Projects 1932 Ford Roadster Build- "The Template Roadster"
Discussion in 'Traditional Hot Rods' started by x77matt, Jan 4, 2018.
  1. x77matt
    x77matt
    Did one more tweak to the crossmember to raise the front edge a bit more...
  2. x77matt
    x77matt
    I tackled the passenger door skin last weekend. I've done several door skins in my day, but the roadster is the toughest due to lack of access to the back of the skin for hammer and Dolly work.
    The eBay door skin patches are total crap as they are flat and don't fit right. So they went in the trash, and I used a roof panel off of something 1960's that had a good compound curve in it. Rather than braking the edges like normal, I welded it on without the edge so I could get a flat spoon behind to work the weld bead. Then I just edge welded the bottom and sides and blended them in... tip: the grey stuff is weld through primer and it created havoc when I edge welded the back of the skin on. It kept wicking up into the bead and I would have to grind and reweld.
    20180421_135953.jpg 20180421_140004.jpg 20180421_140014.jpg 20180421_145511.jpg 20180421_202755.jpg
  3. x77matt
    x77matt
    It's roughed in for now. Another day of metal finishing will get it done....
    jalopykid and kidcampbell71 like this.
  4. alchemy
    alchemy
    Looks good. It's been over twenty years since I did that on a 32 roadster, and I don't remember how I got my hand inside the door to hold a spoon. Maybe I had smaller hands back then?
    V8-m likes this.
  5. x77matt
    x77matt
    Yup! Harder than it looks!
  6. qzjrd5
    qzjrd5
    from Troy, MI
    Looks awesome dude. I might have to pay you to tutor me on the bodywork for my next project.
  7. x77matt
    x77matt
    Mike- you need to come over and play :)
  8. 1-SHOT
    1-SHOT
    from Denton
    You can't rush this kind of metal work. It takes time and patience and determination.
    Ask me how I know
    x77matt likes this.
  9. CTaulbert
    CTaulbert
    from Detroit
    At this pace, it's going to be a roller in no-time!
  10. Rand Man
    Rand Man
  11. x77matt
    x77matt
    Does this count?? I tacked in the rear crossmember and mocked it up with a spare 40 rear I had. I only had a set of 6.00's but I wanted to check and make sure I had them centered in the rear wheel wells. Still need to locate some front brakes drums and then I can mockup the front.
    20180428_184323.jpg 20180429_190606.jpg 20180428_184339.jpg 20180429_003618.jpg
    sko_ford, clem, brEad and 1 other person like this.
  12. x77matt
    x77matt
  13. PRIMER STUDIO
    PRIMER STUDIO
    from Bozeman,MT
    32SEDAN and slv63 like this.
  14. scotti32
    scotti32
    Wow, great roadster, great work. It is going to be killer.
  15. x77matt
    x77matt
    Thanks Brandon! Hope to see yours in its new form soon!
    Thanks Scott!
  16. x77matt
    x77matt
    Today I stole the 4.50/ 7.50 off of my coupe for a better mockup and rear end placement. I think I like where the tire sits in the wheel well. Next, I'll go pick up the 35 rear axle I bought and tear it down to test fit the quickchange.
    20180505_175415.jpg 20180505_175351.jpg 20180505_175432.jpg 20180505_175442.jpg
    rpm56, lodaddyo, clem and 8 others like this.
  17. Pewsplace
    Pewsplace
    Looks great and very traditional styling.
    Atwater Mike likes this.
  18. x77matt
    x77matt
    Thank you!
  19. 32partsguy
    32partsguy
    from DFW,Texas!
    Go Man Go! That looks great!
    x77matt likes this.
  20. x77matt
    x77matt
    A couple weeks back I saw a post on the flathead facebook group showing some Ardun heads at a swap meet in Englishtown, and in the back of the photo I saw a SCoT blower setting there. The person who posted the photo happened to have the contact info for the seller and so I called up and struck a deal.... A couple weeks and a friend-of-a-friend relay later, this is now in my possession.
    It's a never used H&H unit with a little shelf wear and it will be perfect for the roadster.
    Darkhorse, sko_ford, rpm56 and 11 others like this.
  21. el Roach
    el Roach
    Sweet ride!
    x77matt likes this.
  22. x77matt
    x77matt
    Is anyone here running a Scot blower with a mechanical fan? I refuse to run an electric one and i haven't seen a lot of setups without. Any good ideas?
    Also- thinking of sending my 48 crab to bubba for a rebuild. Before I do, do any of you have a tried and true setup you like to run with the blower?
  23. x77matt
    x77matt
    I picked up a nice 36 rear this weekend and mocked up the quickie. With my flat 40 crossmember- the 36 rear spring works, but I have about 1.5-2" of travel until the halibrand bottoms out on my crossmember- about when the axle housing bottoms out on the frame. I'm either going to swap out to a model a rear crossmember and spring, or do some more fine surgery on the one I have in there now... Haven't decided. I'd like to gain about another inch and it would be good.
    20180519_152951.jpg 20180519_153011.jpg 20180519_230514.jpg 20180520_140921.jpg 20180520_151030.jpg 20180520_151040.jpg
  24. x77matt
    x77matt
    Oh yeah- mocked up my 3" chopped windshield today as well...
  25. louisb
    louisb
    Looking good!
    —louis
    x77matt likes this.
  26. solidaxle
    solidaxle
    from Upstate,NY
    Here's what I did.
    https://www.jalopyjournal.com/forum...nning-a-blown-flathead.1098104/#post-12453891
    https://www.jalopyjournal.com/forum...nning-a-blown-flathead.1098104/#post-12454045
  27. x77matt
    x77matt
    Thanks Solidaxle- I'll attach a couple photos of the water pumps I'm gonna use. I'll need to swap to a different dual pulley generator with a front mount style I think.
    Also for some reason the balanced doesn't look right. It's a Chevy style harmonic balancer that has a single pulley and a larger dual pulley that seem to sandwich together. The odd part is that the 6 hole pulleys don't seem to bolt on to the 3 hole balancer. The holes "wink". Also the bolt kit for the H&H blower is a different thread than the balancer that came with my blower purchase. I suspect my used kit has an alien balancer in the mix:
  28. x77matt
    x77matt
    Based on that thread- I might want to reconsider using stock 32 front mounts (like I was planning) and switch to water pump mounts... Also- I have a 59a and was planning to run a crab, unless there is a big benefit to running g an 8ba front cover with a Chevy style dizzy.
  29. x77matt
    x77matt
    I started a little mockup this week. Waiting on my engine mount brackets to arrive, as well as my Reds Headers. trying to decide if I'm gonna pull the trigger on a set of kmember leg extensions from Industrial chassis. I used them ony sedan and they are really nice. I must say I was in a bit if a panic as I cut into the absolutely perfect k-member but the jeep t5 will be totally worth it once the crying is done.
    20180526_161730.jpg 20180601_134723.jpg 20180506_173500.jpg 20180601_213316.jpg
    Fairlane500, jalopykid and brEad like this.
  30. Wow! Great first build thread! Subscribed for the rest of the ride.
    x77matt likes this.
