Hot Rods 1932 Ford Electrical Panel Ideas
Discussion in 'The Hokey Ass Message Board' started by Airborne34, Jun 2, 2022.
  1. Airborne34
    Airborne34
    from Texas
    Folks, I’ve been looking for one of these panels or something similar. HAMBER. “Justinv” was making them but no longer.
    Aside from making something myself, does anyone have ideas or a source for something similar. Thanks 7684C7BA-2296-4F00-A3AF-AE376D4968D1.jpeg
  2. alchemy
    alchemy
    I am way too old and crickety to put the wiring panel on the driver's side again. If it needs work I can't fit up in there between the steering, pedals, and seat. I'd much rather save my back than a couple feet of wire.
    The37Kid and Johnny Gee like this.
  3. 302GMC
    302GMC
    from Idaho
    Pontiac fuse panels used from '49 to '54, complete with the snap-on metal cover which has a map to the one you're looking for.
    They're getting hard to find in good shape.
  4. woodiewagon46
    woodiewagon46
    from New York
    Restoration Supply Company, www.restorationstuff.com, 1-800-306-7008, part number ELE403 is a 6 circuit fuse block. They also make them from 1 to 5 circuits also. Ask for a catalog, it has a lot of hard to find restoration items.
  5. pprather
    pprather
  6. PhilA
    PhilA
    I have this one if you want it. 6 circuit.
    302GMC likes this.
  7. 19Eddy30
    19Eddy30
    from VA
    Is op looking for the panel ?
    Cardboard for template.
    I make my own using the gauge tunnel bolt holes ,
    & a MSC catalog or electronics vendor for fuse power distribution blocks ,
  8. swifty
    swifty
    I made my own out of flat panel steel sheet similar to that in post #1, fuse panel on the right hand side and relay panel on the left of the dash tunnel. Offset them an inch into the ****pit to allow clearance for the Nutserts holding stuff on the panel.
    Fuse panel from Rebel Wire and relays from our local auto elec outlet.
  9. goldmountain
    goldmountain
    I would make my own panel out of stainless steel and mount it on the p***enger side where there is way more room.
