1932 Ford 3 Window Steel
Discussion in 'Cars For Sale' started by scott Hrncirik, Jul 27, 2025.
  1. scott Hrncirik
    scott Hrncirik
    City: Spring Branch
    State: TEXAS!
    Price: 52,500
    1932 Ford with a Ford motor!!
    This car was just finished with about 1k miles. It still needs the turn signals wired up. I just bought a windshield frame and side guides but still need the hinges. The car runs great but still has a couple bugs to work out to make it drive as good as it runs. I have drove it on trips of 60 miles each way and always gets me home. The car was in a few magazines in the early 70’s and early 80’s (I have them). Please feel free to reach out with any questions.
    • Henry Ford steel body w/ 4” chop
    • I have a steel hood and side panels with fibergl*** fenders and running boards. I pushed the radiator forward about an inch for fan clearance so the hood may have alignment issues (or shorten the fan)
    • 239 Ford Y-Block just rebuilt .80 over. (New: fuel pump, starter, alternator, radiator hoses, belts, remote oil filter etc)
    • Tremec 5 speed (world cl***) fresh rebuild
    • New clutch, pressure plate, flywheel and adapter plate from Modern Drive Line
    • Winters quick change rear end with Howe hubs
    • 6” drop axle with hair pins from Speedway
    • Thunderbird Special valve covers
    • New Petronics w/ Flame Thrower coil
    • New drive shaft
    • Disc brakes all the way around (new calipers)
    • All new brake lines
    • New master cylinder
    • New slave cylinder
    • New 18 circuit wiring harness
    • New gauges
    • Bench seat (Dodge Caravan), I also have bucket seats.
    • New shocks (friction up front and conventional in the rear
    • New Speedway Strombergs w/ progressive linkage
    • New fuel regulator and fuel lines
    • Smitthys mufflers
    • Ram horn exhaust manifolds
    • New tires
    • New steelies
    • Trunk lid is rumble hinged
    • Stainless steel fuel tank
    • Floors have been matted heat/sound mat
    • New battery
    • 1954 F1 steering box/column/wheel
    • Power windows
    • Windshield frame from Mr. Roadster
    • Filled cowl vent (wish it still had it)
    • New mono leaf springs front and rear
  2. scott Hrncirik
    scott Hrncirik
  3. scott Hrncirik
    scott Hrncirik
  4. scott Hrncirik
    scott Hrncirik
    Henry Steel price drop 40k.
