Technical 1932 Ford 12V Pick up & Float Assembly
Discussion in 'Traditional Hot Rods' started by Airborne34, Oct 10, 2020.
  1. Airborne34
    Airborne34
    from Texas
    I’ve done a search but haven’t found exactly what I’m looking for. Is there a 12V pick up and float ***embly available that will bolt into the stock Original 1932 Tank? I’ve found several pick up units that would work, but nothing that combines the pick up and float ***embly.
    Re-Pop tanks seem to have two holes, one for each system.
    Overall I’m looking for options to use my stock, original tank, but have upgraded fuel pick up and indication.
    Volume and pressure will be low, engine is a warmed over Riley Two Port with stock fuel pump.
  2. WiredSpider
    WiredSpider
    Not that I know of
  3. Airborne34
    Airborne34
    from Texas
    So how are the traditional guys doing it? Are my only options to replace the tank or use a paint stick to measure the fuel?
  4. HOTRODPRIMER
    HOTRODPRIMER
    In the past when using a original tank I have simply drilled another hole for the 12 volt sending unit and leave the original fuel pickup in place. HRP
  5. alchemy
    alchemy
    I used a standard Stewart-Warner sender, poked through the original hole with some redrilled screw holes to match. I welded a bung into the top of the tank for a new pickup tube. I welded another bung for a vent with a rollover valve on it.
  6. Atwater Mike
    Atwater Mike
    @alchemy: Wasn't (isn't) there a large flat washer-type adapter that bolted onto the stock Deuce holes, then accepted the S/W type sender?
    I may have this confused with the available F100 tank type, ('55 under floor) but seem to recall a bolt-on for S/W on my Deuce. (that was back in '58...memory dims)
    slug and olscrounger like this.
  7. alchemy
    alchemy
    I think there is, but why buy an adapter when I could solve the problem with a drill and tap? I needed to clean the tank out anyway since I was welding in the bungs.
