Hot Rods 1932 Ford Front Frame Horn Availability
Discussion in 'The Hokey Ass Message Board' started by YBNormal, Jun 20, 2024.
  1. YBNormal
    YBNormal
    from Oklahoma
    Is there anyone making reproduction 1932 front frame horns? I need a left/drivers horn for a frame I'm working on. I see several places offering them for the A's but I haven't found anything for the B. I wrote to American Stamping but they don't make them.
  2. JohnLewis
    JohnLewis
  3. wheeltramp brian
    wheeltramp brian
    I would call around to local hot rod shops. Recently got a frame made by blackboard Hot rods that bobbed the frame horns and tucked them in. So I know they have a set laying around somewhere.
  4. YBNormal
    YBNormal
    from Oklahoma
  5. YBNormal
    YBNormal
    from Oklahoma
    That was the next step if I couldn't find them on the web. I thought the same thing, "what happened to all the horns that were lopped off?" Gotta be a bunch stuffed in shelves. Thanks!
  6. 325w
    325w
    RJays Speed shop had rear cut offs to sell.
  7. pprather
    pprather
  8. pprather
    pprather
  9. alchemy
    alchemy
    JohnLewis likes this.
  10. JohnLewis
    JohnLewis
  11. YBNormal
    YBNormal
    from Oklahoma
    Thanks all for the feedback. The folks at Irontrap had a set but advised if I'm trying to match the factory horn the reproductions would not be a good match. So, I will continue the quest for a stock one for now. Thanks again.
  12. krylon32
    krylon32
    from Nebraska
    Also R Jays does a pinched and bobbed ch***is so he should have front horns?
  13. leon bee
    leon bee
    I'm curious, why is there a market for those pieces? For building your own frame?
  14. Fordors
    Fordors
    Most likely for damaged or hacked up frames. Fronts get bent, bobbed or completely removed and rears are cut off when channeling a body.
    leon bee likes this.
  15. DDDenny
    Its due partially to the trend of drinking the "traditional" kool-aid, a lot of cars are being returned to more of a hot rodded but stock appearing theme since their "street rod" period.
  16. krylon32
    krylon32
    from Nebraska
    A pair on the Iron Trap Garage for sale site.
  17. YBNormal
    YBNormal
    from Oklahoma
    Appreciate the heads up on these and I reached out to them, but was told if I want it to match the stock right side, I would be disappointed. Not sure what the major difference is but I'll take their advice and keep looking, at least for a while. Thanks again.
  18. bangngears
    bangngears
    from ofallon mo
    Try Randy Clark at Hotrodsandcustomstuff in San Diego
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
  20. krylon32
    krylon32
    from Nebraska
    If the Iron Trap Garage horns are off a pair of ASC rails there is a slight difference in the vertical height of the rails from side to side. Never caused a problem but we discovered it when we took one rail to the laser cutters to get scanned for boxing plates and when I got a hundred plates cut my frame boxer came over to my side and said there's a problem, plate doesn't fit both sides. Required a slight trim.
    rod1 likes this.
