Projects 1932 Ford Roadster P-51
Discussion in 'Traditional Hot Rods' started by AULIZ, Nov 21, 2020.
  1. AndersF
    AndersF
    Kind of ****s to restore a brand new body.
    But i dont have any doubt that its going to be just as cool as your other builds.
    Stogy and kidcampbell71 like this.
  2. AULIZ
    AULIZ
    Rewelded and fixed one part of this body.
    pressed few louvers
    Aulis
    stoker-161.jpg stoker-162.jpg stoker-163.jpg stoker-164.jpg stoker-165.jpg stoker-166.jpg
    brEad, Okie Pete, Just.dale and 3 others like this.
  3. getow
    getow
    Nice going. Looks like a ton of cool tools also.
    Stogy likes this.
  4. AULIZ
    AULIZ
    Slowly going foward. Nothing expensive tools/machines. I try to buy every year something new. When I was younger, I didn´t have money to buy tools what I want to.
    Now situation is better and try to enjoy using all what have bought. Small garage, not possible to have there all what needed...
    Okie Pete and Stogy like this.
  5. AULIZ
    AULIZ
    Saturday, 8hours in garage and tailight panels are nearly ready for final installation to the body. 1st I stretch little more those cups which I have presslathe few weeks ago.
    Everything else, except hammering, You can see in pics.
    Aulis
    stoker-155.jpg stoker-168.jpg stoker-169.jpg stoker-170.jpg stoker-171.jpg stoker-172.jpg stoker-174.jpg stoker-175.jpg stoker-176.jpg stoker-177.jpg stoker-178.jpg stoker-179.jpg stoker-180.jpg stoker-181.jpg
    brEad, Okie Pete, TagMan and 5 others like this.
  6. patsurf
    patsurf
    how many people are going to ask if those are old 50's buicks!!-..beauty!
    fegsta likes this.
  7. AULIZ
    AULIZ
    ha haa, I hope not so many.
    thanks.
    a
    Stogy likes this.
  8. GeeRam
    GeeRam
    Has to be from an English Electric Lightning fighter, as that was the only RAF aircraft that used a brake parachute that small at that time.
    The only other RAF aircraft to use them were the Vulcan and Victor V-Bombers, but they were huge!!
    48fordnut likes this.
  9. roen132
    roen132
    Looking great!!
    Stogy likes this.
  10. AULIZ
    AULIZ
    Welding Tuesday
    ah
    brEad, Okie Pete, Stogy and 3 others like this.
  11. AULIZ
    AULIZ
    Epiphany (6th of Jan) is here dayoff. Just worked 6hours in garage. They have bolted on rear panel and after that spotwelded it strongly (they have good spotwelder in Brookville). Also under floorpanel have mig welding. After cutting and drilling hour or two, I finally removed panel.
    I want that both panels upside and downside of trunk lid are easy to remove (bolts). When this panel is removed, easy to grind weldings around taillight cups and paint epoxy, final 2K acryl....
    New sheetmetal part around tailligt must be stretched before installation. You know, that when You weld it on, it shrink strongly. I have stretch part before welding when I made those panels. Can also stretch later after welding and grinding. In this case there (backside) is no free space to use dolly when stretch with hammer after welding.
    Too many pics,... stoker-187.jpg stoker-188.jpg stoker-189.jpg stoker-190.jpg stoker-191.jpg stoker-192.jpg stoker-194.jpg stoker-195.jpg stoker-196.jpg stoker-197.jpg stoker-198.jpg stoker-199.jpg stoker-200.jpg stoker-201.jpg stoker-203.jpg
    Aulis
  12. AULIZ
    AULIZ
    It takes very much job that all fit after welded so much. Finally looks better after Thursday 5hours shrinking, hammering and streching.
    Aulis
    brEad, Okie Pete, Stogy and 5 others like this.
  13. AULIZ
    AULIZ
    This part of body is ready. All panels + trunk lid fit good and easy remove, bolt on - bolt off. Both taillights installed. Next need to made alum. rings bezels to those anther holes.
