Projects 1932 Ford 5W Project "Marooned"
Discussion in 'The Hokey Ass Message Board' started by AV8R, Aug 9, 2015.
  1. AV8R
    AV8R
    Thanks! Got some 18" wheels for the back and some tall firestones... but 18" wheels are TALL. Might have to to take a spring out of the back to get it to sit right
  2. brady1929
    brady1929
    Amazing
    AV8R likes this.
  3. IronFord
    IronFord
    from NoDak
    Any updates?
    AV8R likes this.
  4. grumpy32
    grumpy32
    from Australia
    This is great, any updates......
    AV8R likes this.
  5. 3wLarry
    3wLarry
    from Owasso, Ok
    hey you...don't leave us hangin'!...updates please
    AV8R, brady1929 and Moriarity like this.
  6. AV8R
    AV8R
    updates it is! here are some photos with the finished drivers door and wood kit almost finished! The wood parts are from united pacific and fit great like all their stuff. I'll try to get the car rolled out of the garage so I can take one of the whole car.
  7. Hendee
    Hendee
    Chris,
    Loving your project and learning a lot for mine. Can I ask for an update?
    Tom
    AV8R likes this.
  8. McFly
    McFly
    Looking good Chris. How is the roadster?
    AV8R likes this.
  9. El Hueso
    El Hueso
    Beautiful work!
    AV8R likes this.
  10. cully33
    cully33
    Great work you are a true craftsman.
    AV8R likes this.
  11. AV8R
    AV8R
    McFly, What do you call a response that is 7 years late? I think you already saw it, but the roadster is back in Cali where it probably belongs. Great car and went to another great owner. Had to sell it to fund the 32 build. :)
  12. The37Kid
    The37Kid
    Good to see an old build back on top!
    Bob
    AV8R likes this.
  13. AV8R
    AV8R
    Finally back to working on this car. Had 2 kids in the mean time but am starting to find some time to build again :) Metal work is mostly complete.
    29EHV8, 35cab, Gasser 57 and 9 others like this.
  14. AV8R
    AV8R
    And started to mock up the front so I can see how much room I have for the engine. 20230715_145736.jpg 20230723_162011.jpg
    rod1, Gasser 57, Dirty Dug and 11 others like this.
  15. AV8R
    AV8R
    finally back at it :)
    IronFord likes this.
  16. AV8R
    AV8R
    wish I could take credit, but a buddy and 2 good local shops have done a lot to get it where it is now. I try to do what I can, but I don't have a planishing hammer or the skills to use one yet. I'm happy to do what I can.
    SS327, Algoma56 and seadog like this.
  17. pprather
    pprather
    Glad you're back and still making progress on the rod.
    AV8R likes this.
  18. The37Kid
    The37Kid
    Bare metal for how many years now, what is your secret?
    AV8R likes this.
  19. AV8R
    AV8R
    Alberta is pretty dry, so you can just leave it sit indoors and be ok
    norms30a and The37Kid like this.
  20. Fortunateson
    Fortunateson
    Looking good. An inspiration for sure! When done you’ll have to drive it over to Bruderheim and “Strong’s Garage”...
    AV8R likes this.
  21. AV8R
    AV8R
    I Bought a 312 Y-Block from a fellow Hamber. It has a ECZ-6015-C block, ECZ-G heads that were rebuilt by Tim McMaster with hard seats, larger than stock (1.94/1.60) stainless valves, and fully pressurized high-ratio rockers. A big shout out to Modern Driveline for their expertise in driveline components to get the Y-Block hooked up to a T-5. And thanks to Kustom King in Spruce Grove for getting them dialed in. I'm going with cast valve covers later when its installed in the car.
  22. AV8R
    AV8R
    Y block is mocked up but want to lower it about an inch. In order to that I have to find a water pump with a high-level fan location. Otherwise it interferes with the lower rad hose. 20240105_143434.jpg 20240105_143429.jpg I heard truck ones are different, so will start researching that a bit.
    LAROKE, loudbang and Kreepea_1 like this.
  23. Corn Fed
    Corn Fed
    I haven't heard of a raised Y-Block water pump. Are you sure you aren't confusing it with a W (348/409) Chevy? They had big trucks with raised pumps.
    If it turns out Ford did the same thing that would be interesting.
    I personally would just raise the engine up to clear the hose. I have a 312 in my Model A and it doesn't have clearance issues up front. A 32 wouldn't be much different.
  24. Corn Fed
    Corn Fed
    You should get yourself a single lower pulley and remove the spacer behind the fan. Then you can move the engine forward and gain some firewall clearance.
    In my A I had to make a recess for the distributor, but I didn't have to completely cut the firewall away for the valve covers. Maybe you will get luck too.
    AV8R and deathrowdave like this.
  25. AV8R
    AV8R
    Thanks! Yeah, there is a truck water pump that sits higher.
  26. AV8R
    AV8R
    Thanks for the help. That would save some space for sure. Also thinking maybe an electric fan would help tons. I know it's not traditional, but could hide it with a nice rounded shroud?
  27. nochop
    nochop
    from norcal
    Those birds got a mean setback
  28. 52lomofo
    52lomofo
    Hello from Fort Sask
    AV8R likes this.
  29. Rob28
    Rob28
    from Calgary AB
    I’m liking where this is going nice 32 and another Alberta HAMB car. Will look forward to seeing you put this together. Having 2 kids will slow you down at least that’s my excuse for taking 8 years to put my Roadster together
    AV8R likes this.
  30. 19Eddy30
    19Eddy30
    from VA
    If your tig/ mig Aluminum, alter the lower radiator hose outlet that's on the driver side,
    As move outlet 50/50 towards corner of tank , so half diameter of the outlet cir***ference is on side of tank ,
    Or make a L ish shape square / box drop down then add round outlet ,again 50/50 corner of tank image.jpg
    Irish Mike, Algoma56 and AV8R like this.
