Projects 1932 Ford 5W Project "Marooned"
Discussion in 'The Hokey Ass Message Board' started by AV8R, Aug 9, 2015.
  1. Rickybop
    Rickybop
    Missed this first time around.
    Neat to see how far it's come.
    Congrats on a great save.
    And your two little hot rodders.
    AV8R likes this.
  2. dirt car
    dirt car
    from nebraska
    Good to see your 5w back, I'm into the 5th. week of tackling my 5w that has occupied a corner of my barn for a couple of decades, completed the ch***is the past 2 seasons, now comes the body which happens to be the #45 roundy round & formally my v8 avatar that Rocky posted earlier on this same thread. Trying to retain as much original metal as possible but must admit overwhelming on a vehicle that has been bottom side up on two occasions & beat out time & again during its racing heritage. Ron
    29EHV8 and AV8R like this.
  3. AV8R
    AV8R
    So after some research I found out that the T-Bird y-Block 312's have a 1 inch spacer behind the water pump and an extra 1 inch in the balancer/ double pulley. So if I swap the balancer for one with no space, take the water pump and fan spacers out and go down to a single pulley, I'll be able to move the whole motor forward almost 1.5". Get the grinder out! haha
    Tim, Kroombit and pprather like this.
  4. AV8R
    AV8R
    20240109_121132.jpg Motor is moved forward and much happier with its new location. Next up is the firewall and floor.
    Tim and Algoma56 like this.
  5. AV8R
    AV8R
    Tim, pprather and norms30a like this.
  6. brady1929
    brady1929
    Floor looks awesome.
    AV8R likes this.
  7. AV8R
    AV8R
    Tim, The 39 guy and earlymopar like this.
  8. AV8R
    AV8R
    Firewall is sorted out now. Moving the motor forward allows for a nice straight firewall. 20240118_152926.jpg
    29EHV8, loudbang, 40FORDPU and 2 others like this.
  9. Firewall looks great! I remember when a flat 1/8" or 3/16 plate was used for a firewall, then it would be chromed. Looked really good, but now days I like the original firewall with the original stampings, just like you did. Good job!
    Gasser 57 and AV8R like this.
  10. nochop
    nochop
    from norcal
    My dad did this one. 1/8 inch plate mated to original firewall hoop IMG_5990.jpeg IMG_5989.jpeg
    Just Gary, Tim, loudbang and 2 others like this.
  11. AV8R
    AV8R
    Playing around with tires. I have a set of 18" wheels for the rear and the 7.00-18 firestones are tall!! I'll need to find a way to bring the rear down 2 or 3 inches. 20240120_103105.jpg 20240120_103059.jpg
  12. AV8R
    AV8R
    IMG_20240123_181012.jpg Tire is sitting in the right spot now. Man these have a lot of side wall, hopefully a soft ride. haha
    40FORDPU, Tim, treb11 and 4 others like this.
  13. Happydaze
    Happydaze
    7.00 x 18 look great, but I am bias in that regard! Lost a cap that day :(
    Chris
    Tim, Tim_with_a_T, 35cab and 2 others like this.
  14. AV8R
    AV8R
  15. AV8R
    AV8R
    Thanks Ron! I know what you mean about saving as much as you can. I tried the same. Was more work to save more, but makes me feel better for some reason :) good luck with the rescue!
  16. AV8R
    AV8R
    Exhaust is tucked in tight and almost done. P***enger side shows the finished routing. Drivers side still needs to come out just as far. 20240206_074808.jpg 20240206_074907.jpg
    Deucedreamer, Oneball, rod1 and 8 others like this.
  17. doctorZ
    doctorZ
    the build looks great! i'm glad you're leaving it unchopped, too!
    AV8R likes this.
  18. Tim_with_a_T
    Tim_with_a_T
    I didn’t notice the rear spreader bar detail until today. That is an awesome touch!
    Tim and AV8R like this.
  19. AV8R
    AV8R
    There was a bit to coordinate on the drivers side in order to fit it all within the hood sides. I'm happy with the final engine mount location and header routing. Still need to clean up the welds and remove the header tag on the "borrowed" tubes.
    Tim, simplestone, mvee33 and 2 others like this.
  20. AV8R
    AV8R
    Rear end is together and filled.
  21. AV8R
    AV8R
    Exhaust is done! Tight fit to snake it through to the sides of the tank.
  22. AV8R
    AV8R
    20240406_112721.jpg 20240406_112738.jpg Intake is back on and all the pulley work is done. This means the rad can stay in the factory location.
    Tim, Oneball, x77matt and 4 others like this.
  23. AV8R
    AV8R
    Sitting back on the ground I'm happy with how low the rear wheels sit.
    Tim, Rob28, norms30a and 7 others like this.
  24. Your '32 is looking great, Chris! So glad the 312 found a great home, and it looks just right in there...and it saved me the "task" of buying another car to put it in...haha
    I did get the 349 stroker in the T-Bird up & running, so the whole deal really got my act in gear!
    Keep on going!
    AV8R and chevyfordman like this.
  25. AV8R
    AV8R
    Always thought it would be tight for the pedals. They are mocked up with some offsets, but still need to do something with the gas pedal. Steering drop, shaft and wheel are all in and happy with the look.
  26. alchemy
    alchemy
    With a s**** pedal you need a spot to rest the side of your foot. At least I do. I think the side of the trans hump will work good.
    AV8R likes this.
  27. Cant believe I didnt see this threas before!
    Great find, awesome save, *****in build!
    I have a '32 Fiver that has alot of history as a chopped n channeled hot rod in the 50s here in BC. The cowl ended up getting cut off about 3 inches in front of the doors, so need a complete cowl to fix this thing then I can get at it!
    @AV8R I will send you a PM.
    AV8R likes this.
  28. AV8R
    AV8R
    Tail lights are ready to go. They had the light for the license plate, so I made little covers to block them off.
    Tim, loudbang and Deucedreamer like this.
  29. AV8R
    AV8R
    Switched the fuel lines to hard lines and the air cleaners are on. Also used a truck y-block inlet for the intake.
  30. hotrodA
    hotrodA
    Wow!
    Had to go back to the first post. What a transformation! It’s been a long haul, but well worth it.
    Keep the updates coming. BTW, it looks like you have a petroliana addiction as well. Great!
    AV8R likes this.