    Aulis
    stoker-208.jpg stoker-209.jpg stoker-210.jpg stoker-211.jpg stoker-212.jpg stoker-213.jpg stoker-214.jpg
  14. AULIZ
    AULIZ
    1932 roadster package tray.
    Aulis
    stoker-215.jpg stoker-216.jpg stoker-218.jpg stoker-220.jpg stoker-221.jpg stoker-222.jpg stoker-223.jpg stoker-224.jpg stoker-225.jpg stoker-226.jpg stoker-227.jpg stoker-228.jpg
  15. AULIZ
    AULIZ
    Slowly I piece body and reweld all MIG weldings. Same time can make few own things.
    Aulis
    stoker-230.jpg stoker-231.jpg stoker-232.jpg stoker-233.jpg stoker-234.jpg stoker-235.jpg
    Stogy, Jeff34, nunattax and 2 others like this.
  16. AULIZ
    AULIZ
    few pics Monday-Tuesday. Both "drops" made and welded. 3squaremeter 4mm plywood bought (interior).
    stoker-236.jpg stoker-237.jpg stoker-238.jpg stoker-239.jpg stoker-240.jpg stoker-241.jpg stoker-242.jpg stoker-243.jpg stoker-244.jpg stoker-245.jpg stoker-246.jpg stoker-247.jpg
    Aulis
  17. AULIZ
    AULIZ
  18. Pete
    Pete
    I love your vision, your approach and style!!! excellent work.
    fauj and Stogy like this.
  19. AULIZ
    AULIZ
    Thanks Pete.
    Today continue this project. Need to made those plywood panels during next days.
    I want to leave those to upholsterer.
    When I made those door panels, I remembered what brookville door inner panel is not same model RH and LH.
    I found old plan there I was wrote all diffences. If You make those panels, its good to remember it.
    stoker-255.jpg stoker-256.jpg stoker-257.jpg stoker-258.jpg stoker-259.jpg stoker-260.jpg stoker-261.jpg stoker-262.jpg
    Aulis
    brEad, chryslerfan55, Stogy and 2 others like this.
  20. AULIZ
    AULIZ
    Sunday morning.
    aulis
  21. AULIZ
    AULIZ
    Too much dayjob, not worked so much with roadster. Monday-Tuesday I cut and fitted floorpanelkit right dimensions. Before that I shim and bolted body 1st time on frame. Now doors work perfect clearances are Ok.
    Drilled holes, made threads and bolted on female and male dovetails both side. Im not sure if I drill outside door handle holes or keep it "shaved".
    Finally made patch panels, drilled, file those ready. I had one extra littre German brand Osmocolor woodwax. Many times , I have painted all plywoods, but now used that wax. Thursday I left all interior to upholsterer.
    after one or two week arrive CA seacontainer where is also sometihing for me. Engine parts to built that 296cid engine, gaugestuff, engineparts from HH Flatheads, 97 carbs, intakes, magneto,...
    I think, hydraulic tubes for seat frames are ready. Monday need to pick those up from one of those local hydraulic and pneumatic shops called "nestepaine oy". I want to install P-51 magnesium seats very low because windshield frame is little over 3" chopped. Big steering wheel is what I like to use.
    AULIS
    30cm (12") snow here. last week -25 dec celcius 1-2days. Now, normal few minus decrees celcius.
    Days are going longer, so need to be ***iduous in garage.
  22. VF-1
    VF-1
    Very nice! True skills!!
    Stogy likes this.
  23. AULIZ
    AULIZ
    Thanks Sir.
    Today, Saturday, I made 6pc 1932 spindle >< Early Lincoln backing plate fitting plates. Still need to drill new holes to backing plates. If You need those, I can made more. $30.00 pr. There was nice shiny black paint under old firewall insulation.
    Made plywoods under ****. After Saturday evening Sauna (4 x week we have sauna warm (100dec celcius), finnish weekly tradition) I cook water and try to bend those plywoods.
