1932 ford roadster - built flat head , easy project
Discussion in 'Cars For Sale' started by dogballs, May 5, 2020.
  1. dogballs
    dogballs
    City: NORTH LAS VEGAS
    State: Nevada
    Price: $ 29,500
    Clean Current Calif. ***le As A 1932 Ford Roadster
    Org. Frame & Vin #s With Stars, With California Lic. Plates & Non Op...
    Body:
    Steel Reinforced Gl*** Body, Steel Firewall & Gas Tank & Steel Full Hood
    With Louvers On Side Panel. (Not Fitted). All Doors & Trunk latched &
    Work Correctly. Chrome Chopped Windshield Frame & Stanchions & S.S.
    Grill Insert & 39 Taillights. Steel 32 Grille Shell With All Chrome Factory
    Trim, Bodywork Is Close For Paint...
    Motor: 59A Built - Merc. Specks, 4" Stroker Crank, 3.186 Pistons Polished
    Edelbrock Heads, Stainless Valves With Adjustable Lifters, Hidden EGR
    Valve Polished Dual Carb. Intake, & Dress Up, (((All New))) Super 97s Carbs,
    Elect MSD Ignition. High Volume Oil Pump, ARP Fasteners Throughout,
    High Torque Starter, 100 Amp Chrome Alternator, Fenton Headers With Full
    Exhaust, Heavy Duty Radiator With Elect Fan, Motor Is Overbuilt & Fully
    Dressed,Runs Great.
    Transmission:
    1971 C4 Trans Built By Flat-O-Matic (Fully Polished) & Detailed
    Gennie Shifter & Acces.
    Frame:
    Fully Boxed Original Frame With Factory Vin #, All Chrome &
    Polished Stainless Steel, 4" Dropped With Radius Rods & Vega
    Steering Box, 12" F-1 Truck Front Brakes, (New) 8" Ford Rear
    End With (New) 300 Gears Recommend By (Flat-O-Matic)
    Transmission, Triangulated 4-Bar With Billet Coil-overs. All (New)
    Brakes Front & Rear, (New) Wheel Cylinders, (New) Springs, (New)
    Pads, (New) Steel 'Tanks' Fuel Tank, (New) Chrome Spreader Bar,
    Front & Rear, All (New) Steelies With (New) Tires. Full Exhaust With
    S.S. Gl*** Pack Mufflers. Under Floor Power Brakes & Booster...
    Interior:
    Full Set Of 6 VDO Gauges, Polished S.S. Column & Polished Column
    Drop. Chrome Pedal & Dress Up.Hot Rod Wiring Harness,
    (((Car Is Fully wired))). Ultra Leather Seats,
    More Info:
    This Car Is (((ALL NEW))) Nothing On This Car Is Used, Best Of
    Everything, Very Close To Be A Driver, It Needs A Driveshaft & Hard
    Brake Lines To Be A Driver... This Is A Quality Car, I Am 80 Years Old &
    Not Able To Finish... You Wont Be Unhappy With This Car, I Have
    (((All The Paperwork On The Car))) The Car Has A Separate Wiring Fuse
    Box That Is For Engine & Distributor, Fuel Pump, Elect Fan...
    IMG_20200406_110326 (1).jpg IMG_20200504_105622.jpg IMG_20200424_122602.jpg IMG_20200424_122614.jpg IMG_20200406_110159.jpg IMG_20200406_110236.jpg IMG_20200406_110224.jpg IMG_20200406_110509.jpg IMG_20200406_110527 (1).jpg IMG_20200406_110518.jpg IMG_20200406_110603.jpg IMG_20200406_110301.jpg IMG_20200406_110701.jpg IMG_20200406_110726.jpg IMG_20200406_110745.jpg
    new paint blk/clear- not cut and buffed yet, new red interior including trunk
    should be done end of week......
    $ 29,500 obo
    Open To Offers ???
    Awesome Car...
    Ken 702 575 7100
    kenbozdog@gmail.com
    Mattsbidnuz and Jeff Pandora like this.
  2. dogballs
    dogballs
    update- IMG_20200508_122832.jpg IMG_20200508_122857.jpg IMG_20200508_123028.jpg IMG_20200508_122832.jpg IMG_20200508_122857.jpg IMG_20200508_123028.jpg
    Jeff Pandora likes this.
  3. dogballs
    dogballs
  4. dogballs
    dogballs
    IMG_20200515_164241.jpg top . runs exc. / easy finish
    catdad49 and Mattsbidnuz like this.
  5. dogballs
    dogballs
  6. dogballs
    dogballs
    new driveshaft done, new windsheild done. soon to ebay
    Mattsbidnuz likes this.
  7. dogballs
    dogballs
    last chance before i kill ad, new drive shaft- all new from joints, yoke, tube etc all balaced almost 500, new tinted windsheield- gl***, new trans cooler mounted and done, pretty acorn caps installed, all car will need is hard brake lines ran- soft braided done in front, have rear braided lines and misc. included. have all reciepts all the way back from start. dad got old or more intrested in 53 vette pro touring were finishing & i have to many of my cars- not a fire sale IMG_20200524_174136.jpg
    Rick28 and catdad49 like this.
  8. dogballs
    dogballs
