1932 ford headlight bar
Discussion in 'The Hokey Ass Message Board' started by brigzee, May 11, 2009.
  1. brigzee
    brigzee
    from Kennewick
    This is probably a dumb question but everyone I talk to gives a different answer, why are the ends of my headlight bar painted? I just bought the car and it's my first 32 ford I have owned so I don't know all the answers.
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    'Cause that's the way, uh huh, uh huh, Ford made 'em, uh huh, uh huh!
    kandrews70 likes this.
  3. Fogger
    Fogger
    The original headlight bars were forged steel with a center wrap of stainless. Yours appears to be a B bar, no V8 emblem. The V8 bars had a hole in the center for that piece of trim. Yours has also been dropped which lowers the headlights. I've had Pete Eastwood drop a couple for me and in my opinion makes it more valuable. Hang on to it. The FOGGER
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    Always wanted to use that.
    Seriously, the headlamp bars for 1932 are forged steel and the center between the headlamp cups is jacketed in stainless steel. The 4cylinder bars are smooth and the V8 bars have a hole drilled midway for the diecast V8 emblem to mount there.
    The center jacket is seamed on the bottom side.
    The 32 bar also used special headed mounting bolts at each end with a round carriage bolt style head and an oval offset shoulder which fits into the oval holes in the bars (no, they're not oval for adjustment).
  5. Yep, mine's a repop and it's one piece - the originals are getting hard to find - nicely dropped by the way.
    Steve
  6. brigzee
    brigzee
    from Kennewick
    Thanks for the answers, I figuered it was stock but never recalled seeing one that was dropped. I am sure I will have more questions before the project is done.
  7. Deuce Roadster
    Deuce Roadster
    Here is a reproduction of a stock one ... one that has not been dropped ...
    Both of these are original ones that has been dropped (like yours ) :)
    Good original headlight bars are getting more and more difficult to find ... NICE SCORE :eek:
  8. Deuce Daddy Don
    Deuce Daddy Don
    I have the 4 banger one, up in the attic, original, painted black both ends, stainless cover in the center, no hole in the center, anyone know the value???????------Don
  9. 327-365hp
    327-365hp
    from Mass
    Every one I've seen is $100.
  10. Deuce Roadster
    Deuce Roadster
    Swap meet price about here is $100 to $150 for VERY NICE ones ...
    California ( LA ROADSTER swap meet :) ) may be a little higher
  11. alchemy
    alchemy
    If anybody has a B model bar without the center hole, DO NOT drill it for an emblem install. The B bars are much harder to find, and a lot of hot rodders don't want the gingerbread trim on their bars. If you want an emblem trade your bar for a pre-drilled one.
  12. Deuce Daddy Don
    Deuce Daddy Don
    OK, thanks guys, just wondering as I have so much gennie stuff up in attic plus that gennie light bar. (4 cyl. undrilled).--------------Don
  13. Fogger
    Fogger
    As an addition, and stated by Pasadena above, be sure to get the correct headlight bar to fender brace bolts and rubber pads for the fender surface. CW Moss, Bob Drake, all the normal dealers have them. The FOGGER
  14. HOTRODPRIMER
    HOTRODPRIMER
    I thought the same thing Randy,,,but on closer inspection it is an original headlight bar with the stainless wrap but the ends have been chromed,,,and starting to peel!:rolleyes: HRP
  15. sawbuck
    sawbuck
    from 06492 ct
    any one know if the 32 bar fit 32 33 34 ford trucks ? the fenders look the same..thanks sawbuck
  16. sawbuck
    sawbuck
    from 06492 ct
    someone must have tried this on a truck????
    thanks
  17. alchemy
    alchemy
    I know for sure they will fit a 32 truck, but I think the 33-34 is slightly different. I have a 33-34 bar (with truck headlights) and I think the ends are slightly more arched. And they have no stainless on them. I forget whether they take goofy bolts though.
  18. sawbuck
    sawbuck
    from 06492 ct
    thanks, i thought i read somewhere to bend the bar a little and it will fit ...anyone try this ???
