Technical 1932 Ford Roadster Pickup
Discussion in 'Traditional Hot Rods' started by chev34ute, Jan 8, 2020.
  1. chev34ute
    chev34ute
    Hey Guys.
    After buying a whole of bunch steel last year, I have been making a shortlist of bodies I want to finish off. One that has been on my mind the most has been my collection of 32 parts.
    In 2016/17, I purchased enough parts to start piecing together a 32 Roadster Pickup. What I have is an original 32 Commercial Grill, Cowl, Hood Top, Front Fenders and Running Boards. The Fenders and Running Boards are very rough but the other parts are very solid.
    I also purchased a repro steel stock style firewall and louvred hood sides. In addition to that I also own a 1934 BB Truck that I can use for patterns for the doors and cab. I have been looking at images of 32-34 Roadster Pickups to get ideas so I would like some more.
    With all the steel purchased along with a soon to be completed stand alone workshop, I finally have the resources to start putting it together. I will be getting rid of a few other projects beforehand so I will have plenty of time to plan this out.
    The most important thing I need is detailed photos of the floor area, cab section, dash surround and b pillars as I want the cab to be as close to the factory configuration as possible.
    I am also after dimensions for the doors and the panel at the rear that features the recesses as the Truck cab I have does not have this feature.
    Any help will be greatly appreciated.
  2. HOTRODPRIMER
    HOTRODPRIMER
    clem likes this.
  3. chev34ute
    chev34ute
    2B2ECA21-9BDE-471F-A8B3-E4BD9FCFA6D1.jpeg 69A57E5F-560F-4DC6-8381-07726023846D.jpeg F66F6852-6649-410A-ADBD-18C6B9AC8CC6.jpeg
    These are the panels, I will be fabricating, the highlighted areas are the sections I need measurements for.
  4. chev34ute
    chev34ute
    I know, my cowl is a genuine open commercial one, they were also used for buses and fire trucks and over here, closed cab trucks as well. Nothing interchanges between the Roadster and Pheatons. I believe my cowl sat on a truck similar to the one in the image above, notice the straight Windscreen frame along the bottom and the seaparate A Pillar that ties the cowl and doors together. The cab is similar to the 31/32 Chev ones.
  5. tub1
    tub1
    from tasmania
    You got any doors ,I'm thinking half doors of a Aussie truck ,think I know of a pair
  6. chev34ute
    chev34ute
    I will be fabricating everything including the doors. The doors will be relatively easy once I get the measurements of the length.
  7. 32 RPU cab looked much like a closed cab cut down.The back panel looks like the closed cab.Since they all shared the 32 frame,and wheel base I would think the length of doors would be the same as the closed cab.
  8. mgtstumpy
    mgtstumpy
    Local steel car, been around for years. I'll see if I can catch up with him
    This is a 34, note the filler section, I believe the screen is the same as model 'A' however I could be wrong.
    kidcampbell71 likes this.
  9. clem
    clem
    061681B8-97C0-47B3-B8B9-9051FC119C43.jpeg 4BBA59D5-A643-45B3-B133-B3D5790698BA.jpeg E231CDE2-7280-4428-9CBF-C83AF5EAA66A.jpeg
    I don’t believe that the top (black) one in post 8 is a genuine rp.
    Here’s an original, above.
    I have a few more pictures that I have saved, if you are interested.
    kidcampbell71 and stillrunners like this.
  10. clem
    clem
    Here’s a couple of examples from Richardson truck museum in Invercargill, of the commercial.
    I think around 430 rpu made and I thought that I read once around another 400 commercial cowls made ? Would be interested to know. I also have the commercial cowl - bought it for the original vent mechanism.
  11. chrisp
    chrisp
    clem and BigDTexasKid like this.
