going to the same thing with a pair of 53 chevy wheels.
  5. themoose
    themoose
    Looks great.....This thread brings back memories for me. I bought my 32 in 1972 and working on it between other projects finished it in 2009 so your making much faster progress than I did. Stay with it, they're great cars.
  6. logride
    logride
    from CB IA
    Hey Moose any parts left over?
  7. logride
    logride
    from CB IA
    I got a shifter out of a 54ish chevy wagon with a powerglide. I was working on mounting it to the original 32 coullum. It was going well and looked like a small project that I would have some good success with, But when I went to take the shift linkage off the side of the 700r the shaft twisted off! SOB. When I put the Painless wiring kit in the ****** Ill replace the shaft. It just makes it it hard to mock up now.
  8. PBRmeASAP
    PBRmeASAP
    Looking good. I got a soft spot for 32 Chevys.
    Did you ever find your fenders? They are still available as repoped steel, and there are gl*** ones. I have a good workable set also that might be available but they are being used a mock up currently
  9. logride
    logride
    from CB IA
    I haven't found rear fenders yet. If I can't find some decent ones I will probably buy some repop steel ones as it gets closer to needing them. Right now I'm doing low cost grunt work.
    Also I'm looking for a front splash apron for a 32. I do have front aprons for a 27 and one for a 31.
  10. logride
    logride
    from CB IA
    Here are extra parts from the 32. a pretty much rust free cowl and the part over the windshield not sure if someone wanted to make a 32
  11. logride
    logride
    from CB IA
    Hey PBRme asap could you pm me some pics of the fenders?
    Thanks
  12. themoose
    themoose
    I did have some body and miscellaneous small parts but I put them on CVVA Chat and a guy from New York came and bought everything I had.You can put a want ad on VCCA Chat and you might be able to get what you need.I've had pretty good results there .Sign up for free at http://vcca.org/forum/
  13. logride
    logride
    from CB IA
    Hey thanks. I have looked at it but haven't posted any thing yet.
  14. UNSHINED 2
    UNSHINED 2
    Boy that thing has come a long way since I stopped over for that Hemi!!
    Lookin' good!!
  15. logride
    logride
    from CB IA
    Hey thanks Dane, Do you need a bell housing and 3 speed for the Red Ram? I may know of one.
  16. UNSHINED 2
    UNSHINED 2
  17. TFoch
    TFoch
    Any progress lately?
  18. PBRmeASAP
    PBRmeASAP
    damn just saw this....if you want pics, pm me, but may still need them for awhile
  19. jimstro16
    jimstro16
    I like it, Im building a '32 chevy also but its a tudor sedan. The metal work is taking for ever to make it look right. Mine should have been s****ped but saved it instead. Been working on it, on and off, for over four years. Getting close though.
    I took the easy way out and replaced the wood with metal. I had the same plans originally with mine, I planned to fill the roof with exposed wood on the upper and lower.
    Its a great look, Good luck with it.
  20. Normbc9
    Normbc9
    Not a coupe but an original family Confederate Standard sedan with a full pressure 216, T-5, open dive and Gear Vendors OD (3:43 final drive) and it runs good. Fun car. Good luck with you beauty. 27 MPG too!
    Normbc9
  21. logride
    logride
    from CB IA
    Hey PBR, I just saw your post. Last week I broke down and bought some reproduction steel fenders, but I do still need a taillight stand, p***enger side side hood. and a few misc pieces. I have made a little progress should post some pic soon.
  22. chopper526
    chopper526
    from Phila., PA
    Hey, just caught this build, very nice! You are really moving FAST! I'm doing a '32 Chevy myself, check out my build. I replaced all my wood with metal. It's not such a tough job, in fact, maybe a little easier than trying to fit wood back in. Keep posting, and more pictures!! Good luck.
  23. logride
    logride
    from CB IA
    It's been a while since I posted any progress. Here is a picture while it was at the exhaust shop. I had 2" duals with 24" gl*** packs. I have started it and it cackles.
    You can also see the drop blocks that I made. I reversed the eyes on the main spring.
    It is a S-10 rear.
  24. logride
    logride
    from CB IA
    Yea it's suposed to have a chevy. It's a $100 surban 5.7 with a bow tie marine intake. short water pump, small cap HEI. The radiator is for a 32 ford but fits great. It has a 700R4 with the painless kit.[​IMG]
  25. logride
    logride
    from CB IA
    Here is a picture coming home from the exhaust shop. as you can see I have blasted the body and covered it with epoxy primer.
    The wheels are 49 chevy, the rears have been widened with outers I bought off craigslist.
    I was thinking of painting it patriot blue, but I like the straw colored wheels with the black. plus I am crazy about red interiors. That probably would look better with a black exterior. At least to me.
    It was a good day. Driving the convertable followed by the coupe.
    By the way. Where are all the corvettes that are missing the engines? Did they crush them like the suburbans?
  26. chopper526
    chopper526
    from Phila., PA
    Very nice................
  27. logride
    logride
    from CB IA
    I like the Bias ply look. but the fronts are too tall. so they will get replaced. I want to put radial wide whites on it. I welded a quadrajet base in the bottom of the old 2bbl air cleaner.
  28. TFoch
    TFoch
    Looking good! I like it!
  29. logride
    logride
    from CB IA
    Hey thanks, every thing is still loose but it's getting closer. The column shifter works, I made a drive shaft for it, lots of little things. I have repo steel rear fenders that aren't in the pictures.
  30. themoose
    themoose
    Really taking shape.......Keep us posted!