    Oskar bought own hot rod training seat. Here we keep good hot rod driving feeling over winter ... playstation driving and racing.....
    I was glue wood plugs to 4 of those 7 holes. I was relocate those. Body threads and holes in floorpanel were not meet.
    Aulis
    stoker-268.jpg stoker-269.jpg stoker-270.jpg stoker-271.jpg stoker-272.jpg stoker-273.jpg stoker-274.jpg stoker-275.jpg
  24. neds29
    neds29
    Beautiful fit on those body panels. Henry could not have done better! Lots of neat trophies in your back room. Keep the pics coming.
    Noted the snow outside your window- luckily we don't get that here in Phoenix. 65 degrees here today. That's one reason why my great-grandfather left Norway.
    Ned
    Stogy likes this.
  25. AULIZ
    AULIZ
    I like warm places like Arizona, Californa.... But now need to live here until Oskar is moved to live on his owns.
    Now we have very much snow , +10", but today rain water,... It would be better if have little colder all the time.
    Winter is good to work more in garage or have other hobbies. If have all the time nice warm weather, You do not have so much time to work with projects because You enjoy outside ....
    Aulis
  26. AULIZ
    AULIZ
    Monday-Tuesday.
    Too many pics, sorry about that.
    Seat panels are cut and bended (hot water). I was dry those in sauna. 2hours in 90-100dec Celcius.
    Next week I leave those to upholsterer.
    Floorpanels are ready and waxed. 10holes need to move.
    Firewall is welded (cracks and missing part from leg) and broken bolts removed.
    Today I cut, fit and sand woods behind cabin.
    Aulis
    stoker-278.jpg stoker-279.jpg stoker-280.jpg stoker-281.jpg stoker-282.jpg stoker-283.jpg stoker-284.jpg stoker-285.jpg stoker-286.jpg stoker-287.jpg stoker-288.jpg stoker-289.jpg stoker-290.jpg stoker-291.jpg stoker-292.jpg stoker-293.jpg
  27. AULIZ
    AULIZ
    Some engineparts arrived from USA.
    Magneto switch, tachometer arrived earlier. Navarro heads found also from own stock.
    Will make 296cid engine this rod and another engine I will built like "for sale engine".
    296cid: 4.125" stroker Ross pistons, **** h-beam rods 2" journals, windfield SU1 cam, 1.60 Elgin valves In&Ex, vertex or scintilla magneto, G-185 springs, navarro intake, navarro heads, Auliz - oilpan, alum. flywheel + 10" clutch, 2 x 97, 2 x helling-Stelling cleaner,....
    239cid: 030 oversize basic pistons and 8ba rods, L-100 cam, industrial cooled oilpan (waterpump or generator -flathead), basic "balls" -distributor converted to 12V, Edelbrock heads, 2 x 2bbl intake, new valves etc....
    Aulis
    stoker-297.jpg stoker-298.jpg stoker-299.jpg stoker-304.jpg stoker-305.jpg stoker-306.jpg stoker-307.jpg stoker-308.jpg
  28. AULIZ
    AULIZ
    cutting and planning
    AH
    stoker-309.jpg stoker-310.jpg stoker-311.jpg stoker-312.jpg stoker-313.jpg stoker-314.jpg stoker-316.jpg stoker-317.jpg
  29. Dirty Dug
    Dirty Dug
    Beautiful work. But why do you have blisters on the cowl sides?
    Fogger and Stogy like this.
  30. AULIZ
    AULIZ
    Why not? vintage aircraft style and of course old race car style..... Too easy to built hot rod without modifications. If I go to hot rod meeting (street rod meeting) I can see those 1932 cars like "sheeps" in the field.
    I like those Blisters. I can see also this hot rod ready with hood sides, painted old style acryl 2K paint nice colour, wheels and tires under car, alum. parts all over inside and outside, 3" chopped windshield frame bolted on, Alum. homemade grill......
    Blisters. why not?
    Aulis
    brEad, bymanr, chryslerfan55 and 10 others like this.