  12. continentaljohn
    continentaljohn
    446F3A4F-621A-4DD3-BA25-6AF3190BCB71.jpeg 9E55DA31-E4A3-44D8-99C8-086D1E52C859.jpeg 9AC02F46-4321-4838-A7FD-253CCCDE70B5.jpeg EC1FE53C-E829-4623-9286-633405C0784A.jpeg F6F578F0-CB60-4C69-B958-558DDD59A77B.jpeg CE4CFD0B-601C-435D-83BF-039CE4995D02.jpeg D50EC035-A9DD-4355-B538-25D5DD1D2665.jpeg A few pictures I took of a friends 1932 rpu truck collection. I was looking for detail so I can make some dies to make the parts I am missing..
    pprather and kidcampbell71 like this.
  13. continentaljohn
    continentaljohn
    A few more pics of the details of the body. The 1DA0C311-EFA0-4636-830D-1658D863A755.jpeg A07B7479-6395-4CAE-AF3E-FD088BC40BC5.jpeg 81A56D14-7828-4695-A811-819A936DF82B.jpeg FB5F35E1-46AA-4AB9-B04F-38DCC987F4B9.jpeg 3B2F0788-E10F-4E07-ACBD-2D88FD8F4152.jpeg 66D9DC1E-F4A0-4EB0-A4EF-F381969EA0AF.jpeg subrails are the same as a closed cab so the bottom radius is the same in the rear corners.
  14. HotRod33
    HotRod33
  15. chev34ute
    chev34ute
    The stepped swage that sits behind the doors will be the hardest area to reproduce. I have been making up a 30 Pickup cab for a guy in Victoria that I put a swage into, but the one on the RPU protrudes out further. Is there any chance you can get measurements of this area.
  16. chev34ute
    chev34ute
    These two area in particular.
  17. continentaljohn
    continentaljohn
    1B7C6E34-354F-4F14-A596-A99CC707181B.jpeg 7B399B75-16BD-4A56-A3CC-FC8DF98A1109.jpeg 305913F7-61AB-40F9-8B61-4B0B84E4C281.jpeg E6531217-F01C-4913-B0D9-756EDFE27E83.jpeg B41BC863-67D9-4FCD-91E1-5BE4DF0A7A51.jpeg 15CB9B7E-2360-452D-99F1-2E266345EADD.jpeg I will see if I can go and visit as its a few hours away and will see if hes in the south for the winter. I do have a few more picture and will look for the pictures that I had a scale with the picture.
    chev34ute likes this.
  18. redo32
    redo32
    Bobby Walden has built a couple of roadster pickups and there were some good articles I believe on his website, but they are no longer there.
  19. Walle
    Walle
    Im gathering parts for a 32 rpu build myself.
    The detailed pictures in this thread is awesome!
    I have plans to have a batch of windshield stanchions cast from my original set and may sell a few sets if theres any interests. IMG_3158.JPG
    Skickat från min iPhone med H.A.M.B.
  20. chev34ute
    chev34ute
    Thats a great idea, there seem to be plenty of these cowls left over from buses and fire trucks.
  21. chev34ute
    chev34ute
    Hey Guys.
    I am getting home tomorrow so I am hoping to get some photos of the cowl and grill shell in Tuesday. In the meantime here is a photo of the truck cab. This is what I will be using as a pattern for the Roadster Pickup.
  22. chev34ute
    chev34ute
    696879EA-EEAF-430D-A1C3-7CC3C0B66FEC.jpeg CE2C4B56-1070-4000-AA7F-ECADA76D799D.jpeg
    If you study the two photos, you will notice the longer doors on my truck, the truck above it uses the same type of cowl as the Roadster Pickup.
    Look carefully and you will see the A Pillar that fastens to the cowl and door.
    I am ***uming the overall length of the Roadster Pickup Cabs and the Closed Pickup Cabs is the same. Everything is a guessing game when you don’t have the correct panels.
    I had the opportunity to buy a correct rear cab section at a Swap Meet a couple of years ago which could have easily been modified into a Roadster Pickup version, I am really regretting not getting it now.
