Projects 1932 Ford Roadster Build- "The Template Roadster"
Discussion in 'Traditional Hot Rods' started by x77matt, Jan 4, 2018.
  1. FE_STEVE
    FE_STEVE
  2. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    Looks fantastic Matt! Can’t wait to see more progress.
  3. Great build and thread!
  4. rpm56
    rpm56
    Real nice work, kudos.
  5. Very nice work!
  6. x77matt
    x77matt
  7. x77matt
    x77matt
    Thanks Steve
  8. x77matt
    x77matt
    Thanks a lot guys!
  9. solidaxle
    solidaxle
    from Upstate,NY
    This maybe your first build thread, but it's not your first rodeo! nice work. If you need a S.Co.T. blower there's a local guy selling one, pm me if interested.
    Stogy and sko_ford like this.
  10. x77matt
    x77matt
    Th
    Thanks! And interested... sent you a PM.
    Stogy likes this.
  11. 51box
    51box
    from MA
    Great job on the roadster, lots of cool parts coming together
    x77matt likes this.
  12. Malcolm
    Malcolm
    from Nebraska
    Nice work so far. Looks like it will be a super cool and fun little roadster when you're finished!
    Stogy likes this.
  13. ct1932ford
    ct1932ford
    Great work! Enjoying this Thread.
    Stogy, x77matt and kidcampbell71 like this.
  14. ct1932ford
    ct1932ford
    I have bushed my pitman arms down so I could use a size smaller bolt. Also some grinding and smoothing helps it not look so bulky. You may have done this or better already by the looks of thing. IMG_2033.JPG
    alfin32, Stogy, Atwater Mike and 8 others like this.
  15. alanp561
    alanp561
    Just a suggestion, it's 308 stainless rod for stainless to stainless, 309 for stainless to mild steel.
    Stogy likes this.
  16. T&A Flathead
    T&A Flathead
    Congrats on the roadster find. Looks great. Would love to find a roadster in that condition, my coupes need some ******* company in the garage.
    Stogy likes this.
  17. x77matt
    x77matt
    Thanks for the idea! This is great! I'm going to do this.
    Stogy likes this.
  18. x77matt
    x77matt
    Thanks! They make a nice couple
    Stogy likes this.
  19. x77matt
    x77matt
    Thanks for the tip... I just double checked and I used 308L rod. Steel to steel. I'll have to research a bit and double check if this an issue. I have other friends that have done this but I didn't ask if it was 309....
    Stogy likes this.
  20. x77matt
    x77matt
    Hi guys- sorry for the delay in this thread.... I finally made it out to the garage for the first time in 4 months due to my wife having surgery and also having my little niece staying with us for a bit. I am thinking about trying something crazy and wonder if any of you have actually done this with success-
    Has anyone used a flattened 40 crossmember with a T rear spring with a halibrand? Natural sense says you need a model A rear crossmember, however, if I squint my eyes, I can vision that this could almost be done. Here is a close example of what I am shooting for- did any of you build this, and did it work in the end? Looks like a flat 32 crossmember:
    ***uming the above concept will work, I went to work on a 40 rear x-member:
    20180422_205226.jpg 20180422_201931.jpg 20180422_201926.jpg 20180422_190017.jpg 20180422_190014.jpg 20180422_190010.jpg 20180422_190006.jpg
    alfin32, Stogy, 32SEDAN and 3 others like this.
  21. x77matt
    x77matt
    Finished up the spindles, steering and tie rod also last weekend. I cut down a tie rod for the drag link, and re worked an f100 steer arm and changed it from a ball to a normal 7degree tie rod socket so I could use standard tie rods at both ends. I am running 40 spindles and old chrome backing plates to go with my old chrome wishbone and axle....
    20180421_104547.jpg 20180421_104542.jpg 20180421_104537.jpg 20180421_104533.jpg
    Stogy, rpm56, 32SEDAN and 2 others like this.
  22. x77matt
    x77matt
    20180416_203701.jpg Oh yeah- and picked up an original Schroeder wheel from a friend as well. I have a repop in stock, but wanted an original for this build. I think it's a Schroeder as the Bell wheels I think had more of a lip where the rubber meets the rim....
  23. 1-SHOT
    1-SHOT
    from Denton
    FYI you can use 309L to make cast iron repairs, but if you need to drill and tap it beware it's hard. You will need a carbide bit and can only tap it about 1/4 turn at a time go slow and easy. Frank
  24. solidaxle
    solidaxle
    from Upstate,NY
  25. alchemy
    alchemy
    I would either patch in a piece of T or A rear crossmember, or curve the 40, so the top of the spring has an arched pocket to sit in. You won't be able to clamp it in place if the curved spring is trying to mount up to a flat surface.
    Stogy and Runnin shine like this.
  26. continentaljohn
    continentaljohn
    Awesome 32 roadster build
  27. x77matt
    x77matt
    Thanks for the tip!
    Stogy likes this.
  28. x77matt
    x77matt
    Yes- agreed. I haven't got that far on my thinking yet, but you are right. Thanks for that catch, I would have figured it out the hard way
  29. sloppy jalopies
    sloppy jalopies
    I have a '39 ford rear crossmember... but can't ship... in 04210.
    Stogy likes this.
  30. x77matt
    x77matt
    Thanks John!
    Thanks for reminder- I even posted in that thread but totally forgot about Cyclone Kevin's description . This gives me hope here.... for sure I am going to try to move the tank back a little like described in that thread...
    Stogy and Cyclone Kevin like this.
