1932 cross steering (No Vega)
Discussion in 'The Hokey Ass Message Board' started by HotRodMicky, Feb 26, 2010.
  1. HotRodMicky
    HotRodMicky
    Hi,
    i tried a 35-38 Ford cross steer box in my `32 frame.
    The column shaft is too short if i place the box where it belongs.
    Are 42-48 boxes longer?
    If so by how much?
    I have another box with column shift but don't know if its just a `40 Ford.
    I will use it without a U-joint.
    Regards
    Michael
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    Why cant you extend the column shaft with an extended steering shaft to meet the box you have?
    Good U-joints are safe.
  3. krylon32
    krylon32
    from Nebraska
    Try to find an atricle on the Ken Gross deuce. It shows a installation like yours and what he did.
  4. oldrelics
    oldrelics
    from Calgary
    I have 42-47 pu steering box/column in my A, it is couple inches longer than my 40.
  5. HotRodMicky
    HotRodMicky
    Yes i can, but i rather have the "proper" box.
    There is no need for a u-joint in my setup.
    If you can find the Ken Gross Article would be great!
    TIA
    Michael
  6. HotRodMicky
    HotRodMicky
  7. I also have a 47 ford pickup steering box and column in my A coupe. Tight fit but I wanted to keep it pre 50s.
  8. HotRodMicky
    HotRodMicky
    No more suggestions?
  9. lowsquire
    lowsquire
    from Austin, TX
    I did it. extended the shaft with a spare shaft i had, Built a new column.
  10. HotRodMicky
    HotRodMicky
    Ah, that looks good!
    Thanks
    Michael
  11. barry wny
    barry wny
    I used the whole '37 frontend (A frame) and I had to go with a joint. Also the drag link going across to the right spindle was too long. Shortening is eady, finding someone with the right die to re-thread is tough. Only regret is I lost the original horn wire with the joint, but the gearbox and wheel position came first IMO. For the record I have a '49 pickup unit and worked to position it for some time, the push-pull steering required the aftermarket hoop be bent offset, interfeared with the lever shock linkage and generally looked "hokey". Cross steers like a dream, doubt the support bearing is needed but easy to do and I wanted it right. Later built headers around it, the most fun project on it.
